Everything posted by James H
tool review Photo Etched Parts Bender
James H replied to James H's topic in REVIEWS: Model Shipwrighting Tools, Parts and fittings
There is a video of one being used here: -
I'll do a few photos on an upcoming project for you. -
Photo Etched Parts Bender DSPIAE Catalogue # AT-PB Available from Breveco Modelling for €69.50 There are some really good photo-etch bending tools on the market, with my personal preference thus far being the 5.5 inch Hold and Fold from The Small Shop. I’ve used numerous different folders over the last year, some being good and some being a little iffy, in my personal opinion. I suppose it was only a matter of time before Chinese tool manufacturer, DSPIAE, released their own into their high-quality tools range, and here is that very tool. DSPIAE tools are packed into robust and attractive boxes of MDF construction, with rather random Aztec-style imagery that really doesn’t bear any relation to the product within. Still, there’s no faulting the presentation, along with the excellent packing that can be used to safely store the tools for many years to come. The box states that the contents within, or at least some of them, are a result of high-pressure forging. The box sides show the parts included within the tool set, plus the ID Code used to identify this as a genuine DSPIAE tool and not a pirated copy, with this latter being something that even the respectable Chinese companies have had to do to separate themselves from their more unscrupulous countryfolk. Taking a look at the back of the box, we see some general product information and rationale for specific product design choices. Got to love the inclusion of the Ghostbusters logo! Lift that heavy lid and you’re already getting a thank you from the company for your tool purchase decision. Another product authenticity check is included in the form of a Q-Code that can be scanned with an appropriate app on a smartphone. This red packaging is actually a sleeve that contains one of the tools working tables, as named by the manufacturer. Yes, this PE bender has a choice of two working tables, and the one in this sleeve is manufactured from a shot-blasted piece of anodized aluminium that has a sort of graphite colour to it. This is also protected by a foam cut-out within the sleeve. On the rear of the sleeve is a little more of the same product information we saw on the rear of the box, alongside line drawings of the product. One thing that can never be criticised with DSPIAE is their packaging. The tool and parts within the box are sat in foam cut-outs with another insert being used to span the area between the bending plate release knobs. A silica gel sachet is included to prevent any moisture damage. With other PE benders, I’ve been used to a metal blade to assist folding any of the longer bent edges. Unusually, with this tool, the folding tool (or bending plate as described by DSPIAE), is constructed from clear acrylic sheet which has been neatly and evenly ground down to a wedge end, and with a black plastic cap strip along the other edge. In fact, they actually supply two folding tools here, with one of them being quite short in relation to the main folder. It remains to be seen how these bear up to continued use as opposed to a metal item but remember that it’s not much effort is generally needed to make these bends, and you aren’t pushing and grinding these parts together. More rationale for product design is also given on a foam insert, and also some information on how the tool is used. Time to get our hands dirty and take a closer look at this. No doubt, this tool must surely win a prize for the most beautifully finished and aesthetically pleasing tool that will end up on your workbench. The main bed of the PE bender is machined from high-grade aluminium which has been finished in black anodising and has a recess into which the switchable working tables will fit. Four hex-key screws hold the default working table in place. Unlike the shot-blasted, anodised aluminium plate that was packed into the sleeve, this plate is constructed of stainless steel and has a high mirror finish that was a little difficult to capture clearly in my photography. The bending face is constructed from more high-grade aluminium, this time anodised in the companies trademark red colour. This has more bending options than my default 5.5inch Hold and Fold, with the various shaped being precisely machines, as with the US-equivalent tool. Two knurled knobs hold down this pate onto the working table, with the plate itself being sprung-loaded. The being plate can also be lifted off and turned around 180 degrees so that the long straight edge is the principle bending face. This unit is also larger (and heavier) than my usually tool. The larger size does account for that generally, but the stainless working table adds to this, unlike my usual tool which is simply a two-part item which is also sprung-loaded. DSPIAE’s tool has a length of 177mm and a width of 91mm. Note here the smaller machined bending locations that can be used in conjunction with dowel or metal rods/drill shanks. A hex key is also supplied for you to tighten the threaded knob screws, should they ever come loose. Here you can see the difference in the working tables. There is some notation about the mirror finish being easier to scratch (obviously) but that won’t impair the quality of the tool and how it works. I think the choice between these two items is more one of personal choice than how the tool actually works. If you ever inadvertently damage one of these, then at least you’ll have a backup. To help maintain that mirror finish and keep things clean, a neat polishing cloth is also included, as are a set of sticky feet made by 3M. In the same wallet are the two hex-keys that we’ve seen in use in this review. Aluminium or mirror-finished working plate, the choice is up to you! Here you can also see the bending face turned around 180 degrees. Conclusion An extremely robust and high-quality tool with unusually high levels of beauty for a functional item. The two choices of working table are a nice touch, and the large overall size of the tool lends itself to some of those longer folds that we something see in our photo-etch parts sets. It’ll be interesting to see how the acrylic folding tools hold up under use, but these can be swapped for something else, should the need arise. The folding tool I got in my 5.5inch Hold and Fold eventually started to rust, so that wasn’t perfect, and I really didn’t want to look at introducing oil to things, especially when I have to paint the folded parts later! Perhaps acrylic is an inspired choice in that respect. Overall, a stunning new release from DSPIAE and one which, cost-wise, is about on par with other contemporary releases from other companies, but with those little extras thrown in for good measure. Very highly recommended. My sincere thanks to Breveco Modelling for the sample seen in this review. To purchase directly, click the link at the top of this article.
