clearway
Everything posted by clearway
  1. if you look at the plans they are for the sheaves that take the sheets for the main and fore courses along with the main brace
  2. Looking great so far- If memory serves me right Crozier had the iron midships davits removed though. I modelled my terror like that but left the mounts for the davits in place on the outside of the bulwarks. Keith
  3. nice one Keith- i never realised they had steam engine controls in the wheel/ pilot house - would cut out the need for an engineer as well as a fireman in the boiler/engine room. Keith
  4. as with the glue, polish the aluminium before painting- i would agree and recommend applying a coat or two of matt varnish as well when paint has fully cured. Keith
  5. Nice Keith- i take a couple of days away for the steam gala at Keighley and she has sprang forwards leaps and bounds. Keith
  6. i used self adhesive copper tape on my Terror and Erebus, but either super glue gel or bostik should work- be sure to polish the Aluminium first though before gluing to remove the oxidised layer off the surface. Keith
  7. Thanks and nice terror build- i will keep the upper deadeyes about the same distance apart as i found on my Terror when installing the boat davits on the outside of the bulwarks the upper deadeyes interfered with them. Keith
  8. welcome to the Endurance club (really should kick start my build again)!- don't worry about making alterations, just go steady and think it through and you will be fine, and if worried about "another endurance log" just check the amount of Constitution and Victory logs on here 😉, Keith
  9. That makes more sense Keith- my mum god rest her soul called them 'senior moments'! Keith
  10. slap me thrice and hand me back to me mother this is going to look awesome Keith
  11. you are welcome- it is good seeing a different take on the diorama as most i have seen show the ships ice bound or in open water- looking great so far. Keith
  12. She certainly looks the part- i have heard the two ships were merchant rigged regards running rigging and Matthew mentions the large iron truss still attached to the foreyard so i will be fitting an iron swivel truss to my Erebus (i rigged my Terror with chain trusses navy style) and would alter the way the yard halliards / tyes are rigged. as regards the flying jib it would not be furled on the flying jib boom which is why you don't see it on illustrations and the boom would be run out if it was needed with the sail then run up. Keith
  13. Thanks for looking in- have started putting the eyes in the decks around the masts and also between the helm timbers for the blocks to guide the steering ropes from the drum on the helm to the blocks on the bulwarks which take them to the tiller (eyebolts fitted for those too), also fitted the timbers midships for the boats to rest on (don't know why Occre have them on gallows)? Also fitted the Kevels for the main and foremast yard halliards. still need to fit the eyebolts with the rings for securing the anchor chain. Take care all Keith
  14. 7mm is close enough - in full size terms you are only talking around an inch - i made my bowsprit around 7.5 mm diameter tapering down to around 6mm towards the cap Keith
  15. once finished this diorama is going to look awesome- regards masts, rigging etc i used James Lees 'Masting and Rigging of English Ships of War' Keith.
  16. the doubling at the mast head (from the top to the mast cap) should be around 4-5 times the diameter of the mast head- yes you can see on Matthews plans that the doubling is about twice what occre give- on my Terror from the top to the masthead is around 35mm on the fore and main masts and a little less on the mizzen. here are the lengths in feet of the bowsprit and lower masts (outboard for bowsprit and above deck level for masts) from the 1838 admiralty order for a 10th rate frigate which the mast diameters tie in with (occre actually got the topmasts bang on)! bowsprit 29' - 22 1/2" dia. foremast 48'6" - 22 1/2"dia. mainmast 53'6" - 24" dia. mizzen mast 43' 6" - 18"dia. taken from Lees 'Masting and Rigging the English Man o War' hope this helps Keith
  17. good feeling when the whisky plank goes on! regards bowsprit 11mm shouldn't really make much difference to be honest- another thing to watch out for is the mast doubling which needs to be more than occre give. Keith
