Everything posted by _SalD_
Hi John, Thanks for the kind words and I'm glad you're enjoying my log. The carronades, as I understand it and by no means am I and expert on the subject, have a two piece 'sled'. The lower sled is pinned to the swivel bracket located inboard of the gun port and has the wheels at the back end. This sled travels in an arc for aiming pivoting at the swivel bracket. The upper sled with the cannon mounted to it slides back and forth along the slot in the lower sled guided by a pin. So when the cannon is fired only the upper sled moves backward and then is 'run out' again for firing. I hope this makes sense and I'm sure there are others on this forum that can give you a much better explanation. added a picture
- 659 replies
- syren
- model shipways
Thanks Augie, sounds like me, got most of my teeth too.
- 659 replies
- syren
- model shipways
Carronade breech rigging. To rig the breech lines I decided to glue all the cannons in place and not do them off the ship, pretty much how it’s described in the manual. After doing three cannons I came up with a procedure that worked pretty well for me. First I made up all the breech lines I needed for the remaining five starboard cannons with a breech ring and eye bolt seized to one end. At the other end of the line I applied some ca glue to stiffen it up to make it easier to thread through the other rings. Next I glued the breech ring’s eye bolt to the bulwark and threaded the line through the left and center breech rings. Prior to doing the right side of the cannon I glued the line to the deck on the left hand side of the cannon as Chuck did in his instructions. On the right side of the cannon I glued the breech ring to the bulwark prior to threading the line through it. I also slipped a ‘zip-seizing’ onto the line before threading it through the bulwark breech ring. 'Zip-seizing'?, you may ask. While reading Brian’s (GuntherMT) AVS log I was intrigued with his use of ‘zip-seizing’ and thought I would give it a try and it worked out rather well. Here’s a link for anyone interested in learning more about it http://modelshipworld.com/index.php/topic/8936-zip-ties-yes-or-no-for-seizings/?p=263833. Before threading the line through the ‘zip-seizing’ I glued the breech line to the deck. Once the glue was dry I tightened up the line on the breech ring and applied some ca to the seizing. Threading the line through the ‘zip-seizing’ was a challenge but with a little patience it can be done. I'm also glad I added the breech rings to the upper sled, it made positioning the breech line much easier. Starboard side finished. Port side done.
- 659 replies
- syren
- model shipways
US Brig Syren by Gahm - Model Shipways
_SalD_ replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
Thomas, I thought about doing that but not for very long, nice work, keep it up. -
Pirate Ship by JesseLee - FINISHED - BOTTLE
_SalD_ replied to JesseLee's topic in - Build logs for subjects built 1501 - 1750
Sails look real nice Jesse, I like the flag too.- 71 replies
- pirate ship
- bottle
Thanks for the information Brian and George. A lot to read and study.
- 659 replies
- syren
- model shipways
Thanks Thomas and Dirk. Need to add her back teeth now.
- 659 replies
- syren
- model shipways
Thanks Augie, I went back and forth on using the supplied ones or buying new ones. I guess you know how that ended.
- 659 replies
- syren
- model shipways
Thanks George, appreciate the compliment, as always
- 659 replies
- syren
- model shipways
Carronades (sorry for the long post) After much reflection I decided to upgrade the carronades from the kit supplied ones to the carronades from Bluejacket Shipcrafters. The kit carronades just appeared a bit small and wimpy. Bluejacket carronades compared to kit supplied ones. The one thing that the Bluejacket carronades do not have is the part of the cannon that the elevating screw passes through. For this part I raided my daughter’s jewelry beads and used a brass crimp bead. To help secure them to the cannons I drilled a small hole in it and glued in a pin. The other modification I made, and I’d like to thank Rod (rvchima) for posting his mishap with these same cannons on his Syren, was to remove most of the lug at the bottom of the cannon. This was done so the cannon would sit lower on the sled to be better positioned in the gun port. I also added a small pin on the bottom of the cannon to help secure it to the sled. Then painted them all The screws used to adjust the elevation of the cannon were made from toothpicks. I chucked them in my drill press a used sandpaper to thin them down. I used a bead to make sure I had the right diameter. The toothpick was cut to length and a small hole for the handle was drilled into it. For the handles I used the scrap shank pieces from shortened eye bolts. All the pieces were then assembled. Carronades are only temporarily placed. I want to drill the hole for the masts before I glue them down. If anyone is still reading I was wondering what peoples opinions were about rigging the cannons. Is it easier to do it with the cannons on or off the ship?
- 659 replies
- syren
- model shipways
Best of luck with the Phantom Edward. It's a lot of fun building this model.
- 32 replies
- phantom
- model shipways
Thanks Thomas and thanks for all the likes.
- 659 replies
- syren
- model shipways
Thanks George. If I take my glasses off and take a step back I don't notice it either (lucky if I can still see the ship).
- 659 replies
- syren
- model shipways
Darn....I was hoping no one would notice...
- 659 replies
- syren
- model shipways
Continuing with the carronade assemble I used my drill press to drill all the holes for the eye bolts. This worked well except I should have paid closer attention to aliening the holes on either side. I used a divider to mark the hole locations but as you can see they’re a little off. I don’t think it will be that obvious once all the rigging is added and as long as I don’t tell anyone no one should notice. Next I glued on all the photo-etched details to each sled and mounted the wheels to the lower sled after painting them. After reviewing some of the other Syren build logs (Gahm’s & Dirk’s) I decided to add the breech ring to the sides of the upper sled. A little more work but I like the way it looks. I have to say, that as I am working on these small parts I have a much better appreciation of the craftsmanship that Thomas and Dirk put into their cannons (and ships).
- 659 replies
- syren
- model shipways
Jesse, I don't know if you've had a chance to look at my build but I tied to explain the different planking patterns, 3 butt, 4 butt and what Chuck used. see link http://modelshipworld.com/index.php/topic/8410-us-brig-syren-by-sald-–-model-shipways/?p=292710. Also the planking is tapered towards the stern not the bow. Your right though, if you don't taper the planks at the stern you should nib them into the margin plank otherwise they will end at a point. I tapered mine so I didn't need to do that. I didn't find nibbing the margin plank at the bow with it glued in place to difficult. I cut the deck plank first then laid it on top of the margin plank to mark where I needed to cut it. Hope this helps.
- 1,306 replies
- syren
- model shipways
I remembered (sometimes the old synapses fire in the right order ) I purchased them from www.hobbyLinc. com. Link http://www.hobbylinc.com/htm/zon/zon37790.htm
- 659 replies
- syren
- model shipways
Small update today. Finished up the inboard bulwarks by stropping the double block to the traveler and installing it above the rudder. Now I'm in the process of getting all the parts ready for the carronade sleds.
- 659 replies
- syren
- model shipways
cpt_d, I don't recall off hand where I got mine but I know I got them in the US. When I get home tonight I can look through my orders and see where I bought them.
- 659 replies
- syren
- model shipways
Thanks Thomas. I had a question for you or anyone else, I am planning to drill the mast holes in the deck and was wondering what size drill bit you used. I'm thinking 3/16" diameter since it's a 5/16" diameter mast.
- 659 replies
- syren
- model shipways
very lightly. decking looks good, nice color.
- 26 replies
- syren
- model shipways