kit review 1/72 HMS Vanguard 1787 - Victory Models/Amati
James H replied to James H's topic in REVIEWS: Model kits
I look forward to that! Welcome to MSW also- 18 replies
- victory models
- elephant
(and 3 more)
Bounty is often showed with blue painted on the hull sides, and yellow. By demarcation, I mean how this was painted and to what extent, and also which particular colours would have been used for the time?
Thanks guys, This is very useful. Can you identify things such as mast colour, hull demarcation and colours used? Is there something which is usually regarded as reliable in this respect? Thanks, Jim
Hi all, I thought I would seek the knowledgeable counsel of the good folks on MSW for this. Can anyone give me a good indication as to the actual finish of Bounty? (hull, masts etc.) and colours which would be close? Are there any contemporary prints which are considered more accurate in terms of how she actually looked? It's pretty important that I get the information as close as is possible, allowing for the relative lack of technical info available. Thanks, Jim
I really can't wait to see this. What a great looking model.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Lovely work so far. Nice clean deck planking and frame assembly. I'll be following this.
- 21 replies
1:32 Fifie – The Scottish Motor Fishing Vessel Amati Catalogue # 1300/09 Available from Amati for €268.00 The Fifie is a design of sailing boat developed on the east coast of Scotland. It was a traditional fishing boat used by Scottish fishermen from the 1850s until well into the 20th century. These boats were mainly used to fish for herring using drift nets, and along with other designs of boat were known as herring drifters. While the boats varied in design, they can be categorised by their vertical stem and stern, their long straight keel and wide beam. These attributes made the Fifies very stable in the water and allowed them to carry a very large set of sails. The long keel, however, made them difficult to manoeuvre in small harbours. Sailing Fifies had two masts with the standard rig consisting of a main dipping lug sail and a mizzen standing lug sail. The masts were positioned far forward and aft on the boat to give the maximum clear working space amidships. A large Fifie could reach just over 20 metres in length. Because of their large sail area, they were very fast sailing boats. Fifies built after 1860 were all decked and from the 1870s onwards the bigger boats were built with carvel planking, i.e. the planks were laid edge to edge instead of the overlapping clinker style of previous boats. The introduction of steam powered capstans in the 1890s, to help raising the lugs sails, allowed the size of these vessels to increase from 30 foot to over 70 foot in length. From about 1905 onwards sailing Fifies were gradually fitted with engines and converted to motorised vessels. There are few surviving examples of this type of fishing boat still in existence. The Scottish Fisheries Museum based in Anstruther, Fife, has restored and still sails a classic example of this type of vessel named the Reaper. The Swan Trust in Lerwick, Shetland have restored and maintain another Fifie, The Swan, as a sail training vessel. She now takes over 1000 trainees each year and has taken trainees to participate in the Cutty Sark Tall Ships Races to ports in France, Denmark, the Netherlands, Ireland as well as around the UK. Extract from Wikipedia The kit Fifie is packed into a large, heavy box that certainly hints that there’s a good quantity of material included to build this historic fishing vessel in all its glorious 1:32 scale. I do admit to particularly liking this scale, having built plastic models for many years and indeed for magazine publication. It’s definitely something I can relate to when eyeing up the various dimensions and features. Amati’s presentation is flawless and certainly stands out, with its large, glossy lid that captures an attractive view of the Fifie. It has to be noted here that the hull is usually fully painted, with green being common above the waterline, but this model was finished to show off the beauty of the walnut timber supplied in the kit. And why not! For those that don’t know, this kit, under the Victory Models label, was designed by Chris Watton. Many of you should be familiar with that name and his design pedigree. At 1:32, this kit is no shrinking violet in terms of size. Fifie is 700mm long, 470mm wide and with a height of 230mm (sans masts). Lifting the lid does indeed show a box crammed with materials. Inside, we have several bundles of timber, plus a packet of timber dowel/strip/metal rod/tube, a thick packet containing numerous laser-cut sheets, another packet with plans and photo etch, and underneath the main timber, we have sail cloth and fittings packs. Thick foam is included to stop the main materials from banging around in the box. Strip wood Fifie has a double-planked hull, with the first layer being constructed from 1.5mm x 7mm lime strips. These, like many of the other bundles, are 600mm long, and very cleanly cut with no fuzzy edges Sixty-five of these are supplied. The same quality goes for the second planking layer, which is supplied as 90 strips of 1mm