Canute
Everything posted by Canute
  1. Maybe a tiny dot of Tacky Glue first to get it in place. Then flow your CA/superglue into the joint. Have some little squares of paper towels to blot up any excess CA. I've tacked styrene bracing into a resin car with that, then flowed the CA into the joint. Really need it with the older "flat" kits. Need square corners if you want the roof and floor to fit in. Trapezoids don't work too well. 😉
  2. Yes, it does. Aftermarket in this scale would be overkill. And the kit maker did such a nice job with their moldings.
  3. OC, nice presents. I like your dio concept. Definitely need those erks about.
  4. Always try to model from your pictures. Directions aren't always right. And the part molds/prints aren't always right, either.
  5. Yep, cut 'em out, dip in Future/Pledge/whatever that stuff is called today, paint and install.
  6. Nicely done, Grant. The wiring is top notch and that dash is superb.
  7. Wouldn't surprise anyone if they had ashtrays in those older jets. They did in the transports I rode in. Cockpit's coming along nicely.
  8. OC, never was one for them. I gotta find a couple of pix of me or my jet. Maybe in my slide collection.
  9. Thank you, EG. I just need the flight manual to keep the myriad of facts straight for y'all. I'm pretty free with telling some combat stories, mostly the funny stuff. The serious stuff I only tell a very limited few folk. Flying stories are usually funny stuff. I was very fortunate flying, never jumped out of a jet for any reason. Broke a few, but made safe recoveries.
  10. I flew with a guy who ejected at a high rate of speed. He was grounded for months, but eventually did get to fly again. Multiple waivers for stuff, like the special boot for one leg shorter than the other. Great guy, too. I forget what he was flying when he bailed out, but I knew him at Eglin, in Phantoms. The MB seat drogue chute was on top of the seat in the F-4 to slow and stabilize the seat. There was a barostat that senses a set altitude and we would separate from the seat with our seat kit and parachute. Think the altitude was 11,500'. Below that altitude, we just separated and the chute deployed. You guys are going to make me drag out my flight manual to check all this stuff.
  11. The right hand picture looks better to my old Mark 1, Mod 1 eyes. The headrest is more brick red, the safety gear looks more correct red and the green gear looks right, too. I can't believe the seat cushion is so fluffy, for lack of a better word. Every seat I ever sat on or looked at in a fighter was pretty hard. The seat kit, dark green box under the cushion, always amazed me how they stuffed a 1 man raft, with a gas inflation bottle, a ruck sack full of gear and an emergency locator beeper radio into it.
  12. I stand corrected then, EG. Too many old war-stories about that jet. Thank you. 😀
  13. The Mr Color is solvent based, so will have an odor. Don't tick off the Admiral spraying this stuff. However, it looks really good; I'm going to give it a try. Rye Field have a number of M1 Abrams kits, too, if you're so inclined.
  14. We had a T-33 seat we were strapped into, when I was in pilot training. It had a ballistic charge to propel us up some rails to about 50 feet or so. Got all hooked up, assumed the position with your helmet pressed into the headrest and pulled the side handle. POW up the rails and get lowered back down. That was it in 1970. I did para sailing, pulled behind a truck for land parachute training and an AF Twin Merc cruiser off an AF LCM in Biscayne Bay for water survival training. We did a lot of other egress training, as it was termed, when we got into the Phantom. Yeah, it's very aircraft specific. Although, nowadays, at least, the ejection seat used by most of our jets is the ACES II. I flew that twice, about 40 years ago. Much easier to strap in due to no leg garters. I'll explain. The Martin Baker seat required a number of connections via straps to the seat. Calf, thigh, butt(seat kit), lap-belt, parachute risers, plus comms, mask and g-suit. The leg stuff kept you from flailing legs, the butt clips were to keep you and the survival kit/one man raft connected. Since the "chute was built into the seat, you needed those. Proper upper body position was via the overhead handle rings or the one between your legs. Preferred was the one 'tween your legs, but on takeoff, that one would be hard to get at with the stick back into your lap. Again you had to assume the position. There is/was always a risk of compression injuries to the back, getting fired out of the cockpit. The seat started with ballistic charges sending you up the rails. A 6' lanyard, attached to the bottom of the seat, fired the rockets to shoot you up and way over the tail. I had one guy get a flail injury to his shoulder, due to his loose helmet coming off, flinging his arm back and chipping the end of his should bone. He was grounded about 3 months. The fatalities were usually due to ejecting outside the seat capability (too fast, too close to the ground in an unusual attitude). The F-104 was designed as a high altitude interceptor and the seat fired down. I think the B-58 did a similar ejection envelope. I believe the first one the Europeans got had these seat and when the need to bail, since they were flying low... The G model they ended up with had a normal upward firing seat.
  15. Cripes, the detailing in this kit is downright superb. What next? And you finish is flawless. 👍👍
  16. All too true, OC, but you must be able to see the goodies. At this and larger scales, we can see them. If you did this at 1/72, your sanity would be questioned.😉
  17. Cool jet, OC. I'm in, too. And your MB seat looks good. It's almost too new, you need to ding it up a tad more with the alu,👍
  18. Nice job on the cockpit rework. Just kill the white Evergreen styrene. It washes out the two shots fitting the cockpit to the fuselage. 👍
  19. Do the tests, Denis. The alternatives are painful and final. That plane looks like a flying corrugated fence. I suspect the thing was just grossly under-powered; the P-38 had counter rotating props and it didn't crash with losing 1 engine. Probably took a lot of rudder to counteract the dead engine/side.
  20. Yes, Denis, the fit of those panels is off. Hope you can patch them.
  21. You mean the "murder holes" for the boiling oil and large rocks? Inside the portcullis /gate. Our barbaric ancestors.
  22. Believe me, it ain't no cushion. It;s a thin piece of cloth, usually nomex these days, over a fiberglass seat bottom. Sit on 1 for 8-10 hours and you're a cripple. Much better seats in the Boeing tanker. Real cushions.
  23. You bet. It's critical to get the best use of these new paints. Your box lid for the set was absolutely no help.
  24. Might try Sprue Brothers.https://store.spruebrothers.com/category_s/2737.htm They carry the line, but I'm not sure about them carrying these paint sets. Here's the Gunze lines with the page covering the sets. http://www.mr-hobby.com/en/itemList.php?cId=7 The applicable sets are about mid page. Here's their English instructions for the Dark Yellow set Craig is using.: http://www.mr-hobby.com/en/itemDetail.php?iId=1917 here's te English instructions for the OD set: http://www.mr-hobby.com/en/itemDetail.php?iId=1916 They cleverly used the same instructions for both.
