Everything posted by Landlubber Mike
Non-glossy CA??
Landlubber Mike replied to rtropp's topic in Building, Framing, Planking and plating a ships hull and deck
I haven't seen one that dries flat, but note that using flat or other clear coats will cover up the glue spots. -
One place that I have had some success is Woodcraft (there's one in Springfield). It's hit or miss, but they have a section with 3" x 24" (or so) boards of various thicknesses. I believe they carry boards down to 1/8" in thickness, but again, hit or miss on sizes, species, too much figure in the grain, waviness of the board, etc. I found some sheets of bloodwood that I might try for gun carriages, and padouk that I'm using on my La Renommee build. Another option at Woodcraft is to look at their veneers. You can get long sheets of the stuff that are about the right thickness for planking. For my Renommee, I'm using cherry veneer that I found there that worked nicely. You can also find dowels in various woods and diameters at Woodcraft. I picked up a bunch of nice dowels in cherry and walnut for my Renommee and a future build. Just make sure that you check for straightness as many were a bit wavy. I rolled them on the floor to see if they rolled smoothly or were bumpy because of warping. Big loss when Hobbymill and Crown left the business
Thanks! Yeah, good learning experience for me. Part of the problem is that I was getting dry tip, so more air was shooting out than varnish, which probably accelerated things before the varnish could level. I saw a few videos where folks were suggesting adding a retarder is necessary for that product. Never needed to on their paints, but looks like the varnish is a different animal. From a normal viewing distance it doesn't look bad, just when you are up very close you can see it. What do you think of the look on the cowl? Too wet looking? I was thinking of perhaps spraying Gunze semi-gloss clear coat on it - the rattle can is fantastic and nicely self levels. That would tone things down a bit and possibly help smooth out some of the orange peel effect.
Really nice work Joe! I love the lettering - looks fantastic! Did you find that you had to double up on the white lettering or was a single decal sufficient on the black hull? I stopped working on my Charles Morgan because I haven't quite figured out how I was to do the lettering. Dry transfers are going to be too difficult to pull off I think, and I didn't want to glue paper to the hull. I've reached out to a couple of custom decal shops to no avail. I might just try to use single letter decals like you did, and just take my time to get them into the right position. I was worried about getting them spaced and lined correctly, but it looks like it can be done. If I can't do it, maybe I'll send my hull to you to decal
- 140 replies
- benjamin w latham
- model shipways
Very nicely done Chris, great job! Agree with druxey that it's nice to see something a little different on here.
- 179 replies
- shipyard
- wütender hund
Thanks for the likes and the kind words, really appreciate it. I used some Vallejo dark gray wash to add a little more depth to the panel lines and other details, except for the top wing where I used Vallejo dark yellow wash to break up the solid mass of yellow and highlight the ribs a bit. I put a bit of wash on a thin brush and ran it down the panel lines, etc., then used a damp Q-tip to wipe most of it up. I didn't want to get into weathering the planes to preserve the bright colors, and would note that these planes didn't really see any action so they tended to be maintained in a pretty good condition. I quite like the effect which tended to highlight panel lines from certain angles, and not be very stark as you see in some models. Here are some pictures - sorry, the lighting is not the best where I took the pictures. I sprayed the fuselage and the aluminum sections of the wings with Vallejo Metal Varnish. It's kept the shine of the original Vallejo Metal color paints, but is making the non-aluminum sections like the cowl and belly bands look a bit wet and not smooth in finish (though, it gave the red and blue a very rich tone that I like). Not the best picture in the world, but here goes: I found that spraying the Vallejo Metal Varnish, the airbrush was prone to dry tip. Had to clean out the nozzle a few times, so I probably should have added a retarder. 😐 Wondering if I should have masked off the cowl and belly band and added a different clear coat from the start, but was interested in seeing how the Metal Varnish would look. There are some videos on how to spray Vallejo finishes so I will have to check those out as well. Can't really see the wet, bumpy look on the aluminum, but the cowls and belly bands bother me a little. Not sure if I'm going to leave it as is and call it a learning experience, or try to touch up the cowl and belly band by spraying a semi-gloss clear coat. I've been using the Gunze clear coats and they spray perfectly - excellent coverage, self leveling, etc. Not sure if I want to get into taping off the aluminum sections, but I might try it out. A little tricky with these colorful planes as I'm not quite sure if the non-metal colors should be equally glossy as the aluminum or dialed back to semi/satin gloss. I'm thinking using semi-gloss on the red and blue sections might be a good approach. I ordered an Olfa circle cutter that should arrive this week so that I should be able to cut masks for the insignia, which I would also spray semi-gloss. Thanks for looking in!
