DaveRow
Everything posted by DaveRow
  1. Came up not too bad. Rushed the Mizzen and close up bit rough. No white card for the Futtock Shrouds. Plan to do it for the ratling ropes though. Looking at the Jeer Blocks next. Should get all the blocks I know off onto the lower mast first before going up. Dave R
  2. Looking very authentic. You do justice to the varied colors to make things look real. Dave R
  3. Shipyard Update Fore & Mizzen Mast Futtock Shrouds: Finished off the Futtock Shrouds to the top of the Fore and Mizzen Masts. Fore Mast I start by attaching the Futtock Stave either side to the mast shrouds. I used 0.5mm black rope and seized with cotton this time(used brass rod for the main mast stave) Then add in the Catharpins, attached to the middle 4 mast shrouds under the stave. This leaves room for the Futtock shroud to loop under the stave, over the Catharpin, around the Futtock and back over the stave and down onto the main shroud. Can get fairly busy with the trying cords. Making the ForeMast Futtock Shrouds. Attached to the Fore Mast. Mizzen Mast Mizzen the same but 3 shrouds per side, attached to the 3 rear mast shrouds. And we now have the tops and Futtock Shrouds on each mast. I'm glad the Futtock's are out of the way. Doing my eyes in. I suppose it is onto the Ratings next ? or maybe not until I raise the runners ? Dave R
  4. Shipyard Update Main Mast Futtock Shrouds: Finished off the Futtock Shrouds to the top of the Main Mast today. Futtock Stave and Catharpins 2 Futtock Stave(I wound thread around brass bar for mine) 4 Catharpins from 0.5mm rope wound with black tread Below shows the Catharpins tied between the shrouds, the Futtock Stave tied to the stays. Starboard view of the Main Mast top. Top end of the Futtock Shrouds. I made small brass hooks from 0.5mm bar, shaped and welded a loop in one end. The lower end of the Futtock Shrouds. Looped around the Stave and Stay then tied below to the Stays. Up and under. More to go... Dave R
  5. I've got the promise of rum and wild women for the apprentices at the shipyard if they get a move along. Been adding tension to the shrouds, port/starboard to align the mast tops, and adjusting the stays fore/aft to set the mast rakes. Nothing broken yet, the lads doing a fine job. The rum awaits..... I believe I am looking forward to the fine work required for the Futtock Stave and Shrouds, the Catharpins and Rattlings. I tell myself this anyhow. Maybe I need the rum. ? Dave R
  6. Yes Steve. The longer bowsprit will come together nicely with the Main Topmast. With all going to plan, straight stay lines. Dave R
  7. Another good start their Greg. A lot of scratch work which your so good at. Dave R
  8. Shipyard Update Mizzen Mast Shrouds and Stay: Been slow going, checking and preparing ropes sizes and making the ends. Mizzen Shrouds: Shrouds made and hoisted at-top the mizzen mast. All just clear the top rail either side, just how they should be. Mizzen Stay: Made the Mouse on the serving machine(with mouse jig) and looped for the top of the stay. Hoisted the stay in place. 3 years and 1 month after starting the build: An side on view of the 3 Lower Masts hoisted with Shrouds and Stays on. I believe I can now see the light at the end of the tunnel ahead. Dave R
  9. Good Job Glad you got some paying work. Lessons learn't on planking of 1st layer will come in handy for 2nd. Great effort. Dave R
  10. Shipyard Update Fore-stay: I had the fore Stays looped over(on top of) the shroud loops like this: However I believe after some investigation they should be like this(resting lower and more around the sides of the shrouds): Hope I have it right now. MIZZEN MAST And the Mizzen, have made and added the Burton Pendants. The picture on the left is of the Endeavour Replica, Mizzen Pendants. Mizzen Pendants on my model: Onto the mizzen shrouds next. Dave R
  11. Shipyard Update Fore-stays: I've fitted to length with hearts the Cable Stay and Preventer stays, trial fit(shrouds to be lashed in place yet). I with the cable stay significantly larger in diameter, I wanted it to stand out more. May of went a bit too far ? I decided to "worm" the Cable Stay with a lighter thread as described in Steel's Rigging, WORMING. Wind a small rope in the cuntlines of the strands of cables, shrouds, or stays; and spun-yarn in those of ropes four inches in circumference and above. Dave R