x 6mm walnut which is some of the best I’ve seen in a kit. There is little colour variation in these, and they look pleasantly uniform. I’ve always found Amati’s timber quality to be exceptional and this is no different. As well as elastic to hold the bundles some labels are also included to help identity the material. Other strip wood is included (beech and walnut) for such things as deck planking, caulking (yes, caulk plank!), lining the various deck hatches, sheathing the deckhouse structures, rubbing strakes etc. These bundles are both taped and bound with elastic, with the deck planking having an identifying label also. Cutting is clean and precise. Dowel and tube/rod Various lengths of dowel is included for masting, false keel strengthening pins etc. and thicker strip wood for the timberheads. All is supplied in a nice uniform walnut colour….no nasty walnut dyes/stains in this kit! These latter lengths are also packaged into a thick clear sleeve, unlike the others. Note also various lengths of brass and copper wire, as timberheads well as some copper tube. Some mounting parts are included for RC conversion, but you will need to purchase other items to complete the model for radio. MDF sheet items Again, Amati has made extensive use of 4mm MDF for the hull false keel and bulkheads, and all are laser-cut, as are all individual wooden items in this kit. Cutting looks very precise with very little in the way of scorching, apart from very localised discolouration. I know many don’t like MDF as a material for our models, but MDF sands easily and is also warp-free, lending itself to a nice, true hull. You won’t see any of this when you start to lay planks. There are FOUR sheets of this material, and you’ll notice that there aren’t any parts numbers engraved on here. You will need to refer to the first two sheets of plans which contain the parts references. A single sheet of 2mm MDF contains parts such as the four-piece deck, cleats, and the bulkheads and keel for Fifie’s single launch vessel. There is also a single 6mm sheet of MDF (sheet 2698-B) which contains the four parts needed for the cradle. I’ve seen numerous sites which now sell this model claim that no stand is included with this model. Well, this sort of proves that statement incorrect. This is the same cradle shown on the box lid images. Of course, you’ll need a suitable MDF primer for this, and some nice coats of gloss lacquer to get the best from this. Ply sheet parts SIX sheets of thin ply are included for just about every other timber construction elements of Fifie, including the deckhouse, deck superstructures, keel sheathing, and bulwark capping strip. Again, all parts are laser-cut and will require minimal effort to remove any edge char. Fittings Two boxes of fittings are included in the very bottom of the Fifie kit box. Some of the weight bearing down has caused a small crack in the two vac-form fittings boxes, as you can see, but all parts within are absolutely fine. The first box contains the cast metal propeller, deck buckets, ship’s wheel, rigging blocks, life preserver rings and a whole load of beautifully smooth wooden balls for making the many buoys which sit on Fifie’s deck. These are perfectly circular, yet the ones on the box image are slightly shaped. Instructions show these as the balls, and you could perhaps opt to use a little putty to add some shape to these. The second fitting box contains seven spools of rigging cord in both black and natural colours, nails, various cast fittings such as bollards, plus rudder pintles, anchors etc. Copper eyelets, chain and ferrules etc. make up the set. Sail cloth Should you wish to add sails, then enough material is supplied for you, in bleached white cloth. Photo-etch Very few kits come without photo-etch parts these days, and this is no exception, with TWO sheets of 0.7mm brass with a very high number of included parts. A quick scan around the sheets will easily identify parts for the mast bases, steam winch, engine skylight, capstan, deck hand pump, wheel assembly, herring shovel, tabernacle, mast rings, etc. Acetate and card I have to say I’m not entirely sure what the card/cartridge paper is for except for maybe general use, but the thin acetate is obviously for the cabin windows. Instructions and plans Without a doubt, Amati produce some of the very best instruction manuals to come with any model kit. For reference, check out my Orient Express Sleeping Car review and that of Revenge. Fifie is no different with a luxurious and fully-pictorial, 64-page publication. Whilst this isn’t perfect-bound as with the previous reviews, it is in full colour and produced to a standard that’s still far higher than many contemporary manufacturers, with each stage being shown under construction so you get a perfect idea about what is required at that point in construction. Text is also in English, or at least in the sample I have been sent. The rear of the manual contains a complete components list. Backing up this publication is a set of seven plan sheets. The first two of these are for identifying the various timber and PE parts. The others show general profile and detail imagery, as well as masting and rig drawings. Remember that the hull itself is built