Posts posted by Thistle17
So looking at the line heap it looks like almost all of the running rigging didn't survive or did you decide it was easier to start anew? How about the standing rigging?
Joe
I have begun the deck furniture and as I said I could not deal with the shoddy materials, fit etc of the kit so I began building them anew. The process is going slowly as there are no dimensional drawings so with a combination of existing die cut parts and measurement of deck opening I have begun pretty much "building in place". This is not ideal as one can imagine as the deck furniture forms were slightly titled in the vertical plane on all sides and the hull mold isn't exactly uniform about a center line. The first photo is what would have been realized using supplied parts of the kit. Pretty ugly even in its unfinished form. Oh, I forgot to add there was no trim accessory pack in what I took in. The second photo is my built up version using boxwood and mahogany materials. It is yet to be fully detailed but I think you get the idea. I would again add I discarded the acrylic forms shown earlier as they just didn't work with this method. I do appreciate that if one were to sail this model they would have possibly been more appropriate as these new elements are all assembled using "yellow" glue.
Joe
- Jack12477, mtaylor, Roger Pellett and 2 others
- 5
Jud and Kurt thanks for the photos especially the Mark 1 photos they all help. As you might guess we are starting a library of photos, documents etc etc to advance the build datum. One question that just came up today was did the Mark 1 have 2 or 1 50 cal forward? Seems to be some confusion here. Also we haven' gotten to the point to determine if we are replicating an as built version or one with field upgrades at some TBD point in time. Knowing the Navy there was always some upgrade program afoot.
Joe
Jud we have been collecting photos from any sources we can find since both the Maryland Silver and even the Navy releases to us don't tell it all. This is especially true for some of the deck details. For instance the forward gunner detail isn't that apparent. We just realized yesterday that the gunner sat in that tub and we are trying to figure out how the "twins" were mounted. So any deck photos are especially important.
Knowing your demeanor I can't imagine you took this catastrophe in stride. But knowing your demeanor I know you have already heaved a sigh and will have at it. Restorations have their own special place in our endeavors and I am sure you will do a terrific job. I for one will be watching. And here I thought you only did admiralty models!!!!!
Joe
Work has begun on the 1/6 scale model of the Mark I PBR. Using the body plan obtained from Maryland Silver, the bulkheads were fashioned for the waterline model. A keel like former was milled (its height was determined to be the floor of the aft gun deck minus the actual simulated deck plating) and slotted to receive the 3/16" plywood bulkheads. The stations were slotted to fit onto the "keel" in the fashion of today's kit manufacturers. The base plate, 3/8" baltic birch was laid out with the corresponding stations and water line contour. This will be a permanent substrate when cutout and will mount to the display base. At this stage the transom is missing as it has some slight contour and detail not yet worked out. The stem was made out of basswood and awaits the rabbet for planking.
One gets a pretty good idea of its size by the shop cart it is temporarily laid on. Yet another large modeling project of awkward size! Just can't seem to escape them. When we are confident in the bulkhead shapes, thickness and fairness we will move the model to the museum for further participation in this group build.
At this stage of construction I find I am always conflicted with plank on bulkhead construction. I can imagine the end point but the crudeness of this stage always dismays. I guess it is because it is like the human, a skeleton with no character. Oh well onto the next steps which will be fairing the forms, drawing up the forward gun tub , pilot house, engine compartment and transom. Getting those correctly located and determining further work on interfering bulkheads. Then we can begin fastening the assembly down. At this stage we can start a BOM for planking and decking materials and missing parts needed. The museum has purchased some excellent accessories so we do have a head start there. At this point we are of a mind to use Alaskan Yellow Cedar for the planking. It is a denser wood than Basswood and has a very tight grain that does not produce "hairs" when sanded.
Joe
That was a great response Rusty! I have not had a reaction like yours but I am not surprised by what happened to you. When I am working on any wood milling projects big or small and I start sneezing it is a warning for me. Case in point I bought some BNM(Bud Nosen Models) mahogany for the project I am working on. It is not like any mahogany I know and it has a weird smell when cutting, almost perfume like. It too was a warning to me to be careful.
Joe
I will always remember Portia Takakjian, the noted and talented researcher, illustrator, author and modeler died at the age of 61. I believe it was from emphysema. I was told, some time back, toxic wood dust may have been a contributor. Just google the web for the lists on wood toxicity, they are out there. I am particularly sensitive to this danger as my mother died of the same affliction at an early age. She worked in a fabric mill in her early years when there was no OSHA compliance.
