Posts posted by hornet
Hi Don
Read through the thread below. It will give you some guidance as to the best kit brands for beginners as suggested by members of the forum. Remember that clear PLANS are probably more important than written instructions. Any confusion you may have can usually be cleared up by asking for help from this great forum
http://modelshipworld.com/index.php/topic/12105-poor-instructions/?hl=%20best%20%20instructions
As well as a range of different grit sandpaper on different wood blocks, I use my Proxxon delta sander and pen sander.
The delta sander comes with a range of different grit pads and is great for sanding larger areas. The pen sander comes with different shaped attachments and is useful when getting into tight corners.
- zoly99sask, Canute, Mark Pearse and 4 others
- 7
Vossey
I would also suggest you get a Squadron Super Glue Applicator. They are very cheap and deliver a small drop of glue to the back of each plate quickly and easily. Combined with tweezers, I found that fitting plates was made much easier than the method shown on the Modeller's Shipyard YouTube Clip ( applying a line of glue to the hull then putting on the plates) I managed to glue the entire hulls of my Sloop Norfork and the Supply without glueing my fingers together even once.
I bought my squadron applicator from Frontline Hobbies here in Newcastle, but I imagine they would be available in most hobby shops. See link below.
http://www.modelsrgo.co.uk/squadron-tools-precision-super-glue-applicator.html
Well I can vouch for Cornwall model boats. The plates I ordered were very quick in getting here and (at that time) were less than half the price of Modeller's Shipyard (including shipping)
Vossey
I bought copper plates for my current build - HMB Supply. After a lot of searching, I found it was cheaper to buy them from Cornwall Models in the UK. That was when the Aussie Dollar was worth more though. Modeller's Shipyard will sell them to you but they are hideously expensive.
Float A Boat in Melbourne may have them. They are not listed in their catalogue but it s out of date. It would be worth calling them. Nice people to deal with.
http://www.modelshipyard.com.au/fittings/copper-plates-sheathing/
Hi Vossey
Modellers Shipyard/Modellers Central has put out a DVD on the art of hull coppering. I bought it and found it OK for a beginner. I think part of the DVD is on YouTube. You may find it useful.
For me the choice was too, too difficult so I bought the lot.
- Canute, Landlubber Mike, Burroak and 5 others
- 8
Jbshan, you mention `plank separation' in your post regarding single layer of planking. My first build (over 30 years ago) was the Aeropiccola `Golden Hind.' It was single planked. The book `Period Model Boat Manual' which I bought at the time (don't know if it is still in print or not) recommended `caulking ' the inside of the hull to prevent this happening. This was done by layering bandage dressing `gauze' into the interior of the hull and coating with thinned wood glue. It was a similar method to fibreglassing. I used the method and after 30 years still no cracking or plank separation. See pics below.
extract from `Period Model Boat Manual'
Hull of the `Golden Hind' 33 years after construction (no plank separation)
On a recent build, drilled through the centre of a small diameter dowel using my drill press and then turned the dowel down to the desired diameter using sandpaper on my lathe. I then cut the parrel beads to length and carefully sanded the ends. It was fiddly but worked well. The beads were around 1.5 mm in length but could be made even smaller. See below
Alternatively, you can buy beads in a range of sizes and colours from sewing shops. See below.
- CaptainSteve, mtaylor, ulrich and 1 other
- 4
I have been using an Aeropiccola heat/steam bender for over 30 years. Works well for me. See my post about it from another thread below.
I have the Caldercraft Version 'On the Shelf'. I have been through the box. As with all Caldercraft kits fittings and plans are good. Walnut hull planking strips are so so. I anticipate doing quite a bit of scratch work as I have done with the Caldercraft 'Supply' but I'd be happy to recommend it.
Spend the extra and buy a compressor designed for airbrushing. They are small, portable and best of all very, very quiet. If I tried using my regular compressor for airbrushing, the Admiral would probably have me walk the plank. I have a Sparmax (see link) it is a ripper.
http://www.air-craft.net/acatalog/Sparmax-TC-610H-Airbrush-Compressor.html
Least enjoyable - Corel Victory. I didn't have the skills to take on this beast at the time. In addition instructions were awful. Took me 20 years off and on to complete.
Most enjoyable - current build Caldercraft 'Supply'. I have scratch built almost all of the fittings, learned how to use and airbrush and how to silver solder while working on her.
I have this sander. Yes, you do need to purchase a transformer for it - Proxxon make a couple which are fairly cheap. You can buy a single outlet transformer or one with multiple outlets just in case you invest in other 12 volt tools.. The pen sander comes with a variety of different shaped attachments. Sanding pads fit onto these attachments via an adhesive backing. From my experience, the pads don't last very long but they are inexpensive to replace. I don't use mine a lot, but it is good for getting an even sanding job done on hard to get at spots such as the edges of a deck. It is not a 'must have' but is inexpensive and handy at times.
Better known for selling Caldercraft kits.Thanks for the responses. I have seen a lot of the scientific model around. Does anyone have any comments on these? Ragove I have not heard of JoTika but I will check them out.
A question about trennelling. (spell?)
in Wood ship model kits
Posted · Edited by hornet
Hi Paul
I also use bamboo skewers for treenails. I did some research regarding diameter using the treenails on the deck of the Endeavour Replica as a reference. See first link below b
[url="http://modelshipworld.com/index.php/topic/8317-to-treenail-or-not-to-treenail/"
In addition I made a tool for splitting treenails so they were easier to fit in a drawplate. See link below.
http://modelshipworld.com/index.php/topic/2959-treenail-detail-option/
