Everything posted by KeithAug
Sorry Tom I should have been clearer. I'm referring to the oval feature above the rubbing strip. John - there are other views but all are less distinct than this one. Michael - it seems to stick out, but other than that I can't see much detail. Roel - I agree it does look like one of those but they are usually attached to the grating itself and not the hull. Also as you say there is only one and it doesn't seem to be positioned adjacent to a gate in the guard rail. Not sure about that glen. A captain clever enough to ensure that he touched the dock at that particular point would probably be clever enough to avoid the collision. Seems a bit vulnerable Pat. As you say it would probably be better to have it on deck. Interesting Keith - but why only on one side? Yves, they are usually on deck, but anything is possible. It is on the port side but it would be tricky if Cangarda moored on her starboard side. It doesn't seem to have been present when she was rolled out of the builders yard:- Its a mystery! It does seem to be some sort of bracket in this picture:-
The dog on floor training seems to be going badly! Poor doggy on right seems to have had surgery🙁.
- 454 replies
- Union Steamship Company
- Stepcraft 840
(and 3 more)
Another week flashes by with the garden and my wife's birthday taking priority. However I did manage to sneak into the workshop for the odd hour or two. I continued working on the hull. The final piece of the "rabbet plank" was glued in place. Then it was time to sort out the end of the keel where it meets the skeg. The piece, made a couple of posts ago, was glued in place. The slot (bottom right above) isn't an error. The slot had to be over long to allow the skeg to side in place horizontally over the prop shaft. The slot will be sorted out once the skeg is glued in place. The piece at the end of the keel was sanded to shape and is now quite fragile. You may recall I broke the previous piece. I was jumping about a bit so the next job was to make and attach the rubbing strips. These have a "D" cross section and are 0.1" wide by 0.07" high. Fortunately the rubbing strips are parallel to the upper edge of the compensation plate so I was able to recycle my "port hole marker" to draw the parallel lines where the rubbing strips are mounted. I cut a plank 0.1" wide and rounded off the 2 edges with sandpaper to form the "D" The edges were slit off .070 thick on the table saw. I then attached the rubbing strips to the hull with masking tape. I then ran a bead of CA glue along the edge of the rubbing strip and the capillary action drew it between the touching surfaces. Next I think I will sort out the keel. At the scale size the keel is circa 0.1" wide by .25" deep and runs the full length of the hull from prow to skeg.
Good to see that she is back in build.
- 454 replies
- Stepcraft 840
(and 3 more)
The build quality continues to impress Paul. All looking very smart.
- 201 replies
- Oyster Sharpie
- first scratch build
Wonderful little display, congratulations Glen.
- 235 replies
- Banshee II
- Bottle
