Everything posted by ccoyle
More exciting Oscar action! Moving forward (literally) toward the engine mount. The mount consists of three concentric rings supporting a bulkhead. You can see that the fit hasn't been so good on the first two rings, and there is an ugly gap at the bottom. I think this gap will eventually be filled with wing and covered by a fillet -- hopefully. But having nothing to brace the engine bulkhead is worrisome. Any pressure applied while mounting the engine could possibly collapse the structure. So, I measured the gap between to two bulkheads and cut some scrap card stock to act as spacers. And here's the last ring + bulkhead added. Once this dries, I will fill in some of the loose seams with white glue, but this will all eventually be hidden by the cowling. A handy tool to have for card modeling is a screw punch. I got this one for Christmas a couple of years ago, along with a set of ten bits in 0.5 mm increments from 1.0 to 5.0 mm. Here I've used it to punch out the two holes where the wires for the horizontal stabilizers will be inserted. And lastly, I cut out the remaining rear fuselage pieces so I can edge color them all in one batch. Soon we'll have a fuselage! Stay tuned!
Based on my experience, whatever you do, DON'T use an open flame. Styrene's melting point is pretty low. I'd start with the hot water and try that.
It might sound gross, but licking the part actually does the job nicely. 🤢 (BTW, licking might sound like a risk for damaging the paper fibers, but paper fibers consist of cellulose, for which humans lack the necessary digestive enzyme). For larger surfaces, I use a damp paint brush. I will sometimes delaminate a part if I judge the card stock part to be too thick. An example of this is the flags used in my 1/250 ship models. The flag is usually printed on card stock and designed to be folded to produce a two-sided finished flag. But such a flag is too thick to drape properly. Thus, I lightly wet the card stock, allow the water to penetrate the layers of fiber, then use a knife tip to separate the printed top layer from the remaining layers. I'll even gently scrape away any unwanted residual fibers from the back of the part. Card stock is also generally bad for forming tubes of very narrow diameters. To understand why, one must remember that a sheet of card stock is a three-dimensional product -- it's actually a very thin rectangular prism made of multiple layers. The layers of paper in the printed part want to shift as the tube is rolled, because each successive layer, going from top to bottom, must form a narrower tube than the one above it -- visualize what happens when you try to roll a magazine into a tube. The narrower the tube, the worse the problem is. One solution for this is to delaminate the printed part and then wrap it around a piece of styrene rod.
First of all, "moistening" in this case means very lightly wetted -- only enough to cause the paper to slightly curl. There are times when I purposely want card parts to delaminate, but when forming parts, if the card starts to delaminate, then it has gotten too wet. And yes, I do use a variety of "tools" to form parts. Some are actual tools, but most are just whatever cylindrical object is handy: knife handles, paint bottles, dowels of various diameters, etc. The side of a Titebond glue bottle happens to be perfect for many of the oval cross-sections of a fuselage.
Ah, memories! This was my first POB kit. Be advised, there are some issues with the instructions, unless they have been subsequently fixed. The biggest issue, as I recall, is that the instructions describe a single-planked construction, when the kit is in fact double-planked. I'll have to root around and see if I saved my construction notes somewhere (this was 20+ years ago). Cheers!
Cockpit area skinned. I joined the three sections together before adding the framed assembly. The fit was actually quite loose -- to offset this, I only tacked the outer skins on in a few spots, no forcing or squishing things together. I am quite pleased with the result -- the seams are snug, the panel lines align perfectly, and I didn't get any glue globs or smears anywhere. Everything is good to this point.
Moving forward with the outer skins. The first two sections have been joined together, but not yet to the inner cockpit skin; before the final placement of this shell, I will make sure that the first three sections, which will cover the length of the cockpit framing, align perfectly (or nearly so) and will fit the frames without any forcing. Each skin is slightly moistened, to weaken the paper fibers, then carefully formed into the correct shape -- it will hold its shape once the paper dries. Most of the sections will be butted together with the aid of a joiner strip; the flat piece in the photo has had its joiner strip attached and is now waiting for the glue to set before shaping can begin.