entirely from the photographic sequences so everything you see on these drawings is for external details. Conclusion I have to say that you get a lot of kit for your money with Fifie, and when I first asked Amati what they envisaged the RRP to be, I was quite surprised at this. Everything about Fifie is quality, from the packaging and presentation, to the beautiful, photographic manual, fittings, sheet and strip timber, all the way to the superbly drawn plans. I’m very surprised that the gestation period has taken so long for them to bring this excellent kit to market. It’s also a Chris Watton thoroughbred. If you’ve seen his previous designs, then you’ll be familiar with the format of Fifie, which was quite the different vessel for Chris to tackle, when everyone seemed to think he would only design fighting vessels, armed to the teeth with cannon. I must admit that Fifie did take me quite by surprise too. The very shape of this iconic and historic vessel is so homely and welcoming and for me, invokes images of those times when fishing communities were happy and thriving. Whether you’re a fan of Chris’s work or not, Fifie is most certainly a kit that you should consider dropping into your virtual shopping cart next time you visit your favourite online model ship/boat retailer, and of course, if RC is your thing, then this kit will also suit your genre! VERY highly recommended! My sincere thanks to Amati for sending out the sample kit you see reviewed here. To purchase directly click the link at the top of the article to take you to Amati’s online shop or check out your country’s local distributor. Plans are also available from Amati, for €21.00
So pleased you like them. More to come too, with kits from Amati (including their new Fifie), Master Korabel and @MarisStella.hr etc.
kit review 1:100 Santa Maria 'First Step' - Amati
I don't think the exactitudes matter too much to an enthusiastic youngster, as they do to more seasoned modellers with knowledge of ship design. This modeller is just really enthused to be building a wooden ship- 7 replies
- beginner
- santa maria
I gave this kit to a young man who wanted to try building model ships, and he has now started! Great to see the next generation at work- 7 replies
- beginner
- santa maria
1:135 H.M.S. Bounty Amati ‘First Step’ series Catalogue # 600/04 Available from Amati HMS Bounty, also known as HM Armed Vessel Bounty, was a small merchant vessel that the Royal Navy purchased for a botanical mission. The ship was sent to the Pacific Ocean under the command of William Bligh to acquire breadfruit plants and transport them to British possessions in the West Indies. That mission was never completed due to a mutiny led by acting lieutenant Fletcher Christian. This incident is now popularly known as the mutiny on the Bounty. The mutineers later burned Bounty while she was moored at Pitcairn Island. An American adventurer rediscovered the remains of the Bounty in 1957 and various parts of it have been salvaged since then. Extract from Wikipedia The kit This is the second of the three Amati ‘First Step’kits that I have for review here on Model Ship World. As with the previous review of their Santa Maria, also in this range, this kit is aimed at the newcomer to this hobby, who want to see a fair and decent result without having to be hands-on with all of the various skills needed and tools required by a more complex kit. The kit is packed into an attractive and glossy box which isn’t too large and certainly won’t dominate your workbench. A photo of the completed model adorns the box-art, showing you that the results from such a simple kit are actually very pleasing and certainly not shabby at all! Note also the dimensions of the finished model are 26cm in length, 28cm in height, with an overall width of 6cm (although according to plans, that last measurement is actually 9.6cm at the widest yardarm). Opening the box, you’ll note that the modeller isn’t inundated with a mindboggling array of materials, but instead things are kept nice and simple, with a small bundle of timber, pre-shaped hull halves, small packet of sheet material, flags, fittings box, manual and single plan sheet. As noted, the hull in this model is solid, and provided as halves, as per the Santa Maria. In fact, the parts themselves appear to be a standard, and identical to the previous kit, and indeed to the review which will later follow this one. These parts are nicely carved and shaped, with just a sanding and sealing needed to finish them before painting. Internally, you’ll note the two holes which appear on each half. These are to fix the dowels to which locate the parts together, with the false keel being sandwiched in between them. That false keel is made from MDF and included on a laser-cut sheet with a number of other parts for the quarterlight windows and transom sections. Quality is excellent but remember to wear a mask if you need to sand any MDF at any time. A thin, laser-cut ply sheet is included, being the last of the sheets of parts in this kit. Here you will find parts for the bow timbers, transom windows, quarterlight windows and the mast tops. Being laser-cut some parts may need any char removing from the edges before use. As with all First