  12. Hello Rowan, Look forward to your pics and where you are up to. Dave R
  13. Shipyard Update Thanks for you all Greg, Steve, Mike and Pat for looking in on my log. You guys all provide inspiration. More making Stay's Mouse Second weaved mouse for the Main Mast Preventer Stay. Getting the hang of the weaving. Pat, Odd numbers are good. Still a bugger to weave through them though. Might try a light/dark longitudinal's for next one. Dave R
  14. Hi Chris, I tried the fabric band-aid's. I just couldn't get it to work out neat enough. Probably was ok, but the weaving method is coming along fine now, comes up better. Thanks Dave R
  15. Shipyard Update Making Stay's Mouse In one of the other Endeavour Logs, I noticed Elastoplast Fabric was used to wrap around the mouse cone to create the effect of the rope-yarns. I decided to trial this for the stay mouse. I made the Fore Stay and Preventer mouse, using the Elastoplast Fabric - wrapped about the mouse "cone". I used a course type for the Stay and a finer type for the Preventer. <picture below> Whilst the Stay came out not too bad. The preventer mouse fabric seemed a bit too fine(no rope definition) so decided to have a go at the traditional weaving method(of sorts). Below is the Fore Stay loop and mouse, which I am probably going to stay with. I mad up a Jig to drop over my Serving Machine, use the clamps at ends. Making the Fore Preventer Mouse - weaving threads(sewing thread). I had 12 long threads(mistake), next time will try to remember and use a odd number to weave under/over properly. Used different color twine to make it easier to follow the weaving. Finished first ever weaved mouse. Considering, I cut the old Fabric off the mouse cone whilst on the rope, and weaved the new about, came out not too bad I think. Ends are served over the previous served twine(ending up with a large diameter, bugga). Next one we do should come out better. Looped ready to paint black. The picture does not show, but I tightened up the loop(served over) so it just slides over the start of the "mouse". Looped and painted, ready to be hoisted atop. Took me hours to get the first one done. more to get onto. Dave R
  16. Shipyard Update Making things. Shroud Dead Eyes(Turned in Dead Eye): This is the process I use in tying off the shrouds around the Dead Eyes. Here I have already got ahead for the pictures, the shroud is already been whipped 4 times around the dead eye(throat seizing) and a dab of CA glue applied and whipped before drying to leave the seizing looking like thread/rope. Trick is I found was to remove the assembly before drying and squeeze the shrouds together before the CA completely dries, so the ropes were close together. The earlier shrouds ended up a bit wide at the throat. I then hold the dead eye in the clamp and whip the mid seizing 5 times. Each seizing is started with a loop from the green clamp, around a hook and then back to the seizing point, where I hold the twine with tweezers and start to wrap around. After the turns the twine is fed through the loop and pulled under the wrapped twine(to hide the join under the seizing). This picture shows just before "pulling" the twine under the wrapped twine. Dab of CA glue applied(wiped off before drying) around the twin/seizing to hold in place. Trim to 2 ends and finished. Well maybe not > I think I was too smart for myself as I now find in looking at the replica pictures the seizing was wrapped around between the shrouds. Oops. Stay Mouse's(or is it Mice's): Used the Lathe to turn up some Mouse's for the Mast Stays. Drilled a hole(for rope size) in dowel and then turned down to size(a guess really) Made a few for the Mast Stays and the Preventor's. Not sure how they will work out ? Large Hearts I made some custom Hearts for the Stays(from Pear Wood), for the Fore Stay and Preventor to the Bowsprit. Aim is to match the other custom half hearts on the Bowsprit which allow the Jib-boom to retract through these ones. Made a pair for the Main Stay, but ended up too big. Grooved and stained. Two types, narrow & wider tops. Main Stay Started the Main Stay between taking a break from the Dead Eyes on the ends of the Shrouds. Mouse on the stay ready for next stage. (yes it is wrong way about) Eye at the top end to loop over the stay. The Heart loosely about the Bowsprit for now. I didn't use the ones I had made, bit too big(wide) I think it was Steve said "bugger to tie off", it will be. Main and Fore - Starboard Shrouds ready for Laniards Used a tan rope for the Laniard, bit of contrast to the black shrouds. In the voting stage as to keep it tan or go black. Open to suggestions.! Well, lots going on, more to go. Dave R
