Everything posted by James H
Electric Plank Bender Hobbyzone Catalogue # HX-GDL1 Available from Hobbyzone for £20.63 (as of 10-7-18) There are numerous ways of bending those awkward planks that we regularly see at stern and bow, including soaking in water/macerating fluid that breaks down fibres, and then twisting. You can of course use a plank nipper, such as that from Amati, drum roller such as the Mantua release, or you can use an electric plank bender. The latter isn’t exactly a new way of shaping your planks to the required curve, but this new release from Hobbyzone is certainly a quality and affordable way to achieve it. Hobbyzone’s electric plank bender is packed into a sturdy plywood box which is then heavily wrapped in plastic film onto which the product label is affixed. Once the packing is removed, the lid of the box is lifted via a finger hole in the centre of the lid. Inside, we have the electricplank bending tool itself, lying alongside the curved forming tool. The electric part of this is a 240v unit and comes with a European standard 2-pin plug. For my tests, I converted this with a 3-pin UK travel adapter. I think that the basis for the plank bender is possibly a soldering iron or similar, but instead of a pointed tip, this unit has been fitted with a circular brass head that is the correct size to roll around the smaller of the curves on the forming block. Inside the bottom of the box is a sheet that explains that your planks must first be soaked, and that you may well experience some smoke emanating from the unit for the first 10 minutes after the very first use. Note also that the underside of the lid has a rest for sitting the electric tool whilst not in use. *CAUTION* NEVER LEAVE THE PLANKIG TOOL UNATTENDED WHILST POWERED**….simple safety tip! The forming tool is made from very thick MDF and contains two different sized scoop profiles, plus a gentler curving sweep. You can of course use different sections of these profiles to greater or lesser degrees, and it does seem very similar to the formers in other manufacturer’s products. To test, I first soaked my limewood planks for about 30 to 40 mins in plain cold water, and then with the forming iron fully hot, the plank was laid across the shallow curve and the iron gradually rolled into it. The timber formed itself into the curve very quickly and with minimal physical effort for me to achieve it. The tool was gradually rolled until the wood dried out and the curve remained. For the deeper curves, I first placed only a short length of the timber into the former, and then rolled the iron, pushing the timber into the former a little extra each time until I had achieved the full curve. I did experience a little scorching on the internal area, but nothing too major. I think that longer soaking for more pronounced curved would minimise this even more, but the plank shaped superbly. Resting the iron, whilst hot, onto the stand, caused almost zero scorching from the iron, so I have no qualms about using the stand for just that. Conclusion A superb tool at a very reasonable price. This currently retails for just over £20, minus shipping, and is very easy to use. The whole lots packs neatly into that plywood box too, so no loose tools lying around. I couldn’t see a wattage listed on the unit, and I don’t think this is currently available in anything other than 220/240v, but it could be worthwhile approaching Hobbyzone to clarify that.
Not at all because it will be written by individuals and not on behalf of MSW.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Before any planking can be contemplated, those bulkheads need to be faired in. This is probably one of my least favourite jobs, but at least with the Drakkar, it's not too big a task. To do this, I use a coarse sanding stick. This has some flexibility and curves nicely to the shape of the hull. I think this was about 2hrs work in total. A plank of Lime from my Mary Rose kit was used to check the curves all around the hull and to highlight any areas that weren't sanded enough. There are two sheets of planks for this model, one for port and one for starboard. There is a difference in the sheets as one plank for the starboard side has a riser for the rudder attachment. Using the plans, each plan was numbered and then an arrow added to indicate the bow. The planks on this model are all pre-shaped and laser-cut from very, very thin ply. If the fairing isn't done correctly, then the planks will look wavy. This was my worst fear with this model. First of all, the two inboard planks have a slight bevel added to the inner edge so that they mate up properly to the keel. Each of the inboard planks are now fitted using III and some very careful measurements to ensure the are the same on both sides. Some shaping of the ends had to be done so the planks matched the curve that had been drawn on the keel previously. Adding one plank per side and alternating each side as I went, the first four per side were added. Now, I know many don't like CA (superglue), but it's ideal for spotting things into position before proceeding with wood glue. If measurements are out, then the CA joint can be cracked apart and re-positioned. With the first four in place, I painted the interior of the hull with wood glue to strengthen it. I hope to have all planking done for the next update and then to look at fitting the decks.
