Jack12477
Everything posted by Jack12477
  1. I have that same Dremel workbench and love it. It came as a "package" deal some time ago (Loews carried it), you bought the Dremel rotary tool and got the workbench as a bonus. Have not seen them anywhere since, not even on Dremel's website. Too bad they don't still offer it because it is a great workbench. P.S. - Augie great job on the model. Looking really nice.
  2. Divarty, I also used a small awl and hand drill to get the hole started, then switch to my small WeeCheer (Dremel-like) drill to complete the task, using only the weight of the tool. The drill cut a clean hole. It was went I tried to trim it back to length and attach it to the mast that the piece broke right at the drilled hole. The hole doesn't leave enough metal to keep the piece strong enough to not break. I'll have to look up what diameter a #78 drill is and compare it to mine, which are all labeled in fractions of a millimeter. Update: Looks like the drill bit I've been using is a #73 or possibly a #74. I little bit larger than your #78.
  3. Well, I'm making some progress. Mast and bowsprit have been fashioned but those brass irons are a b*tch to drill a hole in without breaking the brass right where the hole is drilled. The flat brass strip is 1/64" x 1/32" and is way to narrow (1/32) to drill a hole in without it breaking. 1/32 translates to .034" my smallest drill bit (I can use without breaking the drill bit) is .023" or .59mm. Doesn't leave enough meat on the strip after the hole is drilled. So far out of 6 bands I made and drilled 5 have broken. I'm about to abandon the drilling part and jury-rig a different solution. These are the bands that go on the mast and bowsprit. If the band was 1/16 instead of 1/32 I probably wouldn't have this problem. Anybody got any suggestions? I may be shutting down the shipyard for a brief period - the river has frozen over and the ice yachts are being assembled - while I do a little "HARD" water sailing.
  4. Thank you, Michael, much appreciated. I almost tossed it in the wood pile after that screw-up. Glad now that I didn't.
  5. You're still light years ahead of me, Michael. I would not even know where to begin doing what you've already accomplished. Having spent a 30+ year career on the "bleeding edge" of computer technology myself, I can empathize. As many have said previously, you are blazing new ground and educating all of us in the process. Your workmanship is amazing and truly inspiring. We are all enjoying the journey with you, including the occasional stumbles along the way.
  6. Me too ! Love the "fancy rope" on the tiller. I have a [uS] Coast Guard friend who does fancy rope as a hobby. It's really beautiful workmanship- yours and his.
  7. Carl, thanks but no it's an applied paper decal - comes with the kit. The side friezes are also a paper "decal"
  8. Well, I finally got back into the shipyard after taking some time off for the holidays to be with children and grandchildren. And also take part in the Ice Yacht Expo at [President] Franklin Delano Roosevelt's Home and Library in Hyde Park. Our ice yacht club (Hudson River Ice Yacht Club - HRIYC) has the largest collection of historic stern steering ice yachts in the world, and they are actively sailed when ice and weather permits. But back to the build. Made some progress in spite of the time off. Had a helluva time with the rudder spindles; those little wires pins wouldn't adhere to the brass even with CA and Accelerator, but I finally succeeded in getting the attached. Pictures follow:
  9. Nicely done, Michael. Very impressive! Nice informative video as well.
  10. Here's a better shot: At my advanced age it takes quite a while for the neurons to bring the "learned photography tricks" out of archival storage and into current active memory . In the old days of film photography when you needed to cut the light output from the electronic flash you could use a white handkerchief and drape it over the flash unit. In the case above I folded the handkerchief twice so I had two layers of cloth to diffuse the light output. Worked pretty good.
  11. Well, some progress. I decided to leave the thwarts as specified in the instructions but enlarged the mast thwart a little. Sorry the lighting is dark, these point and shoot digital camera don't have a way of cutting the flash output. When I use the built-in flash at this close range it completely washes out the image.
  12. Per, I think the instructions are incorrect. When I lay the individual strips of wood on the drawings, the 5/32" fit exactly while the 1/8 is too narrow. I guess I will fiddle with it and see which is visually more acceptable.