Once the inner cockpit skin is applied, the visual value of a tidy cockpit is somewhat lessened. BTW, another minor knock against this kit -- on the port-side interior of the cockpit (not visible in this image) is a cylinder of some sort, perhaps an oxygen cylinder or fire extinguisher. There are no location markings for the cylinder on the cockpit skin. The cylinder is shown in two different diagram views, but its location is different in each view. Thus, in the absence of corroborating evidence from other sources, the correct location for the cylinder is a bit of a guess. This lack of specificity in the diagrams was something I wrestled with during the Mohawk build.
Seat installed. After I finished the bottom portion of the seat, which consists of two layers of card, I discovered I had put it together incorrectly, with the outside layer on the inside and vice versa. Oops. 🙄 I thought it wasn't going together very easily -- now I know why. A thing to keep in mind as a builder when fretting over cockpits is that viewers like you, dear MSW member, are seeing this from an angle that will be quite impossible once the skins are on.
Okay, for all those who are interested, here's a lesson in card model error creep. In this first photo, I have used my incredibly expensive and precise calipers to measure the width of a slot in one of the wing spars. As you can see, this slot is about 0.4 - 0.5 mm wide. The billet that contains the part that will fit into that slot is also about 0.4 - 0.5 mm wide, which of course means that the part should fit snugly into the slot -- no problem. Now before we go further, we must keep in mind that a card model kit is designed and printed so that it can be built without after-market laser-cut frame sets. Normally, the internal frames would be glued onto either chipboard or laminated sheets of card and then cut out. It's up to the builder to make sure that the cardboard + printed parts + glue (this last part is often overlooked) comes out to the desired thickness, or about 0.4 - 0.5 mm in this instance. In many instances, if a laser-cut replacement part is used, the printed part is simply omitted from the construction. But what if a printed part has color on it, i.e. it's supposed to be visible after construction? Take a look at this next photo -- here I've measured the thickness of an internal bulkhead. It's a laser-cut part + printed part + glue. Notice it is now about 0.6 mm thick, not 0.4 - 0.5 mm. That's because of the added thickness of the printed part (printed on bond paper) and glue; it would be even thicker if the part were printed on card stock. We're only talking about 0.1 mm of error here, but the key word in error creep is creep -- little errors can add up to irksome headaches in precision kits. The solution in this case was to cut off and use only the colored portion of the printed part, thus avoiding the extra 0.1 mm that would have been added to the end of the floor piece if the entire printed part had been used. Will this reduce error creep in this model? We hope so! Stay tuned to find out if it worked. 🙂
Nearly every card model goes through a beta build, so somebody was able to build it correctly! Error creep can happen in several different ways, improper cutting and gluing being one such way. Another has to do with the tolerances built into laser-cut parts; sometimes, a colored part laminated onto a laser-cut part can make the part too thick. I'll try to get some photos to illustrate this later.
I'm trying very hard to do this kit justice and make everything as neat as possible. The first real test of the build's success will be seeing if the inner cockpit skin fits correctly (it should -- I've already cut it out and have test-fitted it). You may recall that the inner cockpit skin was where the Curtiss Mohawk build started to go sour.
Congratulations on the launch of your launch!
- 5 replies
- Model Shipways
- Bounty Launch
I have a soft spot for the Tribals ever since I built Revell's old Ark Royal + Ashanti combo way, waaaaay back in the day!
I agree. Each method of construction has its own particular learning curve. I started with POB and have attempted two solid hulls, neither of which I was entirely happy with (never finished either model). One of our members, Chuck Passaro, has written a couple of practicums based on Model Shipways solid-hull kits -- here's a link to the one based on Sultana. You might find some useful tips in there. Over the years, a couple of MSW members have finished Smuggler. It makes a very handsome finished model, so I hope you will press on through the difficult patches. Cheers!
- 104 replies
- Bluejacket Shipcrafters
- smuggler
HUGE card model gallery -- eye candy galore!
ccoyle replied to ccoyle's topic in Card and Paper Models
I buy most of my models direct from the publishers in Poland, with the exception of HMV kits which I can purchase here in the US through Amazon (or through this website). I have purchased through WAK, Orlik, and Halinski, all without any problems. -
Yesterday I stumbled across a card model site that is new to me, called Kartonowki. As the name suggests, it's a Polish site, and there is no option for viewing it in English (unless your web browser can do so). I have always said that the Poles must have a gene that makes them natural-born card model masters, and this site's gallery (nearly 5000 entries) supports my theory. Check it out if you have time -- you'll be amazed!