Lovely work. Can't wait to start mine.
- 103 replies
- queen anne barge
- Syren Ship Model Company
Nice to have you with us, Ron. Paper, wood, whatever....please share your work with us.
Amatis Orient Express Sleeping Car - Unboxing
James H replied to greyhawk's topic in Non ship-related reviews
Nice video and a lovely kit. Mine arrived today too. -
Waterline Marker Hobbyzone Catalogue # HZ-PW Available from Hobbyzonefor 25.00zł (£5.21 as of 6/6/2018) If you’re new to the hobby and setting up a list of essentials for purchase, or if you need to replace your current waterline marker for some reason, then Hobbyzone has a pretty inexpensive way of doing this. In case you’ve never heard of Hobbyzone, they are a Polish company who produce some excellent workshop workbench modules to store your tools and other items, all with magnets which lock the individual units together. This range is totally flexible and can grow as your own needs must. Maybe you have heard of Hobbyzone but didn’t realise that they now have a set of products aimed specifically at our hobby? For our first look at this range of tools, I thought the waterline marker was a good introduction. Hobbyzone products tend to be made from MDF parts, which are CNC routed to very fine tolerances, which fit superbly. I can say this because I have been a customer of them for about 3yrs now. The waterline marker is packed into a clear plastic sleeve wrap with a couple of product labels. Opening the packet, you’ll note that all MDF parts are held together with elastic bands. A packet of hardware is included, as is a single instruction sheet. No tools re needed for this except for clamps. Clean-up of parts isn’t necessary. A quick test fit of parts shows that everything does indeed fit snugly, with just a little playfor the glue joints. For glue, I use Titebond III which has a relatively quick grab time and sets with an amazingly strong joint. I first glue the two upright parts together and leave for 15 minutes before then gluing this assembly to the base. Any excess glue is removed with the corner of a steel rule. One of those upright parts has a channel milled into it for the pencil unit to slide along. Assembling the pencil holder is very simple indeed. Two MDF parts are supplied, and one of these has a V-channel machined into it for holding the pencil, and holes for the bolts. The other part has those holes, but the exterior is machined to accommodate the hex head of the bolts. The bolts are first slotted into this piece and the v-slot dropped into position. The two parts are now fitted to the slot on the upright assembly and the washers and wingnuts used to secure. Before tightening, a pencil is added to the unit, and the wingnuts tightened evenly. It’s a good idea to use a short pencil for this as you want to keep the waterline parker relatively close to your boat/ship so that there’s no flexing of the pencil. That’s it! This tool can be adjusted for heights between 45mm and 225mm, so certainly big enough for most applications. Another real bonus here is the price. At just over a Fiver sterling, then this can’t be beat! My sincere thanks to Hobbyzone for kindly sending out this item for review here on MSW. Hobbyzone products can be bought directly or through one of their global distributors. Tell them you saw this review on Model Ship World
What a great looking little boat. I love that planking.
- 216 replies
- masterkorabel
- ships
(and 3 more)
That looks just amazing. I'd have loved to have seen it commercially available.
- 128 replies
- mordaunt
- battle station
That is very, very pretty. Lovely workmanship too.
