Hi everyone, I just finished building the Greyhound by Corel at 1:100 scale. I have placed a few pics of it in the Gallery. I just started my new build of the Charles Morgan and will post pics as I go!
I purchased the kit from Model Expo and have been a long time customer of theirs. After inventory of everything in the box I was short 30 pieces of 1/16 X 3/32 X 24" and short 2 pieces of 1/16 X 1/4 X 24". I contacted Frank at Model Expo and these were sent out ASAP no problems! They do indeed stand behind their product. This is one reason I like getting things from them if they have what I'm looking for.
The Keel, stem and stern post went together well and were all very straight. I tried something different this time and won't know how well it will work or how clean it will look until I start planking the hull. I took the center keel before gluing on the false keel, stem and stern pieces and after marking the bearding line used my Dremel tool sander instead of chisel. Then I glued the remaining flat surface to the full-size stem, false keel and stern pieces. I'd appreciate any input if others have done this and if it worked well for you.
I then pre-shaped and dry fitted the bulkheads. Once square they were glued in place and I then did some additional bevel cutting and sanding. I suspect there will be some tweaking along the way.
I then cut and installed the stern stems. Make sure you align the posts and watch the height making sure not to cut them too short. I then installed the Planksheer and even though I was careful I managed to break (several times) the part going around the bow. I then installed the stanchions and it's very important to make sure they are aligned and most important that when you install the mainrail (again I managed to break this very thin piece several times) they leave enough overhang so that it will accommodate the batten planks.
I looked at a few other build logs at this point and of interest, after the hull was planked it was eventually sanded smooth. However, one would then have to add a fashion piece that is usually painted white along the outside of the plank sheer and I suppose main rail. This was troubling for me and I had to cut off all stanchions and realign to accommodate the stepped look. I really don't know if that was the correct thing to do or take the easy way out, sand the whole thing smooth and add the extra piece later???
Now, currently I'm struggling with the stanchions on the bow that go from the main rail down to the filler block. And, at the same time keep the exterior "future" planking aligned with the balance of other stepped planking. The problem is that the interior bow has this ceiling and waterway planks that are supposed to be sweeping up and smooth (just at the bow).  I've taken this apart a few times and naturally busted up the plank sheer and main rail several times. I look at the blueprint sheets everything lines up but I just don't have the sweeping angle it needs.
I'll keep messing with this until I get it! Meantime any advice is always welcome. Also, I'm thinking of getting a ropewalk jig. Is Model Expos as cheap as it looks? I'm also thinking of ordering a few different chemicals from Jax to oxidize the copper plates before I install them. I was then thinking of putting a sealer on them before handling and installing? I really like the way the Model Shipways picture on their kit looks. Frank said the guy that built it actually used paper! you could use a thick paper and still roll over it with the ponce wheel to get the rivet effect. But, I'll use the copper and will sample a bunch of different shades and methods. Do I want more realistic or what appeals to "me"!!!
The build continues. I planked between the Planksheer and the Main Rail. Admittedly, I struggled at the bow. I only had to do some minor filling for now. I then took a small break and was messing around with how I will do the copper plates. I purchased some chemicals and applied then to the copper. I then made a bunch of plates on a copper strip and used Acrylic paint with very light strokes.
Now, if you remember I very much like the look of the Charles Morgan on the box cover of Model Shipways box. I also did some intense searching and found two other Charles Morgan's built and one placed in a museum. It too had the same look at the box cover (it wasn't the same model). So, the jury is out how or which plates I'll use below the water line. I know what I want to do isn't true to form but darn it... I really like the look!
I've uploaded some pics of where I'm at. On one you can see this jig I made to use the ponce wheel. But the jury is out on that too (I'm not that happy with it). Anyway, opinions welcome!!!! Ron /Homer
Oh, I also forgot to mention that I ordered the 2.5 Serving Machine from Alexy Damonoff. I'm pretty excited about this. I don't plan on making my own rope but this will definitely come in handy for serving etc.!
I've started planking the area between the planksheer and top of wale. For the most part this went okay. However, I did end up having to add some HobbyLite filler to take care of some stuff at the bow. My question is this, I don't want the smooth filler to ultimately show through the black paint. It is different than the rest of the well fitted planks. Do you think I should try to scratch some horizontal lines to try and match the plank strips/lines????
Edited by homer
My build continues on the Morgan. I enhanced the ponce wheel jig to make the copper plates. I took a strip of wood and lined it with very thin strips a quarter inch apart. These strips are just a hair thicker than the copper tape. I then played two more thin strips on top of the two previously glued down. Except, I pushed them closer together so there is a slight overhang such that the copper tape will slide between the bottom two and under the top two. I then laid some more thin cross strips that I could trace the vertical ponce lines. I put these just under 3/4" apart and the others are line up guides. I start by running the ponce wheel along one side of the entire horizontal strip. Then, as I pull the copper strip through the jig, I make the vertical lines. I keep repeating the process until done. I only put one horizontal line because the strips will overlap slightly as they are being applied to the hull.
