Blue Ensign
  1. Thank you Ron, Kevin, Marc, and Capt. Birdseye. Chapter five Framing the Gunports. This is an ingenious method devised by Chris that gives a nod to the Plank on Frame method and removes all that testy business of cutting ports into a hull. The longitudinal stringers that form the top and bottom of the gunports are now fitted. 0454 I fitted the rear gunport strips from the stern forward, I found it easier to locate the two aftermost slots fully into the bulkheads. 0452 These are followed by vertical risers that complete the port framing. They are position specific so care has to be taken in their fitting. 0453 The parts fit together beautifully, and at this stage of the build it is rather like doing a 3-d jigsaw puzzle, but without the puzzle element. 0457 I’m loving the look of her even at this stage, I think you will all agree she is an impressive sight. Chris must be well pleased with the fruits of his labour. The next stage is fitting the gundeck, but at this point I am going ‘off piste’, as I have some modifications to work out given the ‘Navy Board’ style of my build. B.E. 15/03/2023
  2. Chapter Four What lies beneath. Before the Upper (gundeck) is fitted I need to establish what may be seen below on the Lower deck. This is relevant on my build as the deck will be open to maximum view. Planking and detail provision is made for the Lower deck between the Fore hatchway and the Mainmast, but aft of the Mainmast there are also ladderways and hatches down to the lower deck which just may be visible should I choose to leave the gratings off the hatchways. 0427 Template taken from the plans for the section aft of the Mainmast. 0430 0431 0428 0429 These additional areas of the lower deck are planked using cannibalised maple deck sections left over from my Sphinx build, and I knocked up grating sets that are pretty much the same as the Gundeck arrangement. 0433 0434 0435 Temporary rough fitting of the gundeck gives a sense of what may be glimpsed on the lower deck. This will I hope give the illusion of a fitted out Lower deck limited as the view will probably be. B.E. 13/03/2023
  3. You put me to shame Alistair, better not let my wife see your work space😬 B.E.
  4. Thank you, Alistair, for your kind words, glad my old Pegasus log is still providing some use. Yes, that is Bluebell, made back in the 1990’s from a Matchbox Kit with aftermarket additions. I loved those corvette kits so much I built it again as Snowberry (A Revell issue) with more modifications, but that one is cased. I like the hooded planks on the QD adds a load of interest, and those replacement headworks are a vast improvement on the kit issue. Enjoying your resurrected build. Regards, B.E.
  5. If that's a reference to my post Jim, I'm not having a go at you, simply record it to save people time in sifting thro' all the sheets to find the part, as I did initially, and as something highlighted for future editIons of the manual. This was a massive enterprise and I commend your efforts and build, sorry if I've upset you. Regards, B.E.
  6. Great to see again Alistair, she is a beautiful model and deserves to be finished. With a view to the coppering finish, I'm off to make friends with the horses across the lane.😉 B.E.