- 216 replies
- masterkorabel
- ships
(and 3 more)
As promised, here's the start of my build. The weather here is way too hot for me to do my usual airbrushing of plastic models, so it was just the opportunity I needed to crack open this lovely kit, from Amati. First of all, I removed all of the parts from the thick ply sheet. These parts are the keel, bulkheads, dragon head mounting post....and a part not on the schedule. This is a replacement for the curved tail. The original keel has quite a simplified shape which is a little unsatisfying, and instead of reworking the keel, Amati has included a reworked section for the modeller to use, should they wish. As this is heaps better than the keel shape, I carefully marked out the new joint onto the keep and then sawed off the section. The new shape was now grafted into place with Titebond III adhesive. Here are the bulkheads. These will of course need fairing slightly when fitted. Notice how the middle frame #6 has a stepped profile to aid locating the shaped planks. There's no real need to remove the char from any of these edges. After test fitting the bulkheads to the keel, it became obvious that the joints were way too tight. To correct this problem, I ran a coarse sanding stick a few times through the slots on both the keel and the frames. As the stick is slightly spongy and will compress a little, it only took a few seconds to remove the required amount of material. Before I can fit the bulkheads to the keel, I needed to draw the line on the keel to where the planks would terminate. Amati suggests tracing the shape from their lower half of their plan sheet, containing a keep profile. As this was only a parts list section, I cut the shape from the plan and transferred it to the keel where I then used a pencil to draw around the paper template. I found the stern keel to differ very slightly from the shape of the plan, but it didn't present any real issues. Each bulkhead, except for #2 and #10 were now glued into position using Titebond III aliphatic adhesive, along with the dragon's head mounting post. The reason I left the two bulkheads unglued is because these will need most shaping as the planks sweep steeply upwards here. They will be rigid enough to be faired with the other bulkheads, but allowing me to remove to finely tune them. At this stage, note the tops of the bulkheads aren't flush with the keel. This doesn't matter, as confirmed in Amati's instructions, as the deck more or less sits on top of the bulkheads and not the keel itself. One thing I noted was the curved notches in the two false deck sections. These needed to be squared off so they would sit to the frames properly. I now sit the two decks in place, temporarily, whilst the bulkheads set. A quick check proves that assembly is nice and square. More soon as I then fair the bulkheads in readiness for planking....
1/2” Scale Queen Anne Style Royal Barge 1705 Syren Ship Model Company Catalogue # SKU QABK01 Available from Syren Ship Model Company for $225.00 A royal barge is a ceremonial barge that is used by a monarch for processions and transport on a body of water. Royal barges are currently used in monarchies such as the United Kingdom, Sweden and Thailand. Traditionally the use of royal barges was of high importance in southeast Asian monarchies such as Siam, Burma, Brunei, Riau and Cambodia. The River Thames in London was a regular thoroughfare for the Sovereign until the middle of the 19th century, on state occasions or between the Royal Palaces of Windsor, Westminster, Hampton Court, Greenwich and the Tower of London. In the UK, there is currently no State Barge in active service, but until 2017 the Royal Nore, owned and maintained by the Port of London Authority, was used whenever a member of the Royal Family travelled on the river Thames for an official engagement. Royal barges are typically elegant in style, and those built in the period of Queen Anne were still striking, despite their relative simplicity in relation to other vessels of the same stature. Resplendent in ornate carvings and decorative panels, these barges provided a comfortable and stylish method for the monarch to move between their residences and their courts. Edit courtesy of Wikipedia The kit This is my first experience of dealing with Syren Ship Model Company, and of course, the Royal Barge kit is designed and produced by them. My kit took around 9 days to reach UK shores from New Jersey, via USPS and Royal Mail. Of course, I got hit by the obligatory import duty, but it wasn’t too bad. After paying their ransom, I picked up the package a couple of days ago and now spent some time flicking through the contents. The kit itself is packaged into an extremely sturdy corrugated cardboard box with tabs that release so you can flip up the lid. With the lid open, the plans are the first thing seen, and these are gently curved over the components underneath, along with a contents checklist which has been manually marked to show the contents are indeed in there. A nice system that gives peace of mind to the buyer. I’ll look at the plans further down the review. With these lifted out, some very soft packing foam is included so stop the contents rattling about. Inside the box, there are two robust clear sleeves which contain all of the timber planks, three narrower sleeves with strip and dowel, a card box with resin, wood, wire and black fishing line, a length of thick black cartridge paper with laser-cut elements, a packet with friezes for the interior of the barge plus some decorations for the sweeps, and two flags. Onto the sheet timber. Syren has produced all of the main parts from a superbly milled cherry wood, and the finish is silky smooth. The quality of the wood is also amongst some of the best I’ve seen since I started in this hobby almost 20yrs ago. The colour, which I hope I’ve captured in most of my photos, is a very pale golden colour which looks quite muted. The grain, as you would expect, is very fine. Laser-cutting quality is also on a par with the best kits I’ve seen, with almost zero heat effect, and small tags that only just hold the parts in position. Edge scorching is also very minimal, and it’ll only take a few swipes with some sandpaper to remove them totally. You will of course need