Yves, thanks very much for the kind words. For the insignia, I used the following set from Montex which makes things a lot easier: Here are the steps I took: 1. For the yellow top wing, after priming with Mr. Surfacer 1200 spray primer, I then sprayed with Tamiya white primer (from the rattle can), followed by Tamiya Camel Yellow (decanted from the Tamiya rattle can). For the lower wings, I sprayed with Mr. Surfacer 1200, then followed up with Vallejo Gloss Black primer (recommended for use as undercoat when using Vallejo Metal color paints), then sprayed with Vallejo Metal color (I believe I used white aluminum for a slight color different from the fuselage where i used aluminum). 2. Next I painted the decals. I started with the square mask (e.g., on the upper right corner of the green sheet), but left the interior circle out to be able to paint the underlying white disc. For that, I believe I once again primed with Mr. Surfacer 1200 (as white can tend to show underlying colors like yellows and reds), then sprayed Tamiya white primer. That left me with white discs. 3. Next I painted the blue background of the insignia. Leaving on the square mask, I took the star and added it to the disc to seal off the white star of the insignia. Then I sprayed with Vallejo Arctic Blue. 4. Last was to paint the red circle in the middle of the star. I removed the square and star masks I used in steps 2 and 3, and then used the circle masks (e.g., on the upper left corner of the green sheet). I placed the open circle in the middle of that mask onto the white star, and then had the red circle. For that color, I used Vallejo Red. The Montex mask is a bit translucent, so you can easily see where you need to position it on the star so that the circle is in the center. Those were the steps that I took, maybe there are other ways to do it. Some tips and other experiences to pass along if anyone is a masochist and wants to paint their own insignia: 1. Make sure that you burnish the edges of the masks as much as possible just before you actually paint. The white discs worked really well. I had some bleed under with the next two masks quite likely because (a) I did not take the time to burnish them as well as I did with the white disc mask, and (b) I might have sprayed too heavily, when I should have just sprayed a few lighter coats (big lesson for me!). I almost cried when I lifted them and saw that the blue and red had run under. Interestingly, the top wings were fairly blemish free. The bottom wings on the other hand look horrendous. 2. Thankfully, with the Tamiya synthetic lacquer white undercoat, I was able to take a wooden toothpick and gently scrape off the Vallejo colors that had run under the mask. The paints still left a very light stain, but was much easier to paint over the stained areas than if the full paint remained. Touch ups were done by hand using the same paints. 3. I thought I was being smart and added the radio PE parts to the upper wings so that I could prime and paint them yellow along with the rest of the wing in one shot. Problem I soon discovered was I had a really rough time adding the disc mask to the wing because that PE part was in the way. I ended up having to add a small slit on the mask to let the mask lie as flat as possible on the wing (essentially the PE part sticking straight through). A bit of paint went through that area, but was fairly easy to touch up. 4. Each time I painted, I left the mask on for 24 hours for the paint to cure. I was particularly worried about the Vallejo which can get pulled up from masks I've found. Happened again here. Decals make things much easier obviously, and you are left with very crisp edges. Painting gives you a little more freedom on colors, and I think can look a little more vibrant. You also don't have to worry about decal issues like color mismatches to other similar colors on the model, bubbles, rips, underlying colors bleeding through, etc. I tend to like a challenge so I might try painting them again sometime. On this model, I could have also used the Montex masks to paint the numbering along the belly band, and the smaller insignias on the front of the F3F-2 fuselage. I decided not to as I didn't want to potentially ruin the aluminum finish that I had on the fuselage, and figured I had already used up a lot of luck in getting to where I already was. Hope that helps!
