Everything posted by KeithAug
What do I want for Christmas
KeithAug replied to Worldway's topic in Modeling tools and Workshop Equipment
Seconded -
I have made a start on the life rafts - 4 in total. I had a fairly decent photo to work from. The cradle in which they sit isn't very well defined but as it won't be very visible when installed under the benches I don't think this is too much of a problem. I did a rough sketch of the life raft and cradle. The rafts are 0.5" diameter by 1.1" long. Most of my wood stock is recycled from one source or another so its suitability is generally a bit problematic. I chose a piece of dowel and turned the life rafts, including the strap grooves. The wood turned very nicely producing crisp edges on the grooves. Once turned the rafts were parted off turned round and finished. The left over wood was placed in my good tiber pile. I then needed to accurately cut them in half to reproduce the opening flange. I drilled a hole in the end of a piece of scrap wood to form a holding jig. I then pressed the raft into this before cutting down the centreline on the table saw. I used a TCT blade with a .055" kerf as this was right for the .055" thick flange. I kept the halves in matched pairs although this wasn't really necessary. I then machined and sanded a block from which to form the flange. I then slit off .055" wide flanges before starting assembly. I then diverted on to the cradles (fabricated from brass). The circular segments of the cradle started life as a tube which was turned down to give the required wall thickness .020". The turning was done over a wooden spigot . I also bent up a bit of sheet to form the cradle base. The two parts were then soldered together. 2 parallel rows of .025" diameter holes were then drilled to take eyes for the raft retaining straps. Then the straps were parted off (.080") wide using a .020" wide parting tool. I made 10 although I only needed 8. A segment was then cut out with the jewellers saw to form the opening. You can just about see the scribed cut line in the next photo. I made a crude jig to hold the parts for soldering on the connecting straps. Slots in the aluminium guarantee the correct spacing and the steel bar and elastic bands provide the clamping. The connecting straps are .015" thick and .080' wide. The eyes for attaching the straps were also soldered on at this stage. The cradles were then cleaned ready for painting.
Good progress Allan, the furling gear looks particularly realistic. Allan, for future reference this company produces micro-bore brass tubing that is good for sleeves. It’s a bit expensive but you don’t use much. https://www.albionalloys.com/en/ https://www.chronos.ltd.uk/omega-search/?q=Albion alloys .
Eberhard, I have to agree and even worse without the benches in place. At least they will add a bit of diversity to the build process. Allan, I tend to buy things like this second hand from a local dealer. V blocks are handy but 1,2,3 blocks are probably more useful for this application (and a bit cheaper). see - https://www.arceurotrade.co.uk/Catalogue/Workholding/Vee-Blocks-Angle-Plates/Stevensons-Metric-Blocks. However if I hadn't had the V blocks handy I would have used lego or duplo blocks as they are accurate and cheap.
Keith, Eberhard, John, Richard, Boris, Kees, Pat, thank you all for your kind comments. Moving on, I next attempted the benches that sit over the life rafts. These benches disassemble and are variously shown in position or removed. I will build the model with all 3 benches in place, I won't reproduce the cushions as the photographs only show these when the boat is at anchor or moored. As usual I started with a sketch, scaled from the photographs. all 3 benches are of different lengths and I only needed to sketch the ends. The only slightly complicated elements were the feet. These were profiled on the mill before being slit off. All the other bits were cut out and the planked bench tops were made. I glued the ends to joining planks using a couple of engineers blocks to keep things square. Finally the tops were glued in place. I now need to make the life rafts but that will be another day.
Eberhard, I was not aware of this type of anchor although in concept it seems similar to what I would call a Danforth anchor. The stern anchor is what I have always called a Fisherman’s anchor. Both very nicely made given the limitations of scale. Taper turning 0.3mm steel rod is a bit of an achievement. Was it a case of very light cuts or did you conjure up some other technique?
Brian, isn't it annoying when life intrudes. Great job on the stove, I particularly liked the aluminium tape technique.
Thank you Richard and Gary and thanks to everyone for the likes. Well here we go again, shortly to be locked up for another month - good job we have a dog to get us out for woodland walks. The hatch was finished by creating a framed surround and then glueing it in place in the open position. I could have made it slide but the previous one (on Altair) quickly ceased up. It didn't therefore seem worthwhile. The underside was then given a quick once over with wire wool before being masked and painted with 4 coats of white acrylic paint. For no particular reason I then moved on to the "wings" on either side of the deckhouse. The box structure are variously photographed with planked tops and with protected skylights. As previously I went with the skylight version. Having made similar structures before I didn't need a very detailed sketch. The port wing is longest at 2.9 inches wile the starboard structure is only 1.85" long. Both are .650" high by .710" wide. As previous I started with oak cores. These were clad with mahogany frames and panels. The skylight frames were then made and glazed and brass strips were cut to take the protective bars. The brass strips were drilled and mounted prior to installing the bars. The bars were then installed. Finally the planked section was made to cover the exposed section of the longer wing. I haven't glued the tops on yet - a job for tomorrow.
Valerie, excellent shackle - and the extra bit of explanation was yer helpful. What diameter wire did you use?
Your builds pass too quickly Javier. This one is progressing at warp speed.
- 15 replies
- fishing boat
- small boat
Exactly so Michael. Eberhard - Thank you, but its not something you are going to find very useful at your preferred build scale.
Hello Kevin. Thank you for the compliment. I guess you were jesting but I think you can do it on the MF70. Use 2x24" planks of MDF attach one to the table, hanging out over the end of the bed. Put the pivot at the off table end and then mount the top MDF plank on the pivot. Problem solving is such fun.
Hi Michael, thank you for your comments. I only ever part off on manual feed so doing it slowly was fairly easy. I find soft solder is remarkably strong for jobs of this type, it rarely seems to come apart during machining. I did however make sure the parting tool (which was only .025" wide) was very sharp. Pat - I look at many models on this site with admiration, everyone seems to have something that they excel at. And so to cutting the roof end mouldings. I checked the curvature against a set of radius templates that I downloaded from the web. The radius required turned out to be 22". I improvised a jig to cut this radius. I started by cutting a piece of wood to be a snug fit in the end slot of the mill table. Into this I inserted a steel peg. A piece of MDF was then cut, one end with a hole to fit over the pivot pin and the other end with a "L" section cross piece onto which the mahogany stock was mounted. The distance between the pin and the centre of the cross piece was 22". The mahogany was mounted with double sided tape and the curved beam was cut by progressively passing it backwards and forwards while feeding the end mill down. It didn't take long and the results were fine. I used the previously made scraper to form the profile before glueing the ends to the roof. The corners were then manually finished so the moulding shape wrapped around the corner. The cut out for the hatch was then removed and the hatch runners and side detail was then commenced. The hatch planking was built on the roof to get the correct curvature. Sellotape was laid on the roof to facilitate this operation.
PoulD - Early on I did toy with putting LED's inside the hull but I knew that after the first few months I would never turn them on again. Thank you for your kind comments about my craftsmanship, I keep trying but have a lot of room for improvement.
Druxey, Steve, John - thank you for the compliments, they keep me warm as the workshop starts to cool - only 9 weeks to Christmas.
Keith - You are right to suggest it won't be possible to see them so it is somewhat pointless....................... but of course I will.
Richard, might work but at 0.2" thick I think it would have some memory and would flex back to a larger curve. I could over bend but this might be a bit hit and miss. I have worked out a plan to machine the planks to the desired radius. I'll try it some time this week and report on my success or failure later this week.
