Everything posted by Landlubber Mike
Another masterpiece, wow! Very nice job! For the railings, I see the PE stanchions. Are the railings themselves brass as well, or are you using some other materials (thread, monofilament, etc.)?
Thanks man, really appreciate it. I was mistaken - I have two Montex sets, and the Montex sets also have stencils to add numbering to the plane belly. So, maybe I'll try painting the insignias and numbering, leaving the decals for the squadron markings and the tiny identifiers on the tail. It seems there are those out there that prefer to paint insignias and other markings, so I might as well try it out and get some practice.
It reminds me of Gilt Cream, which I used on some wooden magic wands that I made for my girls this past Christmas. Imparted a great metallic finish with a lot of richness and character that I didn't think I could get using paints. I'm looking forward to trying out gilt creams on wooden models with carvings that are gold, silver, bronze, etc.
Here's a question - for the US insignia decals, is it worth painting white disks onto the top of the yellow wings so that the yellow doesn't show through the white part of the insignia? I noticed on my last pair of models that there was a slight yellowing, which was ok because I weathered the planes a bit. For these, I might try to keep them bright and shiny so I'd like the white to be nice and bright. Any suggestions on how to do this? I did find a Montex set of masks that allow you to paint the insignias. I might try that, though I only could locate one set so would only be able to paint the insignias on one of the planes. Not sure I want to necessarily go that route as I would have to paint six insignias per plane - two on the fuselage, two on the bottom of the lower wings, and two on the tops of the yellow wings.
Thanks for the tip Craig. Sorry, didn't realize you had commented. I made a bit of progress the last few days and pretty much have almost everything painted up except for the aluminum bodies of the fuselage. I did go ahead and spray the belly bands first, as I've heard that Vallejo Metals don't like to be taped. I used the Tamiya white spray primer which went over the Mr. Finisher 1500 very nicely. No issues with spitting, etc. from the rattle can. For the white tail of the F3F-1, I used Tamiya insignia white straight from the rattle can and also had no issues. I'm also happy to report that using Tamiya's TS Camel Yellow (decanted and straight with no thinner through the airbrush) went on very nicely. Much better experience than mistakenly using the PS rattle can (for polycarbonate RC models) on my last builds, which needed a number of layers to cover the gray plastic, and tended to spit. I'm taking my time between painting steps to make sure everything cures at least 24 hours before moving on. I noticed that the Vallejo Glossy Black primer needs at least that amount of time as it tends to remain a bit tacky unlike the Mr. Finisher and Tamiya primers which dry to the touch very quickly. Unlike the last couple of planes where I assumed everything then tried to mask and paint, this time I'm painting the different colored parts separately, and then will assemble. It wasn't particularly fun trying to mask all the parts, especially when I had glued things like the fin stabilizers. It sounds like the remaining parts should fit cleanly together (that's generally been my impression of this kit so far minus the top of the fuselage), so fingers crossed.
Great start! You're going to have fun with all that PE - that's a ton in that Flyhawk package.
Bob, I use micro mesh pads when turning pens. After applying a CA finish, I'll wet send with the micro mesh pads starting at the first pad and going to the last pad. Now, I'm usually using the pads while turning on a lathe, but I would note that (1) I don't press very hard, but let the pad do the work, and (2) the grit levels on the pads is not comparable to sandpaper grits. So, for example, 1500 micro mesh is actually a lot coarser than 1500 sandpaper. On pens I can start with 1500 because the CA is a lot harder than paint. If I was going to use them on a paint or thin finish, I'd probably look to start at a higher pad.
Grant, exceptional work! Thank you for sharing - I'll be bookmarking your log for when I start mine. Sorry for a slight diversion from your log, but I noticed you mentioned the Vallejo Metal paints. I haven't had any problems with the Gloss Black primer thus far, though I noticed that it tends to dry in the airbrush fairly quickly. I haven't had to paint much with it so haven't tried using Flow Improver yet. I really like the Metal Color paints though, which spray very nice and clean quickly in the airbrush compared with the Model Air line. For the Metal Varnish, is it worth using? I am coming up on painting aircraft bodies using Metal Color aluminum. I was probably just going to use Future to coat for decals, and then spray with a semi-gloss varnish.
It's probably hard to make out in the pictures, but there is a bar that attaches from near the firewall to the tops of the suspensions. Interestingly, the kit part didn't include long enough bars so I had to replace them with longer rods. Interesting info about the suspension of these cars! The upholstery seems to be used in the "Dolly" models in the mid-80s (this kit is the Dolly version). I believe these cars were marketed primarily to women with the two toned body colors, but maybe they also had to add more comfortable seats than the traditional fabric draped over a steel frame. Here are a couple of interior shots for Dolly versions that I found online.
