Everything posted by KeithAug
Georges Merci pour le commentaire et bonne chance pour votre construction. Si vous avez besoin d'aide avec l'un des plans ou des détails photographiques, faites-le moi savoir. Je suis prêt à parier que votre anglais est de loin supérieur à mon français, alors j'espère que le traducteur donne un sens à cette réponse.
Keith, Druxey, Mark, Rick. Thank you for your comments. Fortunately here are the final few photos. I was having some trouble extracting these from my phone but a teenager helped and sorted me out. So this is the final batch. Thank you for everyone who has supported me throughout the build. I usually take some time off before I commence my next project so this will be my last post for a while. But as ever I will be supporting the rest of you during my period of inactivity.
Hi Keith, I think the critique of experts is by far the most valuable resource and what better review group that all my MSW friends. Gary, Eberhard, Andy, Gus - thank you all for your comments. I not getting much modelling done at the moment. My son and daughter have added to my wife's list of home improvement jobs. Never mind. I am approaching the end of my build log photos but here is the next batch. Probably two more batches left after this lot.
I agree with the comment above. I bought the saw and find it invaluable. I bought a cheap (eBay) disc sander to go with it and modified the table to accept the saws mitre gauge - this gives me all the accuracy I have ever needed at a fraction of the cost of the Byrnes disc sander. My advice would be not to try to convert the saw to become a disc sander. The though of sanding grit getting into the saw mechanism doesn't fill me with glee and I thinK you would be forever switching the saw between saw and sander.
Proper Technique for Jim Byrnes Saw
KeithAug replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Chris - A few pictures to illustrate what you are doing would help a lot with diagnosis of the problem. All the above comments are pertinent but to be absolutely sure the photos would help. I regularly rip long lengths of 1/4 inch mahogany using a .032" slitting saw blade. This isn't the easiest of jobs but generally it works fine. I have have to say however that a lot of variables come into play which can undermine the process. These include. - The dryness and type of wood. (Some wood don't cut easily, and some that do cut easily don't always cut easily. I sometimes find switching one piece of wood for another cures the problem). - The run of the grain ( the grain is rarely parallel with the edge and the blade can try to follow the grain - sometimes cutting from the other end cures the problem ). - Pressing the wood too hard against the fence ( can cause the plank being cut to progressively thicken (due to blade flexing) - creating a taper effect. Keep the pressure towards the fence positive but light). But as I said earlier - more info would help with the diagnosis. -
Thank you Valeriy, Druxey, Pat, Gary and Brian. Also thanks for all there thumbs ups. The next bunch of photos:-
Eberhard - I think I had picked that up from one of your earlier comments and had assumed that in such circumstances that trining the gun would have been required. Grounding seems to be a bit of a dicey concept given the flat bottom and limited freeboard / buoyancy. I bet they had some anxious moments waiting for the suction between the hull and the mud to let go.
Eberhard - I have to agree with Phil that the gun is particularly magnificent. Firing the gun on the beam must have been a particularly unwelcome job for the bridge crew.
Roger - it is highly probable that your eyesight is better than mine as I need my cataracts done. Below are the 4 shots showing the internals of the main deck house. These are the only ones which show the dining table. What I think I see is a mirror behind a silver cup and above this a cabinet that may contain glassware. Are these the ones where you see a model?
Ras - Thank you for explaining. I was aware that in some photos the sponsons were not obvious. What you say about recoil makes a lot of sense.
Bob, I sent a few shots of Germania to Jeff Rutherford when I asked for some information and I promised to send him the link to the build log once I started it. I haven't made contact with Mr McNeil. I am not sure that he would be interested in seeing a model when he owns the real thing - lucky man. I really need to get on with the photos before this log morphs into a Cangarda build log. Here are a few pre cleaning photos to get the build log back on track before I do the cleaning.
