Everything posted by KeithAug
Yes very tricky Andy. I think I would have been tempted to start with a piece of dowel and then bore it out to form a pipe. Then cut the pipe into strips before shaping / reassembling the strips to give the desired shape. However your effort looks pretty good to me.
- 174 replies
- Vigilance
- Sailing Trawler
I replace the capacitor recently - The original lasted about 8 years. I bought this on eBay and it worked fine. The simple test for a capacitor fault is to switch the motor on and kick the blade over manually (not with fingers). If it's the capacitor that is dud this should cause the motor to run. The function of the capacitor is to facilitate starting.
Cap San Diego by mikegr - 1/160
KeithAug replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
Looking very smart. Welcome back. -
Fascinating back story Phil. I look forward to more.
- 482 replies
- minesweeper
- Cape
Rick, that is marvellous. For some reason I hadn't thought that it would be possible to get details of the masts. Information on the masts and rigging is a big black hole in my knowledge and based upon the photos I should be able to do a much better job on both masts. Many thanks. Thank you Richard.
Ras - I always think that I should build the same boat twice to correct all the mistakes in the first one. I never do of course.
- 128 replies
- zulu
- sternwheeler
I'm not that clever Andy. So am I John. It tends to develop further each day on my dog walk. Thank you Rick. It is inevitable that I find the very bit of info I need the day after Cangarda departs. The only areas where I am a bit short of info is around the bowsprit - the various deck fittings and the protrusion through the bulwark. I think these were fairly inaccessible when you were aboard due to the covers being on. Also do you know if the roofs of the deckhouses are really white or is this just a protective covering? The details of the awning supports are very useful thank you.
Ras - It is funny what I miss in passing. I have only just realised Zulu has two paddle wheels. Are they on a common shaft or can they rotate independently?
- 128 replies
- zulu
- sternwheeler
Very crisp work Richard - the plan looks a little daunting.
- 454 replies
- Union Steamship Company
- Stepcraft 840
(and 3 more)
