Mark Pearse
Everything posted by Mark Pearse
  1. thanks Steve, Yes the bowsprit as a boarding plank is a good one. It would have been a small boat for a family with 4 strapping boys. Not surprised that Ranger came soon with its generous cabin size (relatively speaking)
  2. thanks everyone I completed the supports this morning - if you want more details there was a post that sketched the design. The photos below show if from the wall point of view. The wall plate is the lower split batten, pre=drilled for up to 8 fixings. The weight of the model is held by this. The model is dropped onto the wall plate, then the side screws, visible below, are put in. They really stop it from being accidentally bumped off, or the opportunistic thief (that isn't carrying a large flat head screwdriver....)
  3. Thank you for the detailed & patient explanation of this fine model. I find the tiller yoke question intriguing. Is there any evidence that they might have used metalwork fittings that integrated with the timber piece you showed? I find the rope idea unsatisfying, the leverage doesn't look quite right. Mark
  4. Thank you all. I think the model is finished now. Some finishing details: I scribed some lines to indicate water, I think it looks quite good. The trim is from Australian Red Cedar, which is not a pine timber. It's light & looks like Mahogany, & also takes shellac well. I cut some 9mm strip, rounded the front edge & finished with brown shellac, screwed with bronze screws because the colour goes better. I painted inside the hull a dark grey, it looks better than plain timber. As the half model will be a trophy for our sailing club, there will be a plaque below the hull, & I realised the centreboard would interfere with the plaque, so I cut the centreboard down just so that the visible sliver indicated it's presence. The reflection works quite well, the boat really seems to float in the air. And from some angles you see the hull shape very well. The bowsprit is quite wide, but the story from the designer's son (now 95 & I spoke to him today, but unfortunately I now can't visit him tomorrow morning to show him the model) is that Cliff got so sick of rowing the kids back & forwards to the shore when they went picnicking that he put a bronze shoe on the forefoot of the bow to protect from sand grinding, made a wide bowsprit so he would pull the bow onto a harbour beach & the kids would use the bowsprit to get on & off. So, that's why it's wide & flat. Lovely bow lines. Fine entry & plenty of volume to give lift in waves. Cliff sailed this boat the 10 or12 km ocean sailing to Broken Bay, & this little boat apparently did some trips in difficult conditions. As noted at the beginning (& photo), he had a removable cuddy cabin made for this sort of use.
  5. The stainless steel backplate went very well. Using the metalwork section of this forum I asked for advice (https://modelshipworld.com/topic/28771-polishing-stainless-steel-sheet-to-mirror-finish/) & the method I used is explained in more detail there. The good news is that I am more pleased with the result than I expected to be. I did get a mirror finish, but the effect is a lovely soft sort of mirror finish, just the thing for a half model of a 1930 design - the mists of time etc.... The photo below shows nicely how it looks, the reflection of my drill has a soft ghosting effect. And yet the reflection is nice & clear. I started on the mounting brackets - below is the back of the backplate. It follows the design a few posts ago. Essentially its split battens & then screwed to hold it there. The side strips will also visually cover the split battens from the side. I glued the stainless steel sheet onto this plywood, using some sikaflex marine sealant I had left over. I think it will work better than epoxy...will see. I ended up fixing the timber by screwing it from the back & not using glue.
  6. The ideas here helped a lot & I am happy with the results. Most of the tools I used are below: some mesh sanding sheets 400,600, 800 grit; a sponge pad used in a drill, Autosal metal polish. I actually did borrow a fabric polishing head & green Tripoli wax, & it helped as well but didn't seem to do as much as the Autosol & sponge pad...but perhaps I needed to do both. You can see the reflection is clear, but not a full mirror finish. It took a couple of hours of hand sanding using the sanding sheets, with a light spray lubricant at the same time, about an hour with the fabric head, & about 30 minutes with the sponge head. There is a slight ghosting in the reflections, but I am very pleased with that. It adds of softness to the reflection that is very appealing, & was quite unexpected. You can see the effect in the reflection below. It's likely that I could have gotten closer to a full mirror finish, but I think the result that I got is what I prefer.
  7. Some more work today: the boot top line & shellacking is underway. I did the boot top line because it shows the hull shape off better if you can visualise the waterline. I sprayed it with an airbrush, black paint not diluted but sprayed on a restricted setting so that it is far from solid. I also did the centreboard to differentiate it. This is two coats of shellac, no sanding yet. I will be able to do some decent photos later, but at night it's not easy as the lighting is too much from one side.