I've taken some pics of the hull completion. I also added the 1/8 X 1/8" waterway and sanded the top inside edge down. This will eventually taper into the ceiling planks.
I have included pictures of the copper plate jig and ponce for making the plates. Of interest, I purchased chemicals to put a black, red, rust and patina affect on the copper. I did like the way some of them turned out but in the end, I used Acrylic pain with a make-up rubber do-hickey that my wife uses to apply her make-up (I think!). I would dip the soft rubber sponge thing into the paint, tap it a few times then dap it onto the copper plates. I had much more control of the coloring this way. If you recall, I posted a while back that I like the way the copper plates look on the Model Shipways box cover. So, I came close to that but added a patina look and while they are not the most realistic ... I like it and that's what counts!!! :-)
Oh, while I was making the copper plates, I would constantly wipe with alcohol. Then, after the plates were painted I sprayed a clear matte finish onto them. This way, when I applied them to the hull, my prints wouldn't get on them. After they were all applied, I sprayed them again. I suspect they will continue to age as I've read on this site. So, we'll see what happens!
Here are some pics:
Hi Ron, you are walkng down the road pretty fast.
Your copper plates are looking fantastic!
Cheers,
Udo
Current builds:
Le Coureur 1776 - CAFmodel 1/48
VOC Retourship Batavia
Boston Typhoon steam trawler 1/32
Research/Side Projects/On Hold:
H.M. Bark Endeavour
HMS Bounty 1787
Homer (or is it "Ron"?)
The copper treatment looks great! Using a ponce wheel to make the nail indentations is not only an excellent idea but also creates a scale & historically accurate plate. I've found two patterns for the nailing: 1) diagonal in the field surrounded by straight rows along the edges, and 2) many horizontal rows without a diagonal pattern. What reference would show the correct pattern for different periods of history? Thanks for the clear and in-focus pictures!
Bill
My library will never be complete, and my fleet will always be growing
  • 2 months later...
It's been a while since my last upload. Lots of things going on at home and I haven't been able to spend a whole lot of time on the ship. But here and there I squeeze in an hour or so.  I was able to spend half of today working on it and have some pics to share.
I finished with the copper plates and painted the balance of the hull black. I then sprayed a matte finish on it. Then I finished up most of the outside part of the stern and painted it.
I then finished installing the Waterway and Ceiling Planks. Admittedly, I struggled with the Ceiling Planks and had to use a little filler. I then installed the Log Rail and Top Gallant Rail. Again, I painted the exterior black.
I then installed the Lashing Rail and decided to paint the inside now so I wouldn't have to tape off or make a mess after planking the interior. Today I worked on the supports that will go under the coamings for the Hatches, Skylight, Steerage companion, Tryworks and Forecastle. I also installed the deck insert for the Windlass. If I recall, the width of the scrap wood used for the supports was about 1/4" wide.
I'll see if I can upload the pics to this work:
  • 2 months later...
I've been moving a bit slow on the Morgan build and haven't been able to give it as much time as I'd like. I've laid the deck planks, installed the pin rails and pins, cheek knees, head rails, billet head and have begun working on the deck fittings and the bowsprit. I will upload pics of the work completed to date.
Edited by homer
Hi Ron, just catching up with your build. Looking very nice. Brings back memories of when I was there. I'm enjoying your log, keep up the good work, it's good to see more people coming in to the "Morgan Club".
John
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Hi John, I constantly look at your web site as a resource and guidance. Currently I'm struggling with the anchor deck and wondering if the planks rest upon the  bowsprit? Also, I don't like the way my windlass break pump gadget came out! Where did you get the small square/rectangle piping? I haven't found it on-line and no local hobby shops, just Michael's and don't think they have it!
Hi Ron, sorry this took so long to answer. I was just checking your build log and found your post. My internet access lately hasn't been too good, so I've only taken care of business as I could. Hopefully I'll get this posted before I get bumped off the internet again. So far it's bumped me twice while I try to get this written. To answer your question, I had a piece of 1/16" square brass tubing I found in a hobby shop last year. The company that makes it discontinued it so I don't think any is still available unless you just stumble accross some. It bent well and soldered well. By the time I might get home in October and you haven't solved your problem I'll be glad to send you a piece that should be sufficient for you to make this piece. Hopefully, it won't be too late for you to make it the way you wish. I did not bring it with me unfortunately. I'll keep you posted as to when I might be home. Just let me know if you will still need it around that time. You might check with a model airplane RC type of shop and you might find some....don't know. Good luck. I'm currentloy building whaleboats along my travels. they're small and I have 7 of them to do so I can work on them in my RV or on the picinic table. I visited the Morgan a couple of weeks ago and took 400 more pictures which hopefully will be posted to my website in the next few weeks - again, dependant on internet connections. Hope this helps some.