  17. The longer Bowsprit(50mm) makes the difference, and the taller Mizzen all looks right. The sails is a interesting point. Not under full- sail, however I was considering having the sails furled on the spars, at anchor. Just another level of detail and work to undertake. Dave R
  18. Hi All, Thanks Anton, Steve & Pat for providing background to the Shroud configurations. After checking on several sources, I must admit I followed the AoTS, early in the build. So this is why my Endeavour has on: Fore Mast: 6 large dead-eyes for shrouds, 2 smaller dead-eyes for backstay's on the channel, 1 top-gallant backstay on the hull Main Mast: (same as above) Mizzen Mast: 4 small dead-eyes for shrouds, 1 mizzen backstay on the hull I would lean to agree the Main & Fore(based on the Deptford draft), these masts probably had 7 shrouds, the rear shroud being a swifter. With single backstay's to the top-mast and top-gallant. However, as much as I would like to correct my channel/dead-eye configuration, a big change now, which I am not prepared to undertake. So an update to where the shipyard is at. Placed all the masts into position to see how they look. The ForeMast Pendant Tackle - temp. held down for the shrouds to go over. Shrouds from "Chuck's rope" 0.89mm shroud with 0.2mm serving. 1 of 2 sets made so far. Main Trestle-Tree with MastTackle & Shrouds I've tagged each shroud, each will be a different length to the dead-eye. Plan is to: - tie a length of seizing to the shroud, at top position of the dead-eye - take all the shrouds off the mast then - finish the seizing to the dead-eyes on my rope making jig, where I can clamp and have many hands at work. This is going to take some time..... 3 masts, 32 shrouds, 96 seizings to the shroud dead-eyes. How long can that take. ?? Dave R
  19. Thanks Anton, Greg, Michael and Pat for looking in. 2 pair of long nose tweezers makes the fat fingers work "thinner" to tie knots. Glad this is area is done and out of the way. That Tropical Cyclone "Debbie" came down from up north, lucky at home here we just got some medium rain then a wack of wind at the end. Not much damage at my place, however around us may trees down, some on houses. Dodged the bullet. Researching the shrouds to the lower masts at the moment. Been looking at the previous Endeavour build logs, the AoTS and Steel's to work out the rope, block, seizing sizes and all the other intricacies. Cheers Dave R
  20. 4 ships Boats Lashed down What does one do when stuck inside during the tropical cyclone "Debbie" makes its way past. Lashed all the reserve spars onto the gallows and 2 smaller boats on top . A little rest to work out what to do next. Dave R
  21. Running Sheets Extra Blocks on the Decks /Mounting Following on from my post #593 I added in more sheet blocks and eye-bolts to the decks. Left them "loose" for now, glue in later if I need to take out to thread or attach ropes. Fore Deck: 2 x 4mm singles, 2 x eye-bolts Mid Deck: 2 x 4mm & 1 x 3mm single Rear Deck: 3 x 3mm single, 2 x eye-bolts PS I now have a multitude of eye-bolts, some with blocks, and even some extra holes I drilled about the Mizzen mast, just in case I have missed some fixing points. How many, dozens of them. Adding Blocks to Eye-Bolts Thought I share my process to make the block/eye-bolt work. This is a 4mm single block, ring and eye-bolt. Held either end which allows me to use both hands to thread ropes around and tie off. Dab a drop of CA fast drying glue about the thread, which soaks in to seal the thread and holds it all together pretty much solid. After the CA glue dries, trim the excess threads off. Ready to mount on the decks. I didn't add a ring to the 3mm blocks, direct to the eye-bolt, very small and without the ring they stand up. Onward and upwards..... Dave R