I've been fitting in some work on the Citroen over the last few weeks while primarily working on the F3F builds. I've got the chassis set up with the engine, and have a lot of the other assorted parts painted. Just need to start putting things together. I think I shared some of the pictures before, but here are some current ones. I've used light and dark grey washes to break up the solid sections of black, and brown washes to add depth to the seats and interior. I'm wondering about doing that for the body of the car too. If I do, it will have a different look than a "showroom new" model, which I think I'm fine with. The Tamiya dark yellow looks nice, but kinda plastic. I was originally thinking of spraying on a few layers of gloss clear coat and then buffing it to a nice shine, but I'm not sure that would really fit with this kind of car. So, I might just add washes and then use a semi-gloss or gloss clear coat and call it a day. I have some other car models where a buffed out clear coat would be a lot more appropriate. One part of the kit that I've been thinking about modifying is the grill. The instructions have you painting it black and picking out the gratings and frame in grey. What I'm thinking of doing is actually cutting out the plastic between the gratings so that it looks more realistic. Could be a disaster, but I might as well try. I have some generic PE grills from Modelcargarage.com that could be a last resort if it's not working out. The piece is a bit thick, so it might be a little tricky. I'm thinking of using my micromotor to route out as much as possible, and then use an X-acto to clean things up.
Anyone have any experience using Tamiya spray primer over Vallejo acrylics? I'm a little nervous after applying Tamiya's rattle can yellow paint over some errant black Vallejo paint as touch ups - the Tamiya paint tended to dissolve the Vallejo paint and essentially made the yellow look dirty. It could have been the fact that I was mistakenly using Tamiya's polycarbonate paints for RC models (the PS line, and not the TS line as I should have), which might run hotter than the TS line. Instead of using decals for the belly bands, I'm planning on painting them. Right now, I've primed the various parts with Mr. Finisher 1500, and I'm planning on painting as follows: -- For the yellow top wings of the two models, I'm planning to spray Tamiya white primer to give a good base, and then spray the rattle can Tamiya camel yellow. Then for the chevrons, I'll tape out the outline, re-prime with Tamiya white primer, and then spray the red or blue Vallejo colors as applicable. -- For the red and blue markings for the cowl, belly band, and tail, I'm also planning to spray Tamiya white primer as the base, followed by Vallejo acrylics for the two colors. -- For the aluminum finish for the bodies, I will start with Vallejo gloss black primer, and then use Vallejo Metal Color. -- For the black tail on the F3F-2, I'll just use the Vallejo gloss black primer. What I might do is start with the yellow, red and blue colors, which means I'll be applying the Tamiya white primer followed by the applicable colors. For the belly bands, I'll go slightly wider, and after priming and painting the color, maybe I'll seal with Future. Then I'll mask the belly band at the appropriate width, and spray Vallejo gloss black primer, followed by Vallejo Metal. I've read that the Vallejo Metal sometimes doesn't mask too well, so after trying to map this all out, I think this is the right way to go as I won't have to worry about spraying Tamiya on top of the Vallejo. Any thoughts of course would be very welcome!
I've made some good progress on the F3Fs the past couple of weeks. The bodies are generally assembled, minus the wings and cowls and some detail parts which I will paint separately: I've got everything primed and ready for paint. The assembly was fairly straightforward, with very little filler needed. Couple of quirks as other builders have noticed. The bomb bay doors essentially get slid in between the two A frames for the landing gear, turned 90 degrees, then turned up and popped into place. Was not easy! Eventually figured out how and where to file some tabs and they slid in much easier. The second and probably tougher part of the build was attaching the landing gear itself. At the wheel section, there was a groove to fit against a bar at the bottom A frame, and a few millimeters above, a small hole to fit a tiny stub on the upper A frame corner. At the other end of the frame, there is sort of a triangular depression to fit against the frame of the plane. Everything is under tension to keep the A frames properly spaced, but none of these three contact points had any way of locking the landing gear against the contact point. A huge pain! Had to use CA to get the bottom points relatively secure, and when almost dried, glue the top. I broke one of interior rods of one of the A frames and had to scratch a new one - thankfully I didn't need it to apply tension to get the landing gear oriented correctly. For something I thought would take 20 minutes before bed, took me close to 3 hours for the two pairs. Lots of not-so-nice words and little sleep... I think I've decided to go with a red cowl/belly band/chevron with the Felix the Cat insignia for the F3F-1 as seen on the box art, and the VF-7 insignia (is it a a wasp? ant?) with black tail and blue cowl/belly markings.
Nice choice Popeye! I have the 1/32 Hasegawa kit on the shelf. Will follow your build closely! From what I recall reading when I bought my kit, the Stukas were modified to be tank hunters to be more effective on the eastern front against the Soviet Union. In the earlier years of WWII, they were dive bombers and had that very eery air siren when they went into their dives.
It's actually a nice kit with good components. If you add a stern post, and make some changes to the location of the figurehead and the quarter galleries, you can greatly improve the kit with little work. I just had a problem trying to convert it to the Lyme - couldn't transfer measurements from the Lyme plans to the hull because the measurements of the Unicorn differ considerably in some places from Chapman's Unicorn plans. Good luck!
Oooh I thought it was card, my mistake! Really nice - excellent job!
- 179 replies
- shipyard
- wütender hund
Man that looks like real wood. Really well done!
- 179 replies
- shipyard
- wütender hund
