Canute
Everything posted by Canute
  1. What a change from the first generation WW I tanks in just a year or so. Interesting critter.
  2. if there is a film on the resin parts, wash them in Dawn and warm water or at least prime them with Tamiya thin primer. Most acrylics don't stick to parts if these oils aren't removed.
  3. Nice builds of these stalwart destroyers, especially in 1/700. Well done, Alan. 👍
  4. Interesting build, Alan. I'm in, too. Were these the Parthians or a successor regime? Those Mideastern lands gave Imperial Rome quite the hard time; as bad as the Germanic tribes did in Europe.
  5. Wood railcars of the 1800s used trussrods to level out the floors. The floors sagged in the center, so several trussrods were run from the end beams toward the car center over queenposts. There could be as few as 2 rods up to 6 that I've seen in photos of the old wood passenger and freight cars from the 1890s. Turnbuckles tensioned the rods; some were near enough to another rod that boards could be used between the turnbuckles to prevent the turnbuckles from loosening. These boats most likely were build using similar engineering principles. They just didn't have to put up with the jarring ride over the rails.
  6. You might want to consider that there was wartime censorship of these weapons systems. Or it could just be their construction sequence. Cross reference several photos, if available,
  7. Two items. First the kitbash/corrective surgery. I think we're both pointing you in the same direction. Sometimes manufacturers generate a kit that doesn't follow published plans. They're close, but sometimes parts are cast to ensure ease of removal from molds, in a plastic kit, or structures are simplified for ease of construction in a wood kit. What's the modeler to do? He does corrective surgery or kit bashing to make it look more like the photos he's using to build with. Sometimes you add extra parts, sometimes you may have to modify or adjust parts. It's all part of being a model builder versus an assembler. Second item, orientation of the conning tower: The halfmoon projection on the lower part, facing the stack area, should be on the forward side of the tower. At least that's what the picture in post 20 shows.
  8. Follow you pictorial evidence for the tower. May be doing some kitbashing to correct this.
  9. As a freshman student programing in FORTRAN way back when, that was an axiom of ours. Not much changed in 60 years.
  10. Like your work masking the deck. 👍 And your PE catapult and crane are "the cat's meow".
  11. Excellent work so far, Alan. Yeah, his beard and hair would give him a more menacing look with a bit of a shine to them.
  12. That's one beautiful build, Rob. The F1 racers are so aerodynamic. Well done. 👍
  13. That's better than being a Supervisor of Flying at an Air Force Base when all the aircraft participating in an airshow show up. Many do arrival shows, especially the military flight demo teams. That only happened once a year.
  14. Think you hit that nail on the head with the backdrop, Eric. Really like the wispy cirrus clouds. Keep it up!