to do that thoroughly as this model is only partially planked, as it the style of barge models of the era Circa 1700. Cherry was also chosen because it best replicates the colour of the wood used on these models and allows the kit to be affordable too. Also among the thicker sheets of cherry wood is a two-part building jig which needs to be assembled. The zig-zag edging of this will make the job easier. Each frame slot is also numbered so there’s less chance of human error. When the model is later released from this jig, it will be modified to accept the keel for the remaining construction, using more supplied parts. This is probably the time to explain roughly how this model actually does assemble, and I’ll add a few images here to illustrate things. Each of the frames has an infill piece still attached, and this is what will slot into the building jig. When the outside planks are added, this can later be carefully cut away to reveal the interior of the barge which then needs to be fitted out. Before slotting those frames to the jig though, you will need to add the floor frames. The position for these is finely engraved onto the waste material within each frame. You can use a straight edge along this and then fit the floor frame up to this mark. This way there’s no reason to use pencil on the parts faces themselves. This technique is superbly illustrated here by Rusty, in his MSW build log: https://modelshipworld.com/index.php?/topic/17889-queen-anne-barge-by-rustyj-syren-ship-model-124/ Looking at the timber, you can see that just about every shape is either cut with laser or engraved for reference. All planks for this are supplied spiled, need bevelling from the laser-etched line. These planks are supplied in suitably thin sheets of cherry, and for extra clarity, each sheet is labelled PORT or STARBOARD. The keel is built up from scarfed sections, as the real thing would be. Very impressive. The rabbet is created my inserting thinner keel parts on the inner edge of the keel, creating a recess into which the limited planking will sit. When it comes to the thwarts, these are also laser-engraved to create the stepped edges to them. Also included with the laser-cut parts are the mounting pedestals (you just need a nice piece of polished/varnished timber to use as plinth), and also the sweep (oar) racks so those can be decoratively mounted on the plinth, adjacent to the barge. Now, this model has some ornate and intricate carvings adorning it and these are provided as laser-cut items for which you can try your hand at carving. Does that sound scary? If so, don’t worry because also available for this kit is a set of resin-cast carvings which are more or less all ready to be attached and provided as an upgrade set which you can buy either at the same time as the kit, or later if you struggle with the boxwood blanks. The resin parts are supplied in a small white box to protect them. With this sample, they were supplied directly in that small box that sits within the main package, and the extremely delicate filigree parts were packed into two zip-lock wallets. Very little clean-up is required with these, and to give them a nice natural appearance, weathering powders are suggested. You can also airbrush them and apply an enamel-based wash which would bring out the details superbly. It’s all a matter of preference. These carvings include the scrollwork for the port and starboard side, the quarter-based figurines and the Royal monograph. They really are superb to look at. Other parts were included inside this box. These include some extra boxwood parts for things like the internal panelling that the friezes will sit within. Extras are included in case you screw up. There is a length of wire and also some black 20lb fishing line that you will use to simulate the black nail heads on the planking. A length of resin-impregnated black card is also to be found in this kit, and like the timber, all parts are laser-cut. Parts here are provided for the keel banding and rudder straps etc. Three sheets of colour-printed paper are included that hold the parts for the friezes and the ornate decorations for the sweeps. These will need to be carefully cut out with a fresh blade and then attached to the model using a very dilute PVA or children’s glue stick. Two period flags are also included, printed on thin tissue paper and with good colour definition. Note the union flag, minus the diagonal red cross, which is of course accurate for 1705. I’m presuming the quadrant flag is either of the period or even related to the monarch of the period. It should be quite easy to make these drape realistically due to the thinness of the paper. Certainly easier than some of the materials some companies use for their flags. Two large plan sheets are included, clearly depicting construction in clean line drawings, and of course, the images are at full scale for any measurements you need to take. Please note that no instruction manual is included with this release as it helps to cut down on price. It also helps reduce weight for shipping. There are three manuals for this, in full colour PDF format, and these can be downloaded from the Syren Ship Model Company’s website. These are extremely comprehensive and beautifully describe the whole build process, including hints and tips for your project. Conclusion I’m not usually the sort of guy who gets enthused by barges and narrow/longboats etc. but the sheer beauty and ingenuity of this kit appealed to me instantly and I followed the kit development here on MSW. The kit is just exquisite, with beautifully milled timber and laser-cut parts, printed materials etc. The construction process has been made as easy as possible at every stage of construction with such things as the laser-shaped thwarts and planks that have been spiled ready for you to shape. An amazing kit, intelligently designed, and with the very best in materials. Syren has this model on sale for $225.00 and I think that represents excellent value for money for what will give many hours of building pleasure and a real ornate stunner for the display shelf! My sincere thanks to Syren Ship Model Company for sending this kit out for review on Model Ship World. To purchase directly, click the link at the top of this article.