  13. I've run into a bit of a quandary in my build. I'm at the point of constructing the thwarts and I am finding a discrepancy between the printed instructions and the plans. The instructions call for 1/8 x 1/32 for 7 of the thwarts and 3/16 x 1/32 for the mast thwart. The plans show the thwarts as 5/32 wide with the mast thwart 1/4" wide at the widest and 5/32" at the narrowest. Has anyone else encountered this discrepancy and if so how do you solve it? Are the instructions wrong or is the plan drawing off ?
  14. It's not a Dremel chuck you need but the interchangeable collets that go into the chuck. I have a Dremel 395 and 3001 and both fit the Workstation. They "clamp" in via threading on the "nose" of the drill. A ring is unscrewed and the dremel is then screwed into the workstation and router/shaper station. I have both the "old" Dremel and the new Dremel and use them both interchangeably The collets look like these http://www.dremel.com/en-us/Accessories/Pages/SubCategories.aspx?catid=2005&catname=Chucks+%26amp%3b+Collets and are not that expensive.
  15. I use the Dremel Workstation as a drill press. It's available thru MicroMark http://www.micromark.com/dremel-workstation,8556.html Dremel has collets that take even the smallest drill bits. Mine works fine for model work.
  16. I have to echo EdT's words. Michael, superb ! And the video is very informative, thanks for including it.
  17. When I started airbrushing plastic models several decades back, I purchased a middle of the line Badger single-action airbrush and several cans of compressed air. As I got better at painting with the Badger I bought an inexpensive small hobby style compressor. I still have the Badger (haven't used it in quite a while now) but the small hobby style compressor burned out from overuse (by my son) and now I use a 3 gallon Sears brand compressor. I never had any problems using the single-action brush, as opposed to a double-action brush. I'm not sure I could master the double-action. I painted over 40-45 1/35 scale model armor vehicles including elaborate camouflage patterns with the Badger and it worked like a charm. Mine took an external cup or jar of paint, had two tips for coarse and fine work. So as a starter brush I would recommend the Badge. The secret to any brush is thoroughly cleaning it after each use.
  18. Ryland, Floyd, Divarty, thanks for the likes. Updates: Painting of cap rail and interior completed; I stained the interior and exterior hull with Minwax Natural, while the floorboards are stained slightly darker with Miniwax Golden Oak. The lighting doesn't bring out the color too well. Using the flash at this close distant totally washes out the photos. Gluing the floorboards in place:
  19. Update: Bow stem repaired. Temporary braces removed, Cap rail installed and sanded. Red tape applied to mask off areas to be painted. I'm going to paint the cap rail, inside and stern red as the others. Interior I think I will stain (not sure which color yet). Have not decided whether I will paint the lower hull white or leave it "natural". The red "masking" tape I'm using is Great Planes brand 1/8" EZ-Mask Flexible Masking tape. I started using it when I was building the plastic Tamiya armor kits. It's very flexible, low tack and applies easily.
  20. Now that's a machine ! Impressive ! Would be super nice to have that one in my garage. Haven't kept up with my home town companies since I left there in 1968 even tho I still have family there - Dad, 2 brothers and 1 sister. Dad is 99 and going strong. He's very knowledge about Gleason's history. He told me once that Gleason was the only American company that was NOT affected by the Great Depression of 1929-1930. Gleason offered me a job as a programmer when I got out of the Army but I didn't accept it because I took a more challenging programming job with "Big Blue" down here in the Hudson Valley and stayed for 40 years. We used to say we were on the "bleeding edge" of technology advances. My only experience with machine shop was as a college freshman I was required to take a two semester Machine Shop course where our project was to machine a working micrometer from scratch. I still have the micrometer tho I don't use it much. I'm really enjoying the engine build.
  21. What !? You don't have a Gleason Gear Cutting Machine in your garage, Michael ! (Just kidding of course). Many (and I do mean many) years ago, I was shopping in a department store in my home town of Rochester NY where Gleason is located and on the main shopping floor Gleason had set up one of the smaller gear cutting machines and was giving a demonstration. The machine was cutting the beveled ring gear for a Sears Sewing machine. When the machinist finished cutting the gear he gave it to me. I have it on my key ring - well worn. It was interesting to see exactly how the machine worked - it did not cut each slot sequentially but rather stepped about 15 degrees (or so) and cut another slot then another step of about 15 degrees and another slot; when it finally finished cutting the final slot was adjacent to the first slot cut. Photo attached below: I am really impressed and envious of your machining skills. The engine is magnificent !