Looking good -
John
John
I missed your question on the anchor deck. In real life, the anchor deck goes over the top of the bowsprit. Mine didn't fit, so I planked around it, then the Breasthook goes over that. Let me know if you need pictures as it is an area I re photographed, I also think I show this in my logs ( how I had to do it).
John
John
Thanks John! I made my way around it too. I should upload a few more pics of my build to date. Take care. Ron
I've been able to spend a little time on the build in the evenings. I completed the Tri -Works, Cooling Tank and Scrap Hopper. Didn't have any copper sheeting to make the cooling tank so I used card stock and painted it copper color and then used some aging powder to give it a bit of a dirty look. I need to change the chain attachment that is seen in the picture as it doesn't go well. I'll post my build pics of these below:
Looks great Ron. Outstanding job. I agree on the chains. Keep it up and keep posting pictures for us. Reminds me of when I was at this point...it is very rewarding.
John
Moving on, I built the work bench, chicken coop and the duck / water pen. I did end up cutting off one of the handles on the grinding stone. I also attached the vice to the work bench but don't ask me why I painted it Red! I also thought it would look better if I made one of the work bench drawers in the open position. I'll post these pics below:
Edited by homer
Then I started working on the Main Hatch, the chain Bitt and the Fife Rail etc. One of the two metal bilge pumps was broken in the package before I opened it. I know ModelExpo would replace it but I decided to use part of it, solder on another piece then mount it onto the pad below the fife rail.
I just went to upload the pics of this and realize I didn't take any pics!! I will snap a few and upload them shortly!
Edited by homer
Then I started on the Sky Light. Admittedly I struggled with this and was sort of happy with the end result. Fortunately I didn't glue it down onto the deck. The more I looked at it I realized it was out of scale and I just wasn't happy with the brass wire / rods. It looked sloppy to me. So, I tried several different ways to accomplish the build. There are pis in other build logs but none that really showed how they built it. My third try I decided I would build the panels separate then set it into the Proxxon X/Y and utilizing the vice to hold the panel as I drilled the holes all the way through. But first I painted the panel and then drilled it. I know the plans call for the rods to be yellow but I wanted to keep them brass. The whole thing went together well until I sat back and looked at it and one of the top panels is not straight. At this point I'm fairly frustrated and have to decide if I will use it. It's just sitting on the deck and not glued down at this time.
I then installed the rudder and steering wheel assembly. I'll post pics of where I'm at below. I may start on the deck houses and think further about the sky light!! I'll post pics of the first one and the one I just finished. The last pic in the series below is the first one I built.
Also wanted to add... the Proxxon tools sure work well. In fact, I just ordered the Proxxon lathe from John who sells Proxxon tools. He has a web site and his email contact is " texxn5@gmail.com ". He is building the same ship and his web site details his entire build. It's been a great reference for me and he's a pretty nice guy. He put a special combo deal together for me!
Hi Ron, thanks for the "plug" - greatly appreciated....just a slight correction, my email is texxn5@aol.com or texxn65@gmail.com for anyone interested. I'm glad I've been able to help and that is why I did the website as about 30 pages or so of pictures posted on MSW were lost in a glitch a few months ago. My website is complete and up to date with many more pictures and explanations of my procedure. Not perfect by any means but at least a good reference. Thanks again, my friend. Your build looks fantastic.
John
Edited by texxn5
John
By the way, the skylight was the most difficult item to build on the Morgan for me. Keeping it small enough to stay in scale was a real pain as was the brass bars. I had to rebuild mine too since my first one was too big. It also took a lot of hours that were wasted or should I say "good practice for the next one". I hate being politically correct ---actually it was a real pain in the a$%...lol Clamping it in the x-y table is the only way to accomplish it, and the basswood is not forgiving like a hardwood would be. It kept splitting and breaking at every opportunity. Good job!
John
Sorry for the multiple posts, but I keep thinking about things as I observe your pictures. If the height and width are correct, the side with the crooked brass rods can be put under the Hurricane house and won't be seen. Don't glue it in place until you finish the Hurricane House and you will be able to place it where you need it as well as see how it looks to scale. Just a thought.
John
John, I did think about that and planned on waiting to glue it down until I got the hurricane house and overhang in place. I've also considered taking part of the sky light apart and replace the crooked piece. But, with that in the risk of destroying the rest of it. So, i'm going to just set it aside for a little while and we'll see how it pans out!!  Thank again for helping with the Proxxon order!
Your model of the Morgan looks great. If you need reference pictures I have thousands if you want. most of what I take are with modeling in mind. I worked on the last restoration in the rigging loft... also got to man the helm under full sail for a half hour on her 38th voyage. anyway my bragging aside.. I would be more than willing to send you any pictures that you might want to do your model. I have all aspects of the restoration at your disposal.. ask john about me...my email is lesterpalifka@gmail.com  email me anytime.. ui am going to get back on my morgan as soon as I finish my whaleboat.. hope to hear from you....
Lester