Step kits, this includes a wooden plinth onto which your model will mount. Turned walnut pedestals are also included. A small bundle of both strip and dowel is included. Strip looks like Lime, and the dowel is Ramin. Quality is very good, as you expect from Amati, with clean cutting and an even appearance. Printed paper is included for the flags. These are designed to be folded around the rigging lines, providing a face on each side. You will need to manipulate these so that they hang naturally. A large piece of off-white sail cloth is also included too. You will need to use the templates on the main plan sheet and transfer the shapes to the fabric before you add any boltrope and stitching. As with all Amati kits, the familiar plastic fittings box is included. This compartmentalised box contains parts for the windlass etc., plastic moulded grating, rigging cord, turned walnut pedestals, set of two anchors, nails, cast ships launch windows, lanterns and figurehead, eyelets, rings and some rather attractive cast cannon which look amazing despite their tiny scale. A large, single sheet plan is included, printed on both sides. The first side shows the ship in plan and side elevations, as a complete masted and rigged vessel, with locations for the various deck fittings etc., plus a set of templates for the ten sails that need to be made if you wish to have your model adorned with them. On the reverse, there are masting illustrations, and rigging drawings. These look very straightforward to follow and shouldn’t present any problems to a novice. Bounty’s instruction manual is a 10-page affair, printed in black and white with the model broken down into 16 constructional sequences. All are accompanied with English text and annotation, with the drawings themselves being very easy to follow. Painting references are provided throughout. The last page of the manual includes a parts list that you can use to check off against the kit to ensure there’s nothing missing. Conclusion Another great little introductory model from Amati, designed to ensure a trouble-free move across into this great hobby, and without compromising on the finished result. Everything us here that you need, apart from paint and glue. This would also make a nice project for a seasoned modeller who perhaps just wants a little side project for a friend etc. Either way, it’s a very worthwhile kit that is certainly worthy of your consideration. My sincere thanks to Amati for the sample reviewed here. To purchase, click the link at the top of this article.
non-ship review 1:24 Istanbul tram - OcCre
James H replied to James H's topic in Non-ship kit reviews
Fantastic! Looks great so far. Any tips? -
Lovely work so far. Always wanted to see one of these built.
- 236 replies
- artesania latina
- kitbashing
1:100 Santa Maria – First Step Amati Catalogue # 600/03 Available from Euromodels for £69.99 Santa María was built in Pontevedra, Galicia, in Spain's north-west region. She was probably a medium-sized nau (carrack), about 58 ft (17.7 m) long on deck, and according to Juan Escalante de Mendoza in 1575, Santa Maria was "very little larger than 100 toneladas" (about 100 tons, or tuns) burthen, or burden, and was used as the flagship for Columbus’ expedition. Santa María had a single deck and three small masts. She was the largest of the three ships used by Christopher Columbus in his first voyage. Her master and owner was Juan de la Cosa. Courtesy of Wikipedia The kit Everyone has to start somewhere in this hobby, and few manage to build a fully rigged Man ‘O War or clipper without at least some experience of how to work timber etc. Of course, being any sort of modeller who can think on their feet is always an advantage, but there a whole demographic who would like something just to kick-start their passion, whether they are of our generation, or a whole new generation of younger modeller who may progress to the lofty heights you see here on Model Ship World. For that latter group, Amati have their First Step range, and today we take a look at the first of three of these kits that they’ve sent to us for review. Santa Maria is packaged into a small and attractive box with an artwork of a finished model on the lid, and some vessel history on the side. As you can see from the box, this particular model has a length of 28cm, a height of 24cm, and a width of 6cm. So, it’s still a reasonable size. Lifting the lid reveals a set of plans, instruction manual, sail cloth and printed paper sheet for flags, two pre-carved wooden hull halves, a bundle of strip wood, a packet with two MDF laser-cut sheets, a wooden display base, and a whole box of fittings. Unlike your traditional model ship/boat, where you either plank over a series of bulkheads or frames, the Santa Maria comes with two pre-carved hull halves. Looking at the other kits in this range, these halves appear to be of the same shape, but it’s what you add that really makes these models look very different from each other. Note the two holes. These are used to align the halves, and also peg through a centre plate which forms the keel. Instructions will show you how to paint and stain your model when complete. Here you see the main 4mm MDF sheet that contains the main keel/profile