KeithAug
Everything posted by KeithAug
  1. Gary, the last couple of shots show her off to perfection, beautifully done. Being super critical just to bring you back to earth, are 2 of the planks at the port bow a little recessed or am I looking at a bit of filler?
  2. All looking very neat Jon. Yes it is a pity that most of us are unwilling to lower our standards to match reality.
  3. That sounds a bit annoying. Maybe I'll stick to the traditional method for a bit longer.
  4. Glen - it only works with CA glue if you plan to leave a varnished wood finish. If you try to use PVA it leaves a blemish. PVA is ok if you are going to paint.
  5. Keith - I just took it as an innocent and sensible question. No need for any apology my friend.
  6. Keith - Ann is fairly ok with Cangarda. We have a large playroom that was vacated by the children many years ago and finished models generally go in there. It's when we inevitably downsize that the problem is going to occur and some difficult choices will have to be made.
  7. Thank you Andy - i wasn't aware of such devices. I do a bit of internet searching.
  8. Keith - I can't remember if anyone has asked. I am building at a scale of 1:24 so from the above:- LOA = 5'9" LOD = 5'3" LWL = 4'3" Beam = 9" Draft = 3.8" I hope you are both keeping well. Best wishes.
  9. Printing seems to be a quick process these days. I last had a look at printing 7 or 8 years ago when most people seemed to have to try, try and try again before the printer produced something usable. I assume printing is a much more user friendly process these days?
  10. Well that turned into a bit of a non event. A typical case of overthinking the problem on my part. The curve that I was worried about is a bit over emphasised in the next photo. I had tried bending the 1/32 ply around a dowel of slightly tighter radius than I needed (allowing for a bit of spring back). Bending the ply dry wasn't working so I boiled up some water, lashed the ply to the dowel with rubber bands and dunked it in the water. Almost instantly the ply became compliant and pulled tightly against the dowel. I then left it overnight to dry out. To get rid of the sharp discontinuity between the small and large radius ends of the plywood strip I repeated the process for the large end using a much larger radius former. It is easier to sand the hull without the compensation plates in place so I had another go over the entire hull with 180 grit paper. The individual planks have now blended together pretty seamlessly. The next step was gluing the compensation plates in place using PVA glue. It was pretty easy to get clamps on the edge nearest the bulwark but I had to revert to the use of pins on the opposite edge. The holes will have to be filled but this isn't a problem because they will be painted over. The not so tricky curved piece was then glued to the aft part of the hull. It was tricker to use clamps here because of the presence of the building board, so I just used pins. Because I didn't wreck the aft piece I didn't use the scarf joint as recommended. Maybe i will remember earlier next time. The starboard side went on equally easily. As I work on the hull I find blemishes and defects which need to be fixed. I keep a pot of sanding dust handy to address these. I dribble a few spots of CA glue on the defects and dust it over with the sanding dust. Once dry a bit more sanding usually cures the problem. That's all for now folks.
  11. The diorama work is all very educational Glen. Thanks for the lesson.
  12. You are making me jealous again. Lovely river adventure.
  13. Ah! the shipyard reopens. Welcome back to building Brian. Your lightsabre produces remarkably clean work, the windows in particular look wonderful.
  14. lovely job on the navigation lights and buckets Valeriy. I had to magnify the buckets to see how you had done the handle connection. A cunning piece of visual deception. Very effective.
  15. A youngster then Ras. Many more modelling years left to add to your fleet.🙂
  16. R Ras - thank you for your kind offer. If I am not mistaken Zulu has the simpler non feathering type of paddle wheel. The ones that Eberhard posted were feathering paddle wheels. You probably know the difference but this video explains it well - I was thinking about making the feathering type so unfortunately Zulu's plans don't help a lot, but thank you anyway.
  17. I have always thought it would be fun to make a large working model of a paddle wheel. I have often seen Waverley on my sailing trips around the Hebrides and watched her paddles with interest. Maybe after Cangarda is finished I will have a go.
  18. Another good idea for the fallback position Michael. I will probably try the bending option tomorrow and see how I go. I think I have a lot of you guys waiting in anticipation.