Most wood dust of 1 micron or less particle size gets into lungs and can create havoc and disease. It is always advisable to wear a dust mask or respirator and to collect the saw dust. Most dust collection systems now advertise particle capture in the one micron range. Whether that is true or not I do not know. In addition my shop as well as many others is in the basement and the house air is conditioned by heated/cooled air. It is so easy for those particles to make it into the HVAC through duct voids etc. and that ends up in the living area. So the long and short of it is take saw dust control seriously.
Joe
Chad a project, case and all extremely well done! Anyone who spins in the MSW orbit cares! I don't know how old the children are but I find it puzzling that "younger folk" can' seem to relate to exquisite work of this nature. When I was a kid I marveled at this sort of thing. I was inspired even then. Your reflections are dead on though.
Joe
My, my you have been busy since last we met! It must be bitter sweet to be nearing the end. It is such an interesting model that it deserves a good home. If you haven't got one I know of one!!!!!!!
I am so far behind you and my shot clock keeps ticking along. I will need another lifetime to catch up.
Soooo now what is on your next to do list?
Joe
Mike just a few added comments. I received an order from Wood Project Source just last month. It came within 2 weeks of order placement. If you are of a mind to mill your own lumber look for a "Makers" operation in your area. You can go in and rent the machine time. Surely in metro DC there is one as we have here in Rochester NY.
Joe
- mtaylor, Canute and Landlubber Mike
- 3
Finally we have been given the drawings from the Naval Surface Warefare Center for the PBR Mark I. We have been given 3 of the 4 the drawings suggested to us by our design contact. I suspect the drawing held back was the armament detail. The drawings given to us are configuration drawings of deck, mid section and propulsion subsystems. There is more detail than the Maryland Silver drawings. They, along with the Maryland Silver plans should facilitate our build. We are thankful to the Navy Carderock Division for their generous support.
We have some study sessions to compare the plans but finally it appears we are on our way.
Joe
Looking back to our recent meeting I can't believe we missed the rigging problem Bob highlighted. Many eyes were present but few were seeing as we were focused on the model beauty. Knowing your demeanor I assume you took it in stride with little frustration. And with your usual expertise and dispatch you have moved on! Great work Rusty!
Joe
- Canute and Ryland Craze
- 2
Thanks for the feedback Stephen this paint saga really set me back weeks. I was so angry with the outcome I even had to walk away from the project for a few days. I will never use the Rustoleum product again for something like this. As I search the web I find we are not alone on this problem. The folk's advice at the auto finishers store is the way to go.
Please join in here if you are so inclined. It is helpful to hear from others.
Also if you don't have a genoa kit I have one by mistake and will sell for a reasonable price. It is complete and unopened save the shipping box. See the ad on this web site under items for sale.
This is an update as of 10/29/17. I received another call last week confirming that 3 of the 4 drawings will be released to us. I was not told which one was not released but I speculate it has something to do with the armament. In this day and age it is small wonder that it could be as I suspect.
The drawings will be released to us as soon as the office that controls this type of transaction gets instruction on how to bill us. Is it any wonder that nothing in the US Government moves along with any reasonable pace?
Joe
The next stage is to finish paint the inner bulkwarks and begin attaching some of the deck fittings. I have all but decided that I will start from scratch to build all the deck furniture. The die cut pieces are inferior in size and the material quality is equally poor. Some parts are even missing and don't show up on the drawings
I do have a side project related to the model. The client wishes to display the model in her year round home away from home. It's resting place is on a second floor loft area that dictates a special table. I will incorporate the stand as part of this table so as i think of it I have to set the model aside and begin that aspect of the project.
Can this hull be saved? (US Brig Lawrence)
in Painting, finishing and weathering products and techniques
Steve at this point I might try the following. But I would recommend you experiment off the hull first. Lay up some planking of the same material on a flat service. Treat is as you did on the model. Then sand it down as "hornet" recommends. Then experiment with Trans Tint dyes. Instead of water use alcohol on the experimental plate. Given the "oil" application I would be tempted to wash/wipe the hull down after sanding with lacquer thinner to remove as much of your overcoat that penetrated. You can mix these dyes and get just about any tint you wish. That may (or not) give you a colored substrate of more even coverage. Pine, cherry and even maple and some other woods can give blotchy and unpleasant surface coverage when stained.
Other possible options within the reovery process; Kilz Sanding Sealer, wood bleach (be careful with this as it removes the tannin in the wood and gives a very dull washed out surface which must be colored again. I did an oak tool chest that had awful grease, rust and dirt on it. But once finished correctly it was quite a different piece.
Good Luck!
Joe
