Posts posted by threebs
- scrubbyj427, GrandpaPhil, mtaylor and 1 other
- 4
- GrandpaPhil and mtaylor
- 1
- 1
- 2
- GrandpaPhil, capnharv2, Mike 41 and 3 others
- 6
- mtaylor, GrandpaPhil and Seahawk1313
- 3
Thank you, always nice to see comments.
- Roger Pellett and mtaylor
- 2
- Seahawk1313, GrandpaPhil, mtaylor and 1 other
- 4
- GrandpaPhil, mtaylor and Roger Pellett
- 2
- 1
- GrandpaPhil, Matt D and mtaylor
- 3
- mtaylor and GrandpaPhil
- 2
- Ainars, Kenneth Powell, Javelin and 5 others
- 8
- Ainars, JacquesCousteau, mtaylor and 3 others
- 6
- GrandpaPhil, CiscoH, ccoyle and 1 other
- 4
- mtaylor, CiscoH and GrandpaPhil
- 3
Both lower gun decks are in as are their gun carriages. Bow sprit base is made as is the bowsprit itself. Main gun deck is planked only where it might be seen through the main hatch and ladder openings in the spar deck. The procedure for weathering the planks is shown. After the and gray are well dried sand lightly with 220 grit and 400 grit varying the pressure to bring out the tan.
- 2
New York has it's first light coat of primer. I use gray so I can draw the cannon ports on with pencil and see them easily to cut out. The garage is around 90 degrees so the paint will dry fast. The bowsprit and rudder holes are in. I will copper the bottom once the gun ports are all cut out and framed. The gray primer actually reacts with the adhesive on the copper tape so it sticks really well! A few were somewhat leery at my hull planking methods. I hope this result quells some of their doubts.
- scrubbyj427, CiscoH, GrandpaPhil and 4 others
- 7
The plans are from the Smithsonian Institute. I do not really need a planking tutorial. My goal is to cover the bulkheads, period. The bottom third is coppered, between cannon ports, chain wales, and all the other items on the hull, once it is painted a few coats of flat black almost none of the planking can be seen anyway. Here are a few photos I selected randomly of some of my other "hulls" for you see what this ship will look something like.
- GrandpaPhil, scrubbyj427, CiscoH and 3 others
- 6
More progress on the New York. One side is planked "painted" with diluted wood glue to seal the seams where I did not super glue them. The yellowish color here and there is the wood glue. I did some rough sanding as well. It will need another glue coat to get the seams I missed the first time. And, as you can see, the other side is almost done. Maybe another week and I can give it a coat of epoxy wood filler. In two weeks I should be able to prime the hull.
- GrandpaPhil, CiscoH, mtaylor and 1 other
- 4
- CiscoH, bruce d, Roger Pellett and 2 others
- 5
- 4
The 74 gun New York was never finished. She remained on the stocks until her destruction in April 1861 along with 10 other ships at Gosport (now Norfolk) Harbor. Research seems to indicate that she was being razzeed in preparation for conversion to a Steam Frigate. This build will reflect as she might have been had she been completed and launched.
- Javelin, bruce d, GrandpaPhil and 5 others
- 8
USS New York by threebs - FINISHED - 74-gun ship of the line
in - Build logs for subjects built 1801 - 1850
Misc. work on the New York