- 1 reply
- queen anne barge
- royal barge
kit review 1:70 Hannah - Ship Model Okumoto
James H replied to James H's topic in REVIEWS: Model kits
You're right. My terminology is awry! -
Looks like another one I must add to the collection.
- 421 replies
- medway longboat
1:70 Hannah Ship Model Okumoto Catalogue # Available from Ship Model Okumoto for ¥ 33,000 (approx. $290) The schooner Hannah was the first armed American naval vessel of the American Revolution and is claimed to be the founding vessel of the United States Navy. She was a fishing schooner owned by John Glover of Marblehead, Massachusetts and was named for his daughter, Hannah Glover. The crew was drawn largely from the town of Marblehead, with much of the ships ammunition being stored in Glover's warehouse now located at Glover's Square in Marblehead before being relocated to Beverly, Massachusetts. The schooner was hired into the service of the American Continental Army by General George Washington. Washington commissioned Nicholson Broughton to command the Hannah on 2 September 1775 and ordered the vessel to, "...cruize against such vessels as may be found . . . bound inward and outward to and from Boston, in the service of the [British] army, and to take and seize all such vessels, laden with soldiers, arms, ammunition, or provisions . . . which you shall have good reason to suspect are in such service." Hannah set sail from the harbour of Beverly, Massachusetts on 5 September 1775, but fled to the protection of the harbour of Gloucester, Massachusetts two days later under the pursuit of HMS Livelyand a second British vessel. Leaving Gloucester Harbour, Hannah captured HMS Unity. Hannah's brief naval career ended on 10 October 1775, when she was run aground under the guns of a small American fort near Beverly by the British sloop Nautilus. After a 4-hour engagement between the British ship and Beverly and Salem militias on the shore, Hannah was saved from destruction and capture. According to legend, soon after Hannah's decommissioning, the schooner was towed to Lee's Wharf in Manchester, where its name was changed to Lynch. There, the vessel was restored to working condition by 7 carpenters over the course of 3 weeks. In March of 1777, Lynch was sent to France with congressional correspondence for Benjamin Franklin, who was there as U.S. Ambassador. Upon embarking on their journey back to the U.S., Lynch and its crew were captured by British ship HMS Foudroyant. Lynch was sold as a prize by the British and documentation indicates that the schooner was used as a merchant vessel thereafter. Edit courtesy of Wikipedia The kit Hannah is the fourth release from Ship Model Okumoto and has only been on sale for a week or two, so my thanks to those guys for getting this out to me from Japan so quickly. According to their website, this is the kit specification: Scale: 1/70 Total length: 335mm Height: 90mm Width: 100mm Wood: Agathis Build time: 100 hours Parts count: 310 laser-cut parts, dowel As with my previous reviews for La Couronne, Endeavour and Santa Maria, this kit is packaged into a transparent, lockable box. However, this one is smaller, and our postie actually managed to pop it through our letterbox! As well as being smaller in general size, it’s about half of the depth of the previous releases and has some separate green plastic locking clips to hold it together. Inside, we have eight sheets of laser-cut Agathis wood, a small bundle of dowel, plans, instructions and a parts list. A hallmark of Okumoto’s kits is the very low scorch that results from cutting via laser. You can see that very little heat has crept into the area adjacent to the cut, and there is no discolouration of the parts. A simple clean-up of the edges is all that’s needed, so remember to do this to each inner frame edge and component before assembly. All parts are also nigh-on cut through in their entirety, so lengths of tape have been attached to the rear of the sheets, holding each part securely in place. Removal of the parts shows that no sticky residues are left behind either. As with the other kits, there is no part nomenclature on the sheets, and you need to refer to the paper plan sheets to identify each component. There is a little laser etching on each sheet which indicates the sheet number, for reference, and also the sheet thickness. Timber quality is excellent, with the Agathis being very fine grained. This should be nice and easy to work with, and you shouldn’t get any splitting etc. The slightly golden colour is also very attractive. Note that whilst these kits are POF, there are some simplifications in their construction. For example, these models don’t have cant frames. However, each frame is constructed from a number of individual components that would be similar to the way the