  7. Thanks Alistair, I don't know about longer UK hours, I suspect the fact I'm long retired has more to do with it, coupled with the fact I've now given up Golf. 😊 Chapter Three The Assembly continues. I pick up this stage by adding the deck beams for the Upper deck and will finish with the bow and stern assemblies. Twelve beams are required that simply slot into the longitudinal braces (part30) There are three spares. Note: These are located on the 4mm mdf sheets, not 3mm as indicated. 0415 My old Sphinx build board is re-figured for this early build stage. The bow parts that build up the round are now assembled. Note: Part#34 is located on the 3mm mdf sheet, not 4mm as indicated. I followed the indicated sequence of fitting the bow extension pieces with Bulkhead 1 fitted to the keel, taking care not to get glue on the keel. I then struggled to remove the bally thing from the Keel, and I began to worry that I may break something trying to free the bow section. I used a piece of dowel thro’ the Bowsprit opening to act as a lever to ease the part out, combined with pressure on bulkhead 2 and the extension pieces that fit over it. Nevertheless, it was a bit of an anxious moment. The final parts were then added. I read in Jim’s log that Chris had recommended a palm sander to do the fairing, given the size of this beast. As a confirmed toolaholic, I followed Jim’s lead and got myself a B&D Mouse. (one of those sundries I referred to in Chapter 1.) 0410 I’ve never been a fan of power tools for delicate work on models, I don’t trust myself, but I thought I’d give it a go. Initial fairing of the bow section seemed a good place to start, and I was pleasantly surprised. The mouse sits easily in the hand, and with the finger extension attached, there is no feeling of it running away and taking too much off too quickly. The finger extension which acts like a sanding stick, runs across three of the bow extensions, and I think it will prove useful to reduce the amount of hand sanding required in the fairing. 0411 This is about as much as I felt comfortable taking off with the section off the model. 0424 The bow section was then glued into place. Same procedure with the stern section. 0418 0420 The final section (parts 29) are pre-shaped before attaching to the keel. 0422 Completion of the fairing will be done on the model. 0425 All the bulkheads are now attached and she’s starting to get heavy. I’m thinking of adding lifting handles to the build board ends. 0412 I have also invested in a white board to display Chris’s beautifully drawn plans, I was struggling to find somewhere to open them out, and this Amazon basic board fits the bill. B.E. 12/03/2023
  8. Thanks Glenn and Ron, I usually have three build boards for larger projects such as Sphinx/ Indy each one specific to a particular stage of a build. I find the Amati clamp very useful where I want a specific angle, or a bit of height but wouldn't trust the single one for Indy, she's too heavy and long. At the moment I'm using my old Sphinx board bashed to accommodate Indy, but I will be making a new one. Regards, B.E.
  9. Thankyou David, I'm already thinking Where am I going to put this! Chapter Two First Stages In this stage most of the heavy weight mdf items are assembled. The initial assembly slots together cleanly, and I must commend Chris on the sharpness and fit of the laser work. I did run a sanding stick in the Bulkhead slots to smooth the char and where necessary a light tap with a pein hammer (not directly) seated the parts fully down. I found I needed to ease the slots for the securing pegs which run thro’ the keel assembly. Even so they are a snug fit and I don’t really think they need glue. 0384 The keel is still quite floppy at this stage due to its length, so I utilised the Amati keel clamp whilst I fettled and inserted the pegs. 0383 With this beast the keel clamp is at the limit of its capacity, and I’m toying with the idea of buying a second to double the length, and provide a more stable support. A deeper bench would be ideal but not really feasible. I will have to be careful when turning the hull that those delicate frame tops don’t collide with the wall. 0387 Note: There is a minor error in the manual at Stages 21/22. Bulkhead 17 is not removeable as indicated, as it is held by part 40. Chris has issued a pdf amendment addressing this. 0389 A small area of the Orlop deck is represented beneath the Fore hatchways, which I ‘dressed’ using spare engraved maple decking. 0390 The Lower deck slips seamlessly into place and there is a plywood planking engraved section that presumably covers the area that may be observed thro’ the Upper deck openings. The Orlop and Lower deck decking section are the only parts glued at this stage. 0401 I considered whether to over-plank the Lower deck section, as will be done to the upper deck, but very little will be seen and I think the marked plank lines and butts will be sufficient for the purpose. 0401 Very nicely cut grating sets which I will install ‘as is’ for the lower deck. 0397 The assembly of ladders always give me trouble but a simple jig helps a little. The final action in this Chapter is to add the Longitudinal bracing pieces (No.30) and parts5b/11b described as a gundeck beam. 0405 Note: Parts 30 are to be found on the 4mm mdf sheet not 3mmm as indicated. May save you a little time in sifting thro’ the sheets. I did have a slight mishap with one of the part 30 pieces, which broke about one-third along at the weak point of the slot top. Take care if easing these slots the part is very whippy and care needs to be taken. 0408 This completes this section, more of an assembly than a build at this stage. I can only marvel at the ingenuity of Chris to design a beast like this held securely together with barely any glue. B.E. 10/03/2023
  10. Thanks Jason. It's only the equivalent of buying the Pearwood Rigging block kit version, but with Boxwood planking substituted for the blocks, and with additional planking included. For those who may be interested this is the cutting list for the replacements I envisage. 500mm long strips 20pkts Boxwood strip 4x1mm (200 strips.) for decking. 2 pkts Boxwood strip 6x1mm (20 strips) for decking. 4 pkts Boxwood strip 5x1 (40 strips) for gunport stripe and down to waterline Boxwood sheet 1mm 500mm (L) x 100mm (w) for cutting margin planks, etc; I bought that carronade from a village shop sometime in the 1970s, it's a heavy cast iron beast, made around the same time. I also purchased a larger scale 24 pounder long gun. Both carriages are made of English oak, and the breeching line I made myself at the Chatham dockyard, sometime in the 1990's B.E.
