The copy I have is the third impression published in 1981, it only has 'Sailing Trawlers' on the spine, but the inside Title page includes the sub title The story of Deep-sea fishing with long line and trawl. My copy was published in Great Britain for David &Charles (Publishers) Ltd, and is published in the USA by David & Charles Inc. It is a 384 page book, and I don't think you need worry whether it is some sort of abridged version, it contains all the plans and rigging tables. It is in exactly the same layout as the companion volume Sailing drifters of which I have the original 1952 version. This volume is of great interest to those building the Fifie and Zulu models, and I used it extensively in my builds. B.E.
Relief short lived then,🙄 My two bottles bought some time ago have the control numbers K-03-06 on the label. B.E.
- 857 replies
- Sphinx
- Vanguard Models
I didn't realise that James may have been referring to a different 'Red' I picked up the use of 'flat red' from members who had used it on their builds. I think I first used it back in 2017 on my Model shipways Pinnace build, and have used it on all builds since, latterly on the Royal Barge kit. It always pays to test any paint on a strip of the wood to be used, before applying paint to the model. B.E.
- 857 replies
- Sphinx
- Vanguard Models
Thanks James for the heads up, I'll keep a watch out for that. 👍 I had a similar issue with Admiralty Red Ochre some years ago, one bottle came out with a distinctly unappealing pink effect. Regards, B.E.
- 857 replies
- Sphinx
- Vanguard Models
Thinking About colour There are four main colours other than black to be used on the model. Red, Blue, White, Yellow, and shades thereof. On every build I have done the actual shade has exorcised my mind, particularly for the colour blue. I am interested to see how various tones look against the mainly Pearwood finish. 3538(2) This is my rough colour comparison chart painted on a Pearwood background. All I am interested in here is how the colour relates to what will be the bright finish between Wale and Waist rail. The colour selection features paints from Vallejo, Admiralty (Jotika/Caldercraft) and Humbrol. The majority are water based but the Admiralty Red Ochre and Humbrol RAF Blue are oil versions as I didn’t have the acrylic versions to hand. I favour the more muted tones as seen on contemporary models, and I hope with this build I can settle on a colour that does not require mixing as that relieves me of working out a formula for re-mixes. My initial thoughts are:- Vallejo Flat Red - inboard works and some deck fittings. Vallejo Grey/blue - Ground to the Topsides and stern decorations. (Humbrol RAF Blue (96) runs a close second.) Admiralty Yellow Ochre – Frieze decorations, but with other shades of yellow and white for toning and highlights. I don’t intend to use gold on any area of the model. There is a very good section on painting decorative friezes in Volume 11 of the ffm, the techniques of which can be applied to the brass etched versions supplied with the kit to good effect. I am undecided about the lower hull as yet, if it’s good enough I may not paint it at all, but if I do I may need to tone a bright white down a little. This is the last of my musings before that large box hopefully arrives next week and the build begins in earnest. B.E. 21/08/21
- 857 replies
- Sphinx
- Vanguard Models
Not as many as with Pegasus I hope, this is a very fine offering from Chris. 🙂 Thanks Jason. B.E.
- 857 replies
- Sphinx
- Vanguard Models
Thank you Jacek, I used the AotS series book The 24-gun Frigate Pandora which gives details of the ships boats rigging. In addition to the Yawl a rigged Pinnace is also shown. I also used Steel's references for the rigging of ships boats for the mast dimensions etc. You will find details of my builds of small boats under the kit build logs 1751-1800 section. (Ships Boats, Page 9, of the log index.) The Yawl build follows on from the Cutter build. Regards, B.E.
- 857 replies
- Sphinx
- Vanguard Models
I have entertained myself this week building Chuck’s delightful little mini kit of the double Capstan derived from his HMS Winchelsea kit. 3534(3) At 1:48 scale it won’t unfortunately fit the forthcoming Sphinx build but it will sit in her case as an example of such a device of the mid-18th century. I am ahead of the game in one respect, I have already made the 22’ Yawl which will also be supplied with the kit. 610(2) At least one tiny element of the Sphinx build will be rigged. 620(2) 631 I have already decided to have only the Pinnace displayed on the hull so the Yawl too will sit within the case of the completed Sphinx. B.E. 20/08/2021
- 857 replies
- Sphinx
- Vanguard Models
Hi Glenn, I’ve got an A4 sheet of notes to myself of questions and possible mods, but I need to wait until I see the model before I commit to anything. I’m certainly thinking of minimal deck planking and the addition of Lodging knees, Hanging knees, ledges and carlings. On the hull I’ve mused about the possibility of Open hull framing in the area of the Orlop/ lower deck; the kit does include the Orlop deck and ladderway down from the Lower deck. It’s a very exciting prospect, made more pleasurable by the thought that I don’t have to worry about where to put it, altho’ my younger self would probably have masted and rigged it. Regards, B.E.
- 857 replies
- Sphinx
- Vanguard Models
Very nice progress Richard. The absence of lower Quarter pieces at the Transom is problematic, and I couldn't live with it, it just doesn't make sense. I had two nibbles at stern modifications before I was more or less happy with the result, it was however a fraught exercise. It's one of those 'time to bite the bullet moments' in a build. B.E.
- 104 replies
- pegasus
- victory models
Thank you Nils, They are an eclectic mix of sitting figures purchased from Deans Marine. Having separate arms and torso helped the 'conversion' to Royal Watermen of the early 18th century. Unwanted detail was removed using the Dremel, and the tunics were added using Artists modelling paste, Milliput, and styrene strip. These stage photos give you the idea. 3257 3388 3283 Regards, B.E.
- 185 replies
- queen anne barge
- Syren Ship Model Company
Whilst I await the arrival of my next project I have continued to play around with more Watermen figures to people the barge. After much faffing around I decided on six figures as this seemed to give the best balance on the boat without giving an overcluttered look. The figures as with the original oarsman are all derived from various 1:24 scale figures from Deans Marine. In setting the figures the trickiest part is fixing the oars in the vertical position. I had to resort to smearing ca on the palms of the rowers to secure them. I didn’t wish to mar the varnished thwarts, so a thin strip of Blu-tac was used to secure the oarsmen in place. 3422 3423 3413 3425 3438(2) 3437(2) 3411(3) 3398 3401(3) I think I can now declare the model finally finished, time to clear the workroom for the arrival of Sphinx. B.E. 16/08/2021
- 185 replies
- queen anne barge
Great planking job Derek. 👍 B.E.
- 345 replies
- Duchess Of Kingston
- Vanguard Models
Feature Suggestion
Blue Ensign replied to CDR_Ret's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
If you click on the gallery pictures across the top of the page to enlarge it, you won't have the scroll function. You need to click on the build title at the top left of the photo; this brings up all the photo's in the set, enlarge the first one and the scroll arrows will appear. B.E. -
WoW it’s like Pegasus on steroids, 11½ feet longer and 3¼ feet wider at full scale. Come on Chantelle. 😉 B.E.
- 857 replies
- Sphinx
- Vanguard Models
Thanks guys for your support, I do hope I live up to our joint expectations. 🙄 @ WestPort – Thank you, glad my Pegasus build has been of use. @ Greg - I will be using your build of Pegasus as an invaluable reference work for my deck plan layout. @ Neill – matrimonial harmony - Good thinking, assists a build no end. 😄 @ Mark – I’m looking forward to enhancing the exposed deck beams with carlings, ledges, and knees etc; B.E.
- 857 replies
- Sphinx
- Vanguard Models