actual ship frames were constructed. A small bundle of short dowel lengths concludes the timber items in this kit. Underneath the colour image of the completed Hannah, lies a profile plan that’s roughly A3 in size. This contains a port elevation as well as a partial upper and lower plan. Annotation is in English. We next have three sheets that contain the parts maps for the eight sheets of timber supplied. These are exact duplicates of the timber planks with regard to layout. Now, unlike the previous Okumoto releases, this one has a far more comprehensive instruction manual, again making this an ideal introduction to POF. Twelve sheets of paper are printed double-sided and stapled, creating a 24-page manual. Whilst this is still in Japanese, the photos are very good at explaining the steps. You can also use a smartphone app, such as Google Translate, so scan the text and convert it in real time. Lastly, a series of sheets are included which show the frame and detail assemblies. For the frames, you simply put these together over the top of the printed paper, after applying a little wax, maybe, to prevent the timber from sticking to your plans. Conclusion Out of all the Okumoto kits now on sale, Hannah has to take the place of Santa Maria as the first one that a newcomer to POF should tackle. Whilst Santa Maria is a beautiful and relatively uncomplicated in comparison to La Couronne and Endeavour, I feel that Hannah is well-pitched in complexity and price, to possible be the first POF from Okumoto that you consider due to its straightforward design. It’s worth noting that despite being an easier build subject, it still has almost twice the number of parts, according to their website, than Santa Maria. It’s also a little gem with its length of just over one imperial foot (13 inch, 335mm). A superb project that will look perfect on the mantlepiece and one that also won’t break the bank. Estimated building time is around 100hrs too. Please let Ship Model Okumoto know that you saw this review on Model Ship World. My sincere thanks to Ship Model Okumoto for sending this sample out for review on Model Ship World. To purchase directly, click the link at the top of the article.
What a great job. I hope mine is half as good.
- 120 replies
- queen anne barge
1/80 Santa Maria Ship Model Okumoto Catalogue # SM-SMO-K80 Available from Ship Model Okumoto for ¥ 39,960 La Santa María de la Inmaculada Concepción (Spanish for: The Holy Mary of the Immaculate Conception), or La Santa María, originally La Gallega, was the largest of the three ships used by Christopher Columbus in his first voyage. Her master and owner was Juan de la Cosa. Santa María was built in Pontevedra, Galicia, in Spain's north-west region. Santa María was probably a medium-sized nau (carrack), about 58 ft (17.7 m) long on deck, and according to Juan Escalante de Mendoza in 1575, Santa Maria was "very little larger than 100 toneladas" (about 100 tons, or tuns) burthen, or burden, and was used as the flagship for the expedition. Santa María had a single deck and three small masts. The other ships of the Columbus expedition were the smaller caravel-type ships Santa Clara; one particular ship sailed for 46 years and was remembered as La Niña ("The Girl"), and La Pinta ("The Painted"). All these ships were second-hand (if not third- or more) and were not intended for exploration. Niña, Pinta, and the Santa María were modest-sized merchant vessels comparable in size to a modern cruising yacht. The exact measurements of length and width of the three ships have not survived, but good estimates of their burden capacity can be judged from contemporary anecdotes written down by one or more of Columbus's crew members, and contemporary Spanish and Portuguese shipwrecks from the late 15th and early 16th centuries which are comparable in size to that of Santa María. These include the ballast piles and keel lengths of the Molasses Reef Wreck and Highborn Cay Wreck in the Bahamas. Both were caravel vessels 19 m (62 ft) in length overall, 12.6 m (41 ft) keel length and 5 to 5.7 m (16 to 19 ft) in width and rated between 100 and 150 tons burden. Santa María, being Columbus' largest ship, was only about this size, and Niña and Pinta were smaller, at only 50 to 75 tons burden and perhaps 15 to 18 metres (49 to 59 ft) on deck. Extract courtesy of Wikipedia The kit This is the last of the first three ships that I have received for review here on MSW, until I receive the new release, Hannah, in the next week or so. Out of the initial three, this is the simplest of them all, and the least expensive, producing a nice rendition of a POF version of this legendary little ship. As with all Okumoto releases, this one again is packaged into a lockable, clear plastic box through which you can see the contents. Okumoto’s