russ
Posts posted by russ
- John Allen, Mahuna, michael mott and 7 others
10
This is one thing I cannot bring myself to do. My lugger will not have any paint on the deck even though the boats always had a painted deck. I just cannot bear to cover up the deck planking with paint. I should, but I will not.
Russ
- cog, Omega1234, popeye the sailor and 4 others
7
John:
The shrimpers with whom In have spoken just called it a rub rail. It may be that some of them are not old enough to recall its exact purpose. I have seen many photos with the tire slung over the side. That may be the answer to Carl's question.
This boat worked for Biloxi Canning so it would have been docked out front. You might be thinking of Cruso's which was around back near the old bridge.
Thanks for the kind words.
Russ
- popeye the sailor, cog, mtaylor and 1 other
4
This may represent a transition period between the use of the two rub rails. I have seen these wider rub rails on other vessels from other parts of the US and you can sometimes see them used as a foot hold as they move along the side of the boat at sea. Maybe they kept it on for that purpose. I will continue to ask around to see if there is an answer.
Russ
- popeye the sailor, mtaylor and cog
3
There has been a little more progress. This boat has two rub rails. I am told that the earlier boats had a single rub rail that was much wider than the hull planking. Later boats have done away with the wide rub rail and often have the thinner rub rail that is a bit thicker than the hull plank. This boat happens to have both of them. The thinner rub rail runs from bow to stern and was gotten out of a piece of square stock. The wider piece had to be cut to the curve of the hull and was a bit trickier, both to cut and to fit. I needed to install hidden pins along its inner edge to be able to attach it to the hull. Here are some pics. In the old photo you can see both rub rails. The rub rail is dry fitted on the model photos. I might yet thin its width slightly, just for scale appearance.
Russ
Your model is coming along nicely. The pin rails look good. My only worry is that they would come loose during rigging. I like to dowel or pin those to the side whenever possible. Gives extra strength where it is needed.
Are you going to paint or tone the pins? Bluejacket has a brass brown toner that works well.
Russ
Are they brass? If so, you can anneal them to make them more pliable. Then you can "spring" them around the deadeye and squeeze them gently to hold the deadeye snugly.
Russ
- thibaultron and mtaylor
2
This is a beautiful model. Congratulations on a fine piece of work. Well done.
Russ
- CaptainSteve, BenD, mtaylor and 2 others
5
Your rigging is coming along.
These square riggers always had a lot of rigging. Each sail had as many as a dozen lines.
Russ
- mtaylor, popeye the sailor, Piet and 1 other
4
Thanks for your kind words. I appreciate it. I always hope that something I can offer will help another modeler some day.
Russ
Thanks. I appreciate it.
Russ
- rafine, KenW, Landlubber Mike and 8 others
11
Mike:
Thanks. I am very fortunate to have access not only to documentation for these vessels, but a lot of local knowledge from men who actually work on these vessels.
Russ
- mtaylor and Landlubber Mike
2
Captain Roy 1948 by russ - FINISHED - 1/48 scale - POB - Biloxi Lugger
Carl:
Thanks. That will be the final design, but I will probably make a new set when the time comes.
Russ
