davyboy
Members-
About davyboy
- Birthday 12/03/1940
Gender
Not Telling
Binningen Switzerland
Interests
British naval warships 17th and 18th centuries. Travel in S.E Asia. Reading.
davyboy reacted to a post in a topic:
Nail pusher nightmare
HMS Montague 1779 by garyshipwright - 74-gun Alfred-class
Erycina 1882 by Blue Ensign - Vanguard Models - 1:64 scale - Plymouth Trawler
LA CREOLE/ LA GUADELOUPE by matiz - 1:48 - by Tiziano Mainardi from Boudriot plans
La Créole 1827 by archjofo - Scale 1/48 - French corvette
HMS Portland 1770 by westwood - Portland Scale Ship Co. - 1:48 - 50 gun 4th rate
Carving from Belgorod
FrankWouts reacted to a post in a topic:
Sloop Speedwell 1752 by Chuck - Ketch Rigged Sloop - POF - prototype build
Chris. reacted to a post in a topic:
Le Fleuron 1729 by Chris. - scale 1/72 - French warship from Delacroix monograph
hollowneck reacted to a post in a topic:
HMS Harpy 1796 by Blue Ensign – FINISHED - Vanguard Models - 1:64 scale
Richard44 reacted to a post in a topic:
Blue Ensign reacted to a post in a topic:
Mr Whippy reacted to a post in a topic:
Hi Maurice,why don't you not just sieze the breeching ropes to the eyebolts before fitting them into the bulwark ? Much easier to do it that way you should have enough slack to slide the rope through the cascabel ring from side to side to do this. Certainly more space to do your siezings there than up against the bulwarks. Just a thought but that's how I'd do it. Dave
- 332 replies
- Harpy
- Vanguard Models
KentM reacted to a post in a topic:
Pegasus by hdrinker - FINISHED - 1:48 - POF - Swan practicum
Hi Henry,your Dilemma is easily solved. You can fit an item called a deadeye plate,one of these can be seen in Blue Ensign's HMS Pegasus build log part 9, 6th pic down. Dead easy to make,just an eybolt through small circular piece of wood (Slice off a bit of dowel). The bottom deadeye just hooks into it. I had exactly the same problem rigging my Speedwell build. The Mizzen backstay and Main T'gallant backstay and attaching fittings are totally missing on the rigging plan although they can be seen on the NMM model. It was BE who put me in the picture. Hope this is of help, Dave
- 257 replies
- pegasus
- Swan-class
daHeld73 reacted to a post in a topic:
HMS Bellona 1760 by SJSoane - Scale 1:64 - English 74-gun - as designed
mtaylor reacted to a post in a topic:
Chafing mats or Service on lines
Thank you Trevor,one always learns something new. At the end of the day however they all serve the same purpose. Dave
- 15 replies
- baggy winkle
- service
Interesting names,Chafing mats or Service. I've always known these by the old name baggywrinkles. Dave
- 15 replies
- baggy winkle
- service
I've never used bits of paper as templates. There is usually a standard distance between Ratlines of 12" to 15" ",I use 12". A piece of wood 1/4" wide (I build in 1:48th) clipped across the shrouds below where the first ratline is to be rigged. Rig the ratline then clip your piece of wood directly above it and rig the next and so on. The beauty of doing it this way is you can ensure good alignment of all your ratlines with out struggling to align them with lines on a sometimes wobbly piece of paper. It works very well for me,try it. I'm sure I read this tip here on the forum years ago. Dave
Hello Wefalk, That practice is called pollarding and is still carried out to a limited degree in England for various reasons. Plenty of information on google and other search engines. Dave
Looks very nice indeed Maurice,certainly a great improvement. Dave
- 332 replies
- Harpy
- Vanguard Models
Hi drftrman, Cruizer was my first ship model a long time ago. Don't worry about the bulkhead tops,at a later stage of the build when the hull is planked they're cut off. Just lightly tack glue the gunport patterns to them for that reason after fairing. I found that out the hard way. Have fun with your build,plenty advice on the forum,you just have to ask. Dave
Hi Maurice, She's looking good. These fashion pieces look much better than that shown on the prototype build. The Speedwell has exactly the same arrangement on the lower counter,I suspect that would be fairly common construction practice back in the day on small ships still using the older style square tuck . I'm currently chipping away at the boxwood carved figures of the two ladies ornamenting Speedwell's tafferel,then there are other smaller pieces to be done. Heigh Ho,get there eventually I guess. Dave
- 332 replies
- Harpy
- Vanguard Models
Mini Table Saw recommendations
davyboy replied to captainscott's topic in Modeling tools and Workshop Equipment
Have you tried sticking it to a backing piece of thin (1/8" or so plywood) I can't speak for styrene but I successfully cut 0,015" copper and brass sheet doing that on my Proxxon KS 230 saw using their thin fine toothed # 28020 50mm blade. Just take it slowly so you don't melt the styrene plastic. Dave -
Hi Maurice,I see you've started already,lots of fun ahead for you. Dave
- 332 replies
- Harpy
- Vanguard Models