stats for this kit are as follows: overall length: 378 mm height: 139 mm Width: 103 mm Wood: Agathis Build time: approx 120 hours, laser-cut parts: 173 This kit has notably fewer planks within, with there being a dozen sheets of laser-cut Agathis wood, compared to double that of the Endeavour kit that we recently reviewed here on MSW (see end of article for links). Fewer sheets of timber of course yield fewer parts, with there being less than a third of the Endeavour, and a total of just 173. The model, whilst of the same scale as Endeavour, has a total length of 378mm, so in itself, is still a very reasonable size for display in a cabinet or on a mantlepiece etc. Looking at the various sheets, it is obvious that any scorching that inevitably results from laser-cutting, is at an absolute minimum as there is very little local heat transfer shown on the wood, and this is clearly seen in the photographs. Indeed, releasing a small number of parts from the Endeavour kit showed that the edges of the parts only seem to be a slightly darker brown, and this will be very easy to sand back to the nice bright timber colour underneath. Agathis wood can be cleanly cut with a knife when it comes to making any parts adjustments during construction, and the fine grain means that you shouldn’t experience anything untoward such as splitting or feathery edges when finishing the model. All parts are retained within their planks by the use of tape which holds things in position on the rear of the sheet. Removing the tape leaves no sticky residues either, and the parts will be ready for construction almost instantly. As no parts numbers etc. are etched to the sheets, for obvious reasons, you will need to reference the sheet against a paper parts plan. The sheet is easily recognised as each is etched with the sheet thickness and number. As per the real vessel, each frame is constructed from a number of timber parts, and these are built up over the frame plans which you should first smear with wax or cover with grease-proof paper so nothing unwanted sticks to your completed assemblies. You will note that not only are the regular frame parts etc. included, but also the strip wood, finely cut by laser. Be careful with these parts as they could well be fragile. To complete the timber contents, a small bundle of dowel is included for mast stubs etc. A colour-printed sheet showing the completed Santa Maria sits on top of the kit’s paper contents and provides the box-artillustration for this release, seen through the clear plastic container. Underneath this an A3-size plan lurks, with starboard and top-down views of the ship, clearly showing the main timber placements. Annotation is in English. Three pages are now included for the instruction/assembly sequence sheets. At the moment, these are supplied in Japanese only, but Okumoto tell me they will eventually provide these in English language text too, opening up their market possibilities. For the time though, you can use a phone app to translate in real time, such as Google Translate, that shows you the English equivalent when you hold the camera over the Japanese text. Four sheets of paper now include a parts plan for all of the sheet timber, providing easily referenced information when you come to locate specific elements for your build. The majority of the paperwork in this release provides plan layouts for the many frames in this ship. These are built directly over these sheets, and the frames are clearly numbered and identified. A handful of last sheets provides drawing data for specific elements of construction, with all annotation supplied in English. Conclusion I feel that this kit could be an ideal first introduction to a POF model, as it’s definitely less complex than La Couronne or Endeavour, and with a lesser parts count. General assembly looks easier too, but still maintains the overall busy look of a more complicated model. You’ll note that Santa Maria only has single frames and not the double of the previous releases, of course cutting down in the required number of timber parts. Production is excellent with cleanly-cut laser parts with hardly any charring, and a clear set of plans. The only drawback, at the moment, are the Japanese instructions, but that is easily overcome if you purchase now, and then there will be the English sheets which Okumoto will add in the future. In all, a very pleasing looking model and one at a size that will nicely fit in a small display cabinet. Give it a go!
Requesting feedback for future MSW Group Projects
James H replied to Chuck's topic in Group Projects on Model Ship World
I think 'sails' would be a much needed and appreciated addition. -
Just ordered my barge kit, so watching this with interest. Loving your progress so far.
- 120 replies
- queen anne barge
