Canute
Everything posted by Canute
  1. The B-36 was the Peacemaker. The Stratofortress is the B-52 aka to us fighter types as the BUFF. This is a family site, so I will use that style nickname "Big Ugly Fat Fellow". Boeing bomber products from the B-17 onward were usually some kind of Fortress, although the B-47 was the Stratojet.
  2. Denis, "12 O'clock High" featured B-17s out of England. An excellent study of the pressures of flying and fighting in that period. The USAF used it as a lesson for their Air Command and Staff training given to mid level officers for a number of years. Yes, the B-17s were pretty sturdy. And Monogram had a kit out years ago in 1:48 scale. Big beast.
  3. We have an outdoor railway at my train club. They have one set of tracks, but run equipment in scales from 1/20.3 scale to 1/32 scale. The garden folks don't get too wrapped around an axle about fidelity to prototype. They're outside running trains and they're good with that. And they have lots of space to install big speaker systems in their engines, generating all appropriate steam or diesel sounds. Darn things sound like the real thing.
  4. Danny, nicely done. Very credible garden railway scale logging car. We've got a few at my rail club's outdoor railway. And an often used trick with the short logs. Looking good. 👍
  5. That Walthers decal setting solution is Solvaset. It's pretty strong, since it was developed for laying down some older, thicker decals. Check out GatorMask.com. Here's his aircraft carrier (CV) page: http://www.gatorsmask.com/cv.html I think the Gambier Bay one is hull masks, but Bogue has deck number masks.
  6. Wefalck, have you seen the Alaskan gold dredges? I attended a model railroad convention, back in June and this was one of the structure entries.
  7. Flak Bait is a B-26, preserved in the Smithsonian. It's undergoing a renovation.
  8. Hornfischer's book was a good read. Those were some very brave men. Nice to see a build of a "jeep" carrier. Alex, I'm in.
  9. Denis, the green wire is probably floral wire, a soft wire(not sure what it is made from) that florists use with their flower arrangements. A lot of older train kits (cars and structures) used to use it because it's pretty easy to work with. It's still good to use, but there are better wire materials available, such as phosphor bronze wire. It's a harder material and holds it's shape when bent. Light house is looking good.
  10. Or maybe a helper engine pushing heavy trains up hills. Hope it had a stoker appliance to push fuel into the firebox, too.
  11. Not sure about the bright oil, although it may be a glossy brownish-black paint, to simulate an oil puddle. The Glaze was an additive for making the Floquil paints dry to a gloss finish. Normally, the Floquil were matte or flat finishes. If you wanted to apply water slide decal to a flat painted surface, the decals could dry with a lot of silvering, caused by air trapped under the decal. You would mix a little Glaze into the paint to make it glossy. I don't remember the ratio you'd need to use the glaze. I would paint the surface with the Floquil, then gloss it with Pledge/Future/Kleer. That's an acrylic floor treatment, but works a charm on models, too.
  12. Like what all your others buddies said, OC. Friends are folks you can open up to. Don't need to apologize.
  13. OC, hang in there, buddy. You and the admiral are in my thoughts and prayers. Keep the good attitude.
  14. Loctite make a glue titled Power Flex. Has a black label (because of the rubber?) Per my source, it's a gel. So you'll get a little working time. I myself will be looking for some of this stuff after my current supply gets used up or solidifies.
  15. Sorry to read that, Mark, but you know your heart. We'll be here for you when you feel the need👍.
  16. Denis, that turned out very well. Locos back then were real beauties; the builders and owners were proud of their creations. This one fits in well with those old engines.
  17. Nice video. Gives a good understanding of what it took to keep a steam engine running. One reason for dieselization.
  18. Cabbie, here's one brand from Loctite: https://www.loctiteproducts.com/en/products/fix/super-glue/loctite_super_glueultragelcontrol.html
  19. Denis, most modern fixed wing a/c have retractable refueling equipment. USAF favors doors to receptacles in the body, most other airforces (including naval forces) favor a probe on the receiver and a drogue (basket) on the tanker. Same for helos. I think the USAF version stems from the 50s and Gen Curtis LeMay. Control and use of tanker assets. Blades better droop, means they are flexible. It's like wings flexing; they better or the wings break off.
  20. That probe sticking out front does several functions. It is part of the pitot static system for airspeed. The fins are for angle of attack (AOA) and I suspect sideslip for the helo. Looking at Soviet/Russian jets, they all appear to have similar probes to the one on the Hind. A simple yet reliable system. We had a small cone shaped protrusion on the left side of the Phantom's nose, which was the AOA probe. The AOA gave us an audio signal as we approached stall condition. If the audio didn't get our attention, the frontseater got a foot massage as additional reinforcement. The right rudder pedal shook to get his attention.
  21. That's a bummer. Good luck chasing that down.
  22. There are rubber filled CAs available. Helps reduce the shearing issues of CA.