I'm moving along fairly quickly on the Tamiya Citroen 2CV kit, and am more than halfway through the instructions at this point. The fit and design are better than the Airfix kit, and you can tell that Tamiya set up the kit in a way to make construction more solid, easier to paint, etc. One other thing that's nice about Tamiya is that the bumpers have a black band running in the middle of them. I had a hard time painting a crisp line on the Airfix kit given that the plastic wasn't perfectly smooth. Tamiya gives you black decals which make things much easier. Tamiya also gives you the option of presenting the model with an open or closed roof, and I believe you can flip the windows to an open position. I decided to go with a french blue exterior/gray interior (like Tom's cousin's car pictured above, but without the white hood). For the exterior, I once again went with Tamiya - french blue in the rattle can - but this time decanted the paint and sprayed through my airbrush. Much cleaner spray than spraying directly from the can. For whatever reason, the Tamiya cans seem to like to spit, which is a pain because then you have to sand or otherwise remove blemishes and then try to repaint. Decanted, it sprayed super smoothly in pretty much one coat. On the Airfix, I spent a ton of time going back and cleaning up the spit and other issues, respraying, and repeating multiple times. The rest of the car I'm using Vallejo acrylics. I like the ease of use and clean up of Vallejo a lot. For a car exterior, however, I like the harder finish of the Tamiya synthetic lacquer, which probably holds up better to my brute handling of the model during assembly. Vallejo also can be weird about peeling when being taped at times. Tub: Chassis - nice that all four tires are sitting evenly on the ground unlike my Airfix kit Behold! The mighty 29 horsepower engine! 😆 With the chassis and tub done, really all that's next is to add all the details to the body (and a fewer remaining details to the engine compartment). Tamiya has you add the body to the chassis, then add the details. I think I'm going to first add most of the details aside from things like the windows, then spray the clear coat, then assemble. I figure I might as well have a consistent clear coat on the model without worrying about getting clear coat on areas it shouldn't go like the tires, and the clear coat can generally cover up any extra glue marks. Thanks for looking in!
On the home stretch now. Finally got the cowl on the F3F-1 all straightened out. After stripping the paint, priming with Mr. Surfacer gray, followed by Tamiya white primer, I added the Vallejo red. Then I taped and added the aluminum band (Vallejo gloss black primer followed by Vallejo Metal aluminum). Everything was looking great when I started pulling the tape off, except I got a weird 3mm or so line of black paint on the red. Argh! Have no idea how that happened, except that it might have come through some tape when I was airbrushing the interior of the cowl. I tried touching it up with white primer and followed by red, but it was noticeably whiter. Another argh! I tried a different approach of lightly sanding off the new red, white, and black to get back down to the original white primer coat. Then I had to re-tape and spray the red a couple of coats across the full cowl to even out the color, and finally the modeling gods were with me and everything worked out. Then I was able to add the pinstripe (need to touch up a tiny spot that seems to have ripped), so the F3F-1 is finally, after all the cowl trials and tribulations, caught up to the F3F-2. Everything is pretty much painted except for the canopy pieces. Next up is some very light weathering/shadowing/highlighting (to keep the bright look of the planes), final clear coat, and remaining assembly and rigging. Wings came out fairly well too - the numbers and pinstripes along the chevrons are decals, the US insignia markings are painted on: Looking ahead, I'm next going to work on the Tamiya F4F-1, to be converted to a FM-1 (same plane really, just made by a different manufacturer with different gun specifications) with a wing fold set. I have the Aires full resin detail set for it, which will add a layer of difficulty, but the paint scheme will be significantly less complicated than these yellow wings. I'm glad I tried painting the US insignia on these F3Fs rather than using decals, but that made for a ton of extra work. Famous last words, but the FM-1 should be easier, at least in terms of painting. Thanks for looking in!
Thanks, really appreciate it! I don't think that these are Accurate Miniature reboots of older Monogram kits (unlike the F4B-1 and P-6E boxed set I put together a couple of months ago). Aside from the tricky landing gear assembly (that you have to turn three different ways to pop it in), the kit has been really great to build and I highly recommend it. They pop up on eBay from time to time for reasonable prices. I don't think the aftermarket is necessary, the kit is great on its own. The Eduard PE set looks great when you're putting the cockpit together, but then you can barely see any of the details once in the fuselage. Those tabs do need to be cut off. I've left them to help handle the models as you noted. Keeping them on for now helps too in avoiding getting paint on that area in case I want to use plastic cement as opposed to CA (I might just use two-part epoxy to lock everything in). Thanks Lou, appreciate the kind words and you looking in. I've pretty much got everything but the canopies painted up and ready to go, but ran into a bit of an issue with the cowl on the F3F-1, needing to strip off the paint and start over. So far, the red has gone on nicely, and last night I taped and sprayed gloss black as the base for the aluminum section of the cowl. Fingers crossed that the masking this time works! I burnished the tape with a toothpick, sprayed a lighter coat of the black, and hung the part to dry with the tape side high so any extra paint hopefully will flow down by gravity and not under the tape (hopefully any potential capillary action is not stronger than gravity!). I find the Vallejo gloss black primer takes a while to cure, so I'll give it at least a full 24 hours before spraying the aluminum. In the meantime, I started work on the canopies. I dipped them twice in Future, and started the taping process last night. Not a fun part of the build! The canopy parts are so small. I have Montex and Eduard sets, but they seem to only fit the F3F-1 (the F3F-2 has a different size and shape to the canopy). Also, for some reason the masks for the rear section don't have and opening for the midline of the framing. I think I'm just going to paint the canopies by hand in stages using the masks where I can, and otherwise using tape. I don't think I'm going to make my own masks and then try to airbrush them, the canopy pieces are just too small.