  8. Hi Bruce, glad you enjoyed the visit. This is my idea for mounting the half model. Split battens, the lower one fixed to the wall & upper to the model backboard. Vertical side battens also fixed to the backboard. To hang the model you fix the lower split batten to the wall, then put the model on it (the battens will mean it will happily sit there. Then screw through from the sides to fix in place.
  9. I started hand polishing the SS sheet that will be the half model backplate, using some mesh type sanding sheets of 400, 600, 800 grit. I hand rubbed in a parallel direction across the sheet & used some spray lubricant as well. The metal is getting there, & in the next couple of days I will try a rag polishing head with Tripoli wax. You can see (above), that the deck line needs tweaking. It's not yet an even curve. Below, the sky & street power lines reflected in the semi-polished metal. I did a test of brown shellac on some Huon Pine, see below. It's lustrous, shown here with an unfinished piece - the centreboard.
  10. Hi Silverman I have just come across this build. It's very nice. I like very much the figures (the clothing is excellent) & the stand is pure genius! Bravo Mark
  11. Hi Steve, Best wishes for this, I hope it resolves well for you. There's some wonderful south coast areas, & so many beautiful estuaries & tidal rivers. Jervis Bay has a maritime museum & recently won an award for their restoration of this lovely boat, so they must be pretty active. Mark
  12. Hi Michael, This will be fun, such interesting & extreme boats. Have you ever sailed on one?
  13. Assuming the bowsprit has a bobstay & whisker stays, the main load on the spar is compression. The old 18' skiffs have a bowsprit about 20' (6.6m) long, they are about 75 x 45mm in section - & they actually hollow out the underside.
  14. I would add that it's possible to laminate sheets of silkspan to make it heavier. I mixed PVA with white acrylic paint & laid it up 3 layers thick to replicate heavy duty dacron at 1:12. It shows no sign a delaminating.
  15. Hi Michael I'm not sure about butting in, but hopefully this is helpful, & apologies if it isn't. The bow is certainly very fine. Personally I doubt the builders would have thinned the planks at the bow, I reckon they would just use a wider stem timber & placed the rabbet line to suit. I reckon the steps are: they decided a minimum remaining timber thickness after the rabbets were cut into the stem timber; if the two plank thicknesses plus this minimum thickness totals 2.5", then the rabbet line at the bow will follow the 2.5" hull thickness line, like a contour on a survey plan. So the fine lines don't need to be made more chunky, but it would mean a wide outer stem to achieve the fine bow - but it would be strong & the width of the outer stem would look elegant & emphasise the fine lines.
  16. I'm working on the outer parts of the stem & keel. The lines drawing of the design appears to stop at the rabbet line, so I guessed the visible amount below the rabbet line at 45-50mm. This boat would have been lightly built. I'll glue the pieces on before doing final shaping where it meets the bow lines. I don't have a pic of the stem piece, but the curved part (name?) is below. I chose a part of the timber near a knot, that suits the shape. The bowsprit is roughly shaped, & it still looks a bit thick to my eye. The forward part of the gunwale is lifting, I've bound it with rubber bands & tried some epoxy. The hull is looking good. The virtue of adding the gunwales & other details in showing; compared to photos without these details the sweet lines are more visible. And the coaming is glued in - I managed to domesticate the Makita table saw enough to get a 1mm slice, & with the heat gun it bent easily. The bowsprit is definitely too heavy looking, & the coaming needs to be trimmed parallel to the deck line.
  17. Hi Keith I think your metalwork is getting even better, this batch is beautifully delicate. PS I know them as whisker stays.
  18. I made & attached the gunwale, first cutting a strip of Huon Pine: The shaping & bending it. Initially I used a heat gun to bend it, but although it was happy to curve that much it didn't want to stay there. Plus, because it was being bent against the wider dimension the timber wanted to twist away. So I used boiling water & clamped it for 24 hours, after which it still wanted to spring quite a lot. So the initial plan to just glue it was upgraded to plugs of timber (actually bamboo I think). The plugs stand out a bit, but I wondering about staining it, or maybe even painting the gunwale. Still just roughly sanded, but I love what adding a gunwale does for showing off the lines. She's really starting to show pedigree; & the fine entry & hollow exit lines are showing well. On an historical note, gunwales do seem to be larger & wider in the past. I carefully enlarged a stern photo of this boat & measured the size, & this is accurate, around 90mm wide actual.
  19. Hi Steve That looks very good. I like the delicacy of your design.
  20. thank you everyone That is a big help. I'll experiment on a corner of the sheet soon & see how it goes.
  21. Hi Shipman, thanks & sounds like a lovely motorbike. What compound, if any, did you use on the buffing wheel?
  22. thank you Bob, I'll digest that before attempting anything