  11. Always good to finish the deck planking, nice job Kevin.👍 Did you find the strip planking followed the printed layout, or did it start to run off the further you got across the deck? Did you find the printed pattern a help or hindrance? Cheers, B.E.
  12. Chapter One Formulating a plan Wow – Sphinx on steroids! 01591 I’ll leave my assistant to do the initial inventory while I continue to fiddle with Medway. I can’t be doing with hauling that box around, so first steps are to sort the box content and put aside all the items I won’t be using. Smaller delicate items are put into a smaller container. I have been waiting to see what the supplied Red Alder deck planking looks like. Jim’s prototype build used maple pre-engraved decks. 0374 Under artificial light. 0378 Under natural window light. 1601 It is a nice-looking wood, but I understand Alder tends to darken with age, in tone it reminds me of Tanganyika, but a lot nicer. My preference is for Boxwood for decking. I would have gone for the top of the range Boxwood kit, but I didn’t need the Pearwood blocks, (£140) and the premium for the Boxwood version is a hefty £590. That’s a good chunk of a Sphinx worth! Still, I want what I want, therefore I have put in an order for the necessary Boxwood planking from Hobbymill.eu precision milled exotic woods and woodturning blanks which also allows me to include wider strips which are often necessary for decking purposes, and sheet to cut margin planks. Also included is Boxwood planking for the Topsides down to the wale. I am thinking of a contrasting wood for the Gunport stripe. I am also thinking of coppering this model, think the wonderful model of Bellona, but I am easy with a pearwood lower hull should my resolve fail. This is an additional cost but one that is only equivalent to the cost of the pearwood blocks set and provides me with a nice saving over the cost of the Boxwood kit. I have little doubt at all that the cost of sundries and extras will add more as the build progresses, they certainly did on my Sphinx build. Time for a little light assembly work I think. B.E. 09/03/2023
  13. Post 16 With the rails in place the stem bolsters have to be shaped and fitted. Chuck describes this step as challenging and provides six blanks from which two finished bolsters are required. Hoping that’s enough, but if it isn’t, perhaps I need a different hobby. 0346 To give me a feel for shaping these bolsters I carved a Balsa block before moving onto the cedar. 0349 0350 To achieve the shape, I used a No11 scalpel blade, and finger sanders with a curved profile. 0351 0352 Once the bevels are cut the most difficult part is holding the bolster to impart the concave shape down to around 0.8mm thickness at the bottom edge. 0353 0354 Multiple trial fittings are required during the shaping process. 0362 The final finishing was done with the bolsters in place. 0372 0367 All went well with four blanks left. The recess for the bolster roller was cut using micro chisels. 0370 0373 I can’t help thinking that the boat looks better without those baulks of wood, necessary as they are to perform one of the main operational functions. Perhaps once the decorative rail and decoration is applied they won’t look so prominent. B.E. 08/03/2023
  14. I would think that anyone scratch building the hull of Indy with proper frames wouldn't need the crutch of the Indy kit to finish it. It's all way beyond my pay grade. There are a few sectional kits around if that's what takes your fancy. B.E.
  15. Thanks for your comments Guys, much appreciated. @ Nipper - a stretch too far to add false 'real' frames to the mix, but I am watching Chuck's Speedwell development with great interest. A very large box is due to be delivered by UPS today, as close as it gets to being like a kid at Christmas again.😊 B.E.