with the alignment holes and mast sockets, plus a deck section. Parts are all laser-cut and are clean and precise. Of course, you will need to ensure that any sanding that’s to be done with these parts means you will wear a face mask. Wood dust isn’t great for the respiratory system, but MDF can be particularly bad. Important that youngsters are aware of this. The second and last sheet is also MDF, but 10mm thick. There are ten parts here, for raising up the fore and aft decks, creating the correct shape of this ship and totally transforming the shape of the basic wooden hull halves. When your model is complete, you’ll want to display it properly, and this kit includes a neat wooden base. Nicely turned pedestals are also included that will glue to this and into which the keel will slot. A small bundle of timber is included for masts, spars, wales, bulwarks etc. Timber quality is excellent, as we have come to expect from Amati. These plastic fittings boxes are very common to Amati releases, and even these First Step kits get one, stuffed with goodies to adorn and detail your model. All parts are bagged and compartmentalised, and the clear lid holds tight, keeping everything in place whilst in the kit box. Unlike other kits, this one has a brown plastic-moulded grating which you will need to cut to the required size. Note the mast top/crow’s nest is manufactured from a piece of turned walnut and is silky smooth to the finish. Some white metal parts are included too, such as doors, windows, and the ship’s launch. Casting is very nice, and with a lick of primer/paint, should look very good once installed. Remember, this is a very small model when complete, and therefore these parts are also small. We also have a packet of nails for general construction. Of course, you will also need an anchor or two. A packet of two is included with this release, complete with wooden stocks and brass ring fittings. The anchors themselves are blackened and ready for use. A couple of small packets contain the decorative shields for the upper, rear exterior bulwarks. These are designed to be painted. Also, we have some small copper and brass fittings, such as rings and eyelets. There are a few small staircases on Santa Maria, and these are cut from these pre-formed lengths of timber. Note also some parts for the windlass and rigging blocks. There are only a couple of the latter, as the model is designed to be simple to build (and rig). Here are the aforementioned turned walnut pedestals onto which you will mount your completed model. These are high quality and require no extra finishing apart from some varnish, perhaps. Only two spools of rigging cord are included, one being in black for the standing rig, and the running rig being in natural colour, as a general rule. You will need to make your own sails, but this is fully explained, and is very simple. Plenty of material is provided for this. For the flags and pennants, a sheet of colour-printed paper is included. You can also go to town with fabric paint and add the familiar Maltese cross to the main sails. Again, this is shown so you can copy from the illustration. One large plan sheet will show you everything you need to know for your build, and everything is simple to follow. Several 1:1 scale images are shown for you to measure against, including the masting diagrams. Amati’s instructions tend to be well illustrated and easy to follow, from my personal experience, with many of the very new kits having the best I’ve ever seen in any of the modelling genres. This kit also has a nicely illustrated manual that takes the construction through in a series of easy to follow steps complete with English text. I can’t see anything here that would thwart even a young modeller, with the various drawings. A handy parts list is also supplied at the end of the manual, which is handy for you to check your supplied parts against. Conclusion These kits fulfil several roles on the market. For me, the first is to introduce a young modeller to our hobby and initiate them with a number of the skills required to advance a little and create more complex results. Another is to allow a modeller who may never have used timber before, to build a very nice replica of a ship and to help them also pursue a line of attack into a more challenging project. Lastly, these could well appeal to a seasoned modeller who fancies a little fun between larger projects and may want to build something they could gift when complete. So many possibilities. The kit itself is actually a high-quality product that is well thought out and executed. There are also some classic vessels in this range too, with something that should appeal to most ship builders, or soon-to-be ship builders. Price-wise, these kits are also relatively inexpensive and will provide a good number of happy hours at the modelling bench. Wherever you are in the hobby, or whether you’re starting out, give one of these a try! I have already given this model kit to a young man who will send me some photos of his progress. I will post them here as he builds this model. My sincere thanks to Amati for the sample reviewed here. To purchase, click the link at the top of this article.
- 7 replies
- beginner
- santa maria
