Everything posted by amateur
Because both ends of the rope should turn in the same direction (and in the same rotation speed). Not usiong a gear and attatchinhg the crank on the 'rope-holding tube' itself will cause the rope to twist. Jan
- 1,148 replies
I guess it's a rather small vessel. perhaps coastal, perhaps even under gt 10000. Jan
very little to go on. Hazy picture, no background, rather standard design. Even no names visible in the pic... Jan
HMS Sloop Jan
I'm pretty sure it's not a guess btw I like the Dutch church. Jan
Adrieke thought he made it difficult to google the pic
Google an image.We can't disqualify you, as it is not against the rules. However, what's the fun of it ? Googling makes it easy (unless Andy is putting up his home made pics of lakers that are already gone to the breakers yard by now) Jan
Masts and funnel fit the Ormuz, the white band at the bow does noet.... There are alos a number of white-star ships that have this "four mast+onefunnel"-configuration. hmmm..... Jan
Or a pilot cutter...... Jan
Could be an old icebreaker.... Jan
Could be a Leda-class frigate.... Can't find the pic Jan
Another Friesland.. I'll be following this one with great interest. Frieslanbd is based on the Hohenzollernmodel. That particular model is fairly well documented by Heinricht Winter. There is a nice book (in German) around of this model (the model itself didn't survive through the last war) The kit has some minor and larger mistakes in it, but genenerally speaking it is a nice example of a Dutch warship of the era. The whole historic blabla of Mamoli is nonsense. There never was such a ship names Friesland (and the Friesland that existed was of different build than this ship). Nevertheless, a kit worth building. (I did hesitate long in choosing between Prins Willem and Friesland, and I finally went for PW. Unfortunatedly, my house is far too small for two of these large models.....) Jan
Just to get the dimensions right: has your green cutting mat a centimeter- or an inch-grid? (the 'direct' question is ofcourse: how wide are the separate parts of the sail?) Jan
I guess you're right. Jan
But the colour of the hull and the number of masts are correct You have to go a bit to the south: Adrieke is/was/used to be Flemish Jan
Danmark is two mast square rigged, this one is not.... and Adrieke is not Danish Jan
There is quite a lot on all kinds of Dutch ships, but most of it is in Dutch. Google Van Beijlen (or alternatively Van Beylen) and you'll see quite a lot coming up on botters, hoogaars and other Dutch ships. Jan
The book bij Sopers dates from 1947, and has seen new prints in 1971, 1974(?) and 2000. Still widely available second hand. Jan
Ofcourse they are not the same: why use tow names for the same ship (more often in Dutch, different ships share a common name) Botters are fishing ships (see-going, originating from the southers parts of the former Zuiderzee) Boeiers were originally small freightships, in later years (i.e. from the 18th century onwards) mostly build as yachts. However, the shiptype called boeier did evolve quite a bit, as can be seen in this 17the century picture..... Different rig, different hull, different everything. Still: same name..... Jan
An other way for the blocks could be: tie a half hith knot, and use one seizing to tie the loose end. But: nobody ever siad there was a quick way of doing these things Jan