  16. Post 15 The next stage is fitting the Capping rails, this will secure the frame tops and stiffen the frames further. I reduced the frame depths a little at the sheer before I added the rails which went on without any issues. 0331 I fixed the bow section first followed by the aft, centring the rail along the sheer. 0333 This is a fairly painless exercise, just need to ensure that the rails sit right down on the sheer and a tight join at the centre is achieved. A slight bevelling where the rail fits beneath the transom was required. 0335 I love the run of the sheer on this model. 0338 0340 0342 0341 0336 0343 0345 Fairly satisfied with progress thus far, but a somewhat more testy aspect looms. B.E. 06/03/2023
  17. Cheers Guys, thanks for your support. 👍 @ Kevin - I was rather thinking of following you, and crib off your progress.😉 I have informed my shipyard assistant of the impending project, and he's of the opinion that he'd rather be sniffing around the woods and meadows, than spend long hours in the workshop, listening to me muttering to myself. B.E.
  18. HMS Indefatigable 1794 The Prologue. I find myself once again beguiled by that modeller’s honeypot known as Vanguard models and I finally succumbed to Chris’s latest offering, having mulled it over for several weeks. Why the wait, wots not to like, some may say, but this will be the largest project I have undertaken since Norske Løve way back in the 1980’s. Indefatigable is about the same hull size as Norske Løve, (1:70 scale) but not so tall. It will still demand a sizeable display area. As with my Sphinx build this will be Navy Board style, I’ve no room for masting and rigging, and I have developed an affection for the look. I opted for the basic kit as all the masting, rigging line, and block work will not be used, simply added to my ever-growing pile of discarded kit parts. If I decide to add stump masts my preferred material is Ramin. From a preliminary assessment I don’t think Chris has left me much to fiddle with. He has addressed the issue of realistic Quarter galleries, the provision of Lodging knees, and a properly fitted out Great Cabin, complete with Rudder housing. He has solved the issue of lower deck cannons coming adrift early in a build, and the stern decoration and Figure are wonderfully sculpted. In terms of authenticity this kit hits the spot and is what in the end persuaded me to go for it. As with Sphinx I will be taking a minimalist paint approach, and will look to represent the ochre band along the gunport line more subtly, using natural woods. It was the all-painted hull that also delayed my decision; authentic as it is, I prefer the natural beauty of wood on a model of this type, and I needed to have a clear idea of the approach in my mind. The makings are expected to arrive on Tuesday, and I will be working the initial stages of the build in conjunction with my current Medway project. B.E. 05/03/2023
  19. Vanguard re-imagined. A conversation between Sir Christopher Watton, notable ship designer for his Britannic Majesty, and Mr James Hatch (seated) acknowledged Master shipwright, and preferred Navy Board contractor. Think you can knock this up by Easter Hatch, need to recoup some funds, don’t you know. That’s a big ask Sir Christopher, I ain’t left the yard in months, and I’ve only just finished chopping down that last Sixty-four you’ve had me working on for weeks. Well, do your best Hatch, and don’t forget the penalty clauses..
  20. Phew, that's a relief, thank you Chuck. It's so reassuring to have your expert eye watching over my efforts and those of others on MSW, it is much appreciated. B.E.
  21. Post 14 Removing the base board went without issue, and the hull will now remain upright as work progresses. 0311 The Queen Anne Barge building board is taken into service to support the Longboat for the remainder of the build. An issue developed with the upper wale plank on the starboard side where it had slipped partially out of the stem rabbet. 0310 Poor fitting on my part no doubt. 0309 Acetone was used to free the top two planks at the stem, and with the use of clamps and a prop the offending planks were re-set. Fortunately, in this area the bow plank/stem rabbet will be covered by bolsters attached to the stem which support the roller fitting at the bow. 0313 The tools I used to release the frames. A chisel blade to ping off the supporting tabs, and micro saw blades to release the frame centres. Fairly easily done with a micro saw, and apart from the alarming creaking as the centres release from the frame bottoms all went well. Only one frame needed re-gluing. 0330 This is the first real opportunity to see what a fine model, and what great lines she has. I am content with my decision to build her open framed. 0326 0316 0315 0319 0322 A fair way to go yet. B.E. 04/03/2023