Looks great Grant! Good to know about spraying it - I tried using the pen on my Citroen 2CV, and it's a bit tricky. You need to be very careful and not go back over your work or the finish will look wonky. The pens generally have good flow, but from the one time I used them, at times the flow isn't consistent. I'll have to try out the airbrush approach. Also agree on the longer drying time. I found that to be the case with their black pens as well.
Nice choices! You won’t be disappointed!
- 40 replies
- best airbrush
- compressor
Thanks Pete, I’ll have to try that! just out of curiosity, how much paint does a Tamiya rattle can hold? About the same as one of their larger jars?
- 40 replies
- best airbrush
- compressor
Hang in there Chris we feel your pain 😀
- 179 replies
- shipyard
- wütender hund
I believe there were slight modifications to the guns and bomb racks, and possibly wing shapes. I think I have the Wolfpack wing fold set for it. Thanks for that picture, looks really cool! The kit I won came with the mega detail Aires set which includes a super detailed resin engine, so I might leave some of the panels off to display the engine like the one in your picture. A little more boring of a color scheme, but after the four yellow wings, I’m looking forward to working on something a little different.
Thanks man, really appreciate the kind words! These make for cool colorful little planes and the Accurate Miniatures kits for them are very well done. I have some other US planes in the stash (WWII era) but the coloring is a bit more drab with just blues and grays. Speaking of the other kits, I have the TBF-1 Avenger from Accurate Miniatures, SB2C-4 Helldiver from Pro Modeler, and the F4F-4 Wildcat from Tamiya (that I will like convert to a FM-1 Wildcat with a wing folding conversion set I found). I picked them up off of eBay as packages with full aftermarket accessories, so that should be an interesting jump in building for me. I was going to do the Helldiver next given that the box is very big and taking up a lot of stash space, but I’ll probably start the Wildcat next, given that the box is falling apart.
Thanks for all the kind words guys. For my second pair of plane models, I am liking how they are coming out. I've learned that painting reds and yellows are tricky, as they are very apt to be affected by any colors underneath. I tried repainting the red cowl on the F3F-1, but it was just looking messier and messier, so yesterday I decided to strip off all the paint and start again 😤 So, once again used Mr. Surfacer 1200 rattle can primer (gray) for the base coat, followed by Tamiya white rattle can primer to give the red a nice base. A few minutes ago I sprayed Vallejo Air red. I'll give that 24 hours to dry, then tape and spray the black gloss primer followed by Vallejo Metal Air aluminum for the cowl's aluminum band. For more positive news, after more hours of work than I would have expected, I added the decals to the F3F-2. Am very happy with how this one is looking! This was a little more different in that I was going for a different plane than the stock one in the kit, which meant that the 7-F-7 and 1028 markings were all done using individual decals for each number/letter. The kit's decal sheet includes lots of extra individual numbers and letters, which gives you lots of flexibility. Interestingly, the F3F-2 did not have the grasshopper insignia in it, but the decal sheet for the F3F-1 had it. The grasshopper decals in the Yellow Wings decal sets could have worked, but I liked the colors a little better on the kit sheet. Also, rather than painting the US insignia on the front of the fuselage, I went ahead and used the kit decals. Masking that area would have been a nightmare, and I didn't want to press my luck too much given that I had painted the insignias on the wings and they came out decent. Finally, the pin striping went on much easier than with the F3F-1. Per the Micro Set instructions, I was brushing on Micro Set onto the model prior to adding the decal, and then added more Micro Set on top. The Micro Set makes decals get soft quickly, which can be a problem when dealing with long thin decals like the pinstripes. This time around I worked with water only, and then when the decal was positioned in the right place and a bit drier, I used Micro Set (in some cases, I followed up with Micro Sol when I was sure that the decal was set and positioned correctly). That made adding and positioning the decals a lot easier. Here are the two planes side by side. I don't have the best lighting set up, but I would say that the aluminum fuselages are probably somewhere in between the two planes (maybe a touch darker than the F3F-1). I'm liking the bright bodies, so I think I'll just add light applications of washes to the panel lines to add some depth and highlight things, and call it a day. Thanks for looking in. For those in the US, happy Labor Day weekend!
