Everything posted by clearway
where as occre have the bowsprit going over the top of the bulwarks with the new location it goes through the bulwarks more or less at deck level Keith
- 72 replies
- Arctic Exploration
- Erebus
if you look through my Erebus log there are pics of the modified bowsprit - just move the holes foreward , the angle is about the same. as regards the mast sizes - foremast is 7mm and mainmast 8mm- you should check out mine and Keith s HMS Terror build logs for more info as well, but at the end of the day it is your build and you are the shipwright in charge, just altering the mast diameters and adding the deckhouses makes a huge difference. Keith
- 72 replies
- Erebus
option 2 is the best option- looks better with the fuller frames doesn't she- also don't forget the holes for the mast holes on the main and fore will need widened if using right diameter dowelling and alterations to the slot for the bowsprit if moving to correct position as in my build log. Keith
- 72 replies
- Erebus
best way is to hold a planking strip across a few frames when trimming down to find any high spots- it was me who said you could reduce frames 6 & 7 as an alternative to save building new frames but a very rounded hull would result. Keith
- 72 replies
- Erebus
Yey another Erebus build at last- there are planking tutorials on MSW, just remember the planks taper fore and aft- how occre, amai and artesenia show in their kits is wrong! Keith
- 72 replies
- Erebus
it will look great when finished Keith- you weren't sure when starting the pile driver and she turned out great. Keith
- 732 replies
- Lula
- sternwheeler
ahhh the joys- nice to see you really getting your teeth into the alterations- i am in a similar situation with my Erebus build- i used Caldercraft brass ships wheels while Keith s and i think Daniel D used syren wooden kits for their Terrors- i also used the caldercraft wheels for Erebus. keith
- 62 replies
- OcCre
i strongly advise buying Matthew betts HMS Terror book as it has full drawings for the hull which will be o.k. as occre have just tweaked their Terror kit- i did mention at the start of the blog you can reduce the fullest frames to run better with the rest of the frames but a rounder hull will result- i just googled hms erebus lines plan and clicked on images option and scrolled through the results to build the new frames. Keith
takes me back to the quandries between keith s and myself when trying to fathom HMS Terror out!- nice to see building commence Keith Keith
- 732 replies
- Lula
- sternwheeler
Though not as drastic as having no fridge, sounds like our sofa and armchair scenario a few months ago- i gave them the measurements for the 12 foot long 33inch wide hallway and even taking the front door and the hallway door off they couldn't get it in! had to pay a little extra to get reclining armchairs that could have the backs removed so they would fit- but had to wait while they got re-upholstered to match the sofa- three months later we finally had our new sofa and chairs! keith
- 732 replies
- Lula
- sternwheeler
Rum fer yan mare Keith (can translate from Cumbrian if need be 😜)- slipped under my radar this one - another unusual/ interesting prototype. Keith
- 732 replies
- Lula
- sternwheeler
You are welcome Jond- cool looking ride (looks like one of the german style narrow gauge tanks) - its a 3 hour journey from West Cumbria to West Yorkshire for the 'big steam' you see in the video but we have the world famous La'al Ratty 15" gauge railway just down the coast. Back with Erebus and made a start on the Jeer winches- used turned brass billings eyes for the bearings for the axles on the winches and foremost bearings for the Massey Pump, the posts for the main mast fife rail have two knight heads on each post and the spindle for the pump in a notch drilled at an angle at the bottom of the valley between them. Still need to drill sheeve holes in the main jeer winch post and make some wooden warping drums- the wheels came from a Mantua Cutty Sark deck pump kit available as a spare to buy- nothing apart from the brass eye bearings has been glued in place yet, the brass wire for the warping drum shafts, bearings and pump crankshaft were blackened using Birchwood/ Casey brass black. Anyone building HMS Terror will need to do this if wanting to be more accurate- i didn't take the plunge with my Terror but the fife rails on the mainmast and from the pawl posts to foremast jeer winch look like they were iron with iron belaying pins (used wood on Terror as easier to work with than brass when curving/ drilling) Take care all Keith
Can't believe it's been 4 months since my last Erebus update!!! Like with my HMS Terror i have cut holes to rebate the jeer posts, windlass pawl posts into the deck- unlike the occre plans the posts abaft the main mast should be a lot wider than the plans show and its best to ignore the occre fife rails and pump handle mountings and use the plans in Matthew Betts book or find the plans online from the original drawings. must admit a bit nerve wracking drilling and filing out the holes for the posts in a nice planked deck! A couple of weeks ago i went to the Autumn Steam Up at Keighley and rode the demo freight train all day- stood on the open veranda of a southern railway queen mary brake van with nothing between you and the steam loco- tunnels were erm interesting shall we say!!!! Brake_van_2[1].mp4 Take care all Keith
i always soak my planking for a few hours before using it to soften the fibres and use a small surfoam to taper the planks towards the bow and stern- i will soak the kit in cold water for about 15 mins to re-add a little moisture- it was still wrapped in its cellophane wrapping around the box which was the style then- it really was an unopened kit! Keith
i built this kit in the early 90s in the days before laser cutting (was die cut part way through the old billings soft ply used back then)- she went to my step mother. recently i saw an unopened kit from 20 years ago on a popular auction site at more or less the same price i paid over 30 years ago - hard to let that one pass so i didn't😁- however lord alone knows when i will get onto it! Keith
