Everything posted by kirill4
Michael, you are a very modest person! Perhaps such things for the participant are happening unnoticed, but from the outside the difference is very obvious !!! Rex makes his rigging differently, not as detailed as you ... if you follow the link that Mark left, this difference is obvious ... So that's great ! The more good models and ways to create them the more interesting !!! All the best!!!
Good day, Thank You very much for information about process and of using threads ! Is clear now!Very informative! All the best! Kirill
Michael, Please give a light , What do You use for making your crowfeet, which thread? Looks pretty good ! What is it...maker ,p/n, etc.? Could You make sometimes really macro shots of some most complicated spots where You spent most of the time for rigging ... for me would be interesting to see how did You manage rigging of that topsail halyard spinnkloben which is in my opinion very fragile part but difficult to see how You did it?
Thanks for the link Marc! may be there were some private issues why he decided to leave all that platforms ... good to hear that he is OK and continue building his models
Hi Michael! Great job! I dare to notice that you have already surpassed the Rex Stewart in the skill of rigging work!😲 The general detailing and accuracy of the extension of the binding of blocks, crowfeet, deadeyes, even for a larger scale, would be worthy, not to mention such a small one in which you are now working! Keep it up!
Good day, Thanks wefalck , it is interesting fact that "... precious decorations were actually removable at least on some types of ships." I knew that there were some troubles due to weights and sizes of the decorations... but didn't realise they could be removable in some cases... All the Best! Kirill
- 2,652 replies
- heller
- soleil royal
(and 9 more)
Roter Löwe 1597 by Ondras71
kirill4 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Good day, Dear Ondras, Such clean and beautiful work! Watching your build with great pleasure! All the Best! Kirill -
I see. now.. it was about stay twisting /I didn't have such experience with stay, I had that crows feet legs twisting a little when pulling them trough the stay ! You are right than angle "needle-stay" is very important! and also size of the needle - it must be special very thin needle! I used small long noise pliers to keep needle at right angle and pincet to keep stay steady at the penetration point ... Which tools did You ? I meant thereis no strait contact between fingers and threads ?... and Yes ... in this small scale which You work with ,materials could "feel" and act very differently compare to the larger scale like mine 1:100 ... there could be effect of different rope treatments which makes effect on the process as well ... my stays and shrouds were heavily painted before installation and became quite hard .... they became almost like lead wire or very soft copper wire/ the advantage of this thread condition that it keeps "strait" shape with min load required ... but threads which I used for making crows feet were unpainted at this "needle" stage remains very soft and flexible and passes easily trough the stay ... than all construction were balanced with weights , all necessary leg's lengths were adjusted, than legs were plated by "extra liquid CA " and on the next day after complete drying , all legs excesses under the stay were fine trimmed and I made imitation of crows feet legs knotting to the stay by separate very thin mono thread( it makes more accurate imitation of knotting compare to the same size thread , if try to use it for knotting imitation) ... and finally all were painted to the existing rigging color... purpose to use weights(under the stay) + counter balance weight (loaded other side of the back stay-crows feet unit) and very liquid CA - to make crows feet legs strait shape and to fix this strait shape without phisical ly loading them when weights and counter balance weights will be removed - imitation of gravity forces .
Good day Michael, Your crows feet finaly looks pretty good! When you first try to make them with needle, did You use weight for each leg as well and super liquid CA to aplly on them, while they were under weight ? Just You mentnioned they were twisting... these weights and liquid CA solved my problem with twisting... but Your plan B does good job as well !!! All the best! Kirill
Good day, Some digital CS drwngs in high rez. may it will be more handy to read text on the drawings https://cloud.mail.ru/public/BPpQ/wHjjVFTtz
- 248 replies
- Cutty Sark
- Revell
Thanks Bill ! I see , now is clear, must be good stuff!
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Bill for reply , clear - gold leaf. All the Best! Kirill
- 1,508 replies
- Le Soleil Royal
- Heller
Good day Bill, What do You use for gilding of your figures ? All The Best! Kirill
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Bill , It looks as they are what I need as well ! need to buy them
- 1,508 replies
- Le Soleil Royal
- Heller
Oh! Bill! while I was trying to make readable text in google translator , You already answered my questions!!! :))) ... look at my modified previous message - about reproductions...It will very interesting to know your opinion about if we could to use that stuff which Doris use for making her decorations , for making sample for further reproduction copies in resin ?
- 1,508 replies
- Le Soleil Royal
- Heller
Sorry, Bill I just read your post 439 - that reproductions are planned ... Then of course there are no questions If only, maybe more convenient and more accurate on scale, if you first make a sample of the decor from this sculptural hardening mass and after polymerization in the oven, even then give the final shape using a model knife? And then make the required number of copies from this sample? Edited 49 minutes ago Kirill4
- 1,508 replies
- Le Soleil Royal
- Heller
sorry , but that decor she made , it is out of scale - remains too big, if compare to the original kit decor which could be seen on the photo... what if just sculpturally create a sample from that Doris magic sculp stuff as much close as possible to the original design , and after backed it in oven , than to cut by rasor nife to the desired final shape... doing this phase which she is busy now only once , and than, just to start making copies from epoxy or special casting resin?
- 1,508 replies
- Le Soleil Royal
- Heller
Good day, very interesting in this decoration making... Bill, Marc, what do You think if make one fully detailed and scaled element of decor , made it from that oven hardened stuff which Doris uses for her decoration, sorry I forgot the name of it... and than, just try to reproduce it in copies as much many as we need - make matrix and use epoxy for reproduction? I 'm just crying looking at this girl ... to make one element is ok, but it looks she wants to make it again and again... ? or what is the idea ? All The Best!
- 1,508 replies
- Le Soleil Royal
- Heller
Good day Michael, Looks just great!!! and your choice of rigging color as well! All the best!
some funny things from our seamen life... recently one of my colegue shared this video ... this guys , instead of gulls , they are brave ! They are traveling from ship to ship in big group and try to find where is food for free, ... they have funny faces :))) and even can bite if someone crossed private borders ! :))) .... the Chief Mate asks them to go away because they shitted all over deck of his vessel and hide fish in wrong places... but they don't agree with his demands https://cloud.mail.ru/public/iJn8/pjcR49xRR
- 228 replies
- spanish galleon
- lee
Once again I would like to return to this briliant work of Michael D. - look at this magic transformation plastic in wood by using simple stuff... if it so easy, why everybody do not do the same? :)))
- 137 replies
- Golden Hinde
- Revell
To remove paint from plastic , many use a “mole”- this is a special liquid, usually used to clean the clogs of kitchen and sewer pipes, the name will differ in other countries of cause ...
- 137 replies
- Golden Hinde
- Revell
