Posts posted by hornet
While coppering the hull of my HM Brig Supply, I came across this handy CA glue applicator from Squadron (just google Squadron glue applicator)
The hooked end of the applicator traps a small amount of CA glue which is transferred to the copper plate as soon as the applicator touches it. Very clean and easy - no plates stuck to fingers
The applicator is made of stainless steel and was quite inexpensive to buy
The hooked end of the applicator holds a small drop of CA glue
As I mentioned in a previous post on this thread, I use the concave end of a glass jar as a reservoir for my CA glue.
Steve
I use CA for gluing down copper plates, holding the end of hull planking down until quick dry PVA glue sets, making a pointy end on thread. Other than that I avoid CA glue. The flu like symptoms resulting from inhaling even a small amount of fumes from it is a real issue for me
Because the decks are on three different levels, the thickness of the planks may not be an issue. However, because the hull planks are three times as thick as the deck planks you may find that things like scuppers and ports may not line up properly. In addition, if your decking timber is different from the timber used on the hull - for example hull planking - basswood and decking timber - Ash, then using two different timbers on your deck will give an inconsistent finish. You may also find that your deck planking s a different width to your hull planking. I think your best bet is remove the planking and redo it with the supplied deck planking. In the overall scheme of things it s not a big job to remove and replace with the correct timber.
- mtaylor, Canute, CaptainSteve and 1 other
4
I suggest you slip a No 18 X acto chisel blade under them and remove them carefully. Resand and replank with the correct decking planks.
- Canute, thibaultron and mtaylor
3
I have built he Corel version. I would not recommend it as the instructions are woeful. I am currently building the Caldercraft Supply and have the Caldercraft Bounty and Endeavour on the shelf Both instructions and fittings are very good - although I have done a lot of scratch work on the Supply. Timber used for the second layer of planking is of inconsistent quality but there is plenty of it. On the basis of my experience with these kits, if I were to build another Victory, I would seriously consider the Caldercraft version.
Hi Shaun.
A while ago I posted a method of making planking screws using clothes pegs. They worked well for me. Check out the link to the thread if you are interested.
http://modelshipworld.com/index.php/topic/3734-planking-screws-moved-by-moderator/
As someone who has been toying with the idea of buying a milling machine for quite a while, but being unsure if I would have enough use for it or not, I will be following this thread avidly. Keep the ideas coming.
This looks like a good idea, but I wonder if the rubber tubing will stand the test of time. Like most things that are rubber based, would it not start to perish or break down over time? A couple of my models are 30 years old and I am not sure this would last that long. I'll be sticking with copper or cardboard.
- Bobstrake, mattsayers148, GLakie and 2 others
5
Danny
I remember following your restoration of an old HMS Victory model. It was a great job. I'm sure you will do this one justice as well.
Cheers
Steve
Another modification I made to the powered version was to replace the perspex brackets holding the spools with ones I bent up from some scrap aluminium. I found that the perspex ones flexed too much for my liking and I had difficulty getting them to hold the spool firmly enough. The aluminium ones fixed the problem.
I am currently building the same kit and have the same problem. The only good thing is that there are more than enough walnut strips provided so I was able to pick out the best ones. I also have the Caldercraft Endeavour and Bounty 'on the shelf. ' the walnut in them is no better
I agree with Brian, although I did make an addition to mine. Check it out on the link below.
Modification to Serving Machine -
I made up a simple but effective scraper for removing excess glue using a reversed No 11 blade. See link below.
http://modelshipworld.com/index.php/topic/4679-the-kit-bashers-guide-to-the-galaxy/page-6
For white glue I usually squeeze a blob onto the lid of a Chinese take way container. When it dries it just peels off and the lid is as good as new. I apply it with a small awl. I use CA glue very sparingly but when coppering a hull I turn a glass jar ( most of which have a concave bottom) upside down and squeeze a few drops in the middle. I use the old awl to apply this as well.
Since most work is done with things that are very sharp, often pointy and sometimes even quite hot, I tend to avoid using the groin area as a workbench. I can do more than enough damage to my extremities even when my build is mounted in a vice on a workbench.
- Canute, usedtosail, WillB and 8 others
11
finish for wood
in Wood discussion...Where to use it? Where to get it? What types are best? How to Finish it?
Posted · Edited by hornet
Lionfish, between 20 and 25 psi. Much the same as for acrylic paint. I use a dual action Sparmax model DH 103 for Acrylic paint and a single action badger model 200 for poly/turps mix.
