Roger Pellett
Everything posted by Roger Pellett
  1. Wishing you a speedy recovery from your upcoming cataract surgery. Roger
  2. Looks good Keith! I agree putting the right frame in the right slot is usually a good idea😆
  3. Great to see another post 1900 scratch build here. Looking forward to upcoming research and construction of an interesting vessel. Roger
  4. I had some time this evening to do a little research about your anchor problem: I. Pattern: Anchors with folding metal stocks were used in the early 1800’s especially for kedging. The photo below reproduced in the book Anchors, An Illustrated History shows one such anchor recovered in Tahiti from one of Captain Cook’s ships that grounded there in 1773. It weighs approximately 950# II Weight: Much harder to answer. Harland gives a number of formula not all make much sense and results must be translated into dimensions. He points out that logically that the length of the shank should not exceed the dimension waterline to Cathead. Keep in mind, these are small vessels in reality large boats. I would suggest a pattern like my photo with stock folded lashed securely to ring bolts in deck. Roger
  5. Steven- You’re doing a great job! Your customer should be pleased. In addition you should qualify for the MSW Time Traveler Award. San Marco Ship- Titanic 800+- years apart.
  6. Looks like an interesting project! You could duplicate the picture on the the box as 54 mm Civil War era figures (1:32 scale) are readily available. Roger
  7. To designate a vessel for National Historic Landmark status it is Necessary to prepare and file a Historic Structures Report (HSR) with the US National Park Service, an arm of the US Federal Government. The process can be quite complicated and HSR’s can vary in quality. HSRs are supposed to include Measured Drawings of the vessel in question. The National Park Service has posted a number of these HSR’s on line and I believe that includes one for Hercules. The drawings in the Hercules HSR should be helpful in adding details to this kit. Roger
  8. Naval Architects have an elegant term for that. It’s called Slamming!
  9. It may just be the angle of the photo but those anchors appear to be over scale. If the revenue cutters were actually fitted out with the metal stock anchors it would that they would have been brought inboard, the stocks collapsed, and the anchors stored flat on d.eck lashed to ringbolta. Roger
  10. Have you read Shattered Sword? If not it might be an interesting book to take on your trip. It would be of interest as the authors describe in considerable detail how American and Japanese operated and how these operational details affected the outcome at Midway. You might find some gems that help you to better understand constructional details not explained by the instructions. Roger
  11. Epoxy cures with an exothermic reaction. In other words the chemical reaction itself creates heat. So, while curing, heat needs to be transferred away as fast as it is generated. In most cases the surface area is large relative to the thickness of the Epoxy so heat buildup is minimal. In your case the Epoxy is thick and the space confined. I have mixed epoxy in a 2oz piper cup and it got too hot to touch. If possible, can you pour it in layers to minimize the volume being cured? Roger
  12. At least one Epoxy manufacturer, West System, used to sell pigments formulated to be mixed with their resins. There are of course, pre packaged Epoxy paints. This is all the realm of full sized yacht finishes but should work for you too. I believe that Urethane marine paints are also applied as a finish coat atop Epoxies. Roger
  13. It may seem strange, but in the wooden shipbuilding era, ships and boats were not always built to the Naval Architects drawings. The final design was often done by modifying the lines on the mould loft floor. This may account for some of the variations that you are encountering. Roger
  14. Yes, it sounds like the guy, although I thought that he had a definite release date. Roger
  15. There is supposedly a guy in prison who recovered $$$$ in gold from a wreck in US Waters. He stashed it somewhere and lost a fight with the authorities regarding possession. He will be released in a while and as he had paid his debt to society will be able to enjoy his loot. He apparently thinks that this is a good bargain. Roger
  16. The main user of water from the sea chest is of course the condenser for the main engine. Period photos and drawings for various ships and the condenser for the 1896 main engine of the historic Steamship SS Meteor have the condenser located on the engine’s port side. This means that the hotwell, air pump, and feed pump would also be located on the port side. The air pump and often the feed pump were driven by a link to the engine crosshead. The sea chest would be located on the same side of the vessel as the condenser to minimize the run of of piping to it. The engineer controlled the engine while standing on the operating platform that was located on the side opposite the condenser as the shaft and linkage for controlling the engine’s rotation had to be located on the side opposite the linkage for the air pump. The direction of rotation of the propeller was a function of valve timing, nothing more. The engine was reversed via a linkage that changed the valve timing. A major advantage of the triple expansion marine engine was that it turned slow enough to be connected directly to the propeller. Expensive, difficult to manufacture gearing was was not required. I see no reason why the sea chest could not be located on the starboard side, provided the engine’s condenser and pumps were located on that side also. A twin screw vessel would have sea chests on both sides with a “port condenser engine and a starboard condenser engine.” The operating platform would then be located between the two engines. Roger
  17. I have a Byrnes Saw bought shortly after they first became available, so it’s an old timer. My interests include scratch building of warships’ boats and completing a very long term project; a steel hulled Great Lakes Steamship. I do not anticipate building a classic POF sailing warship model. Never less I continue to find new applications for my Saw that were totally unanticipated when I bought it: cutting sheet brass and thin craft plywood, cutting dimensioned grooves in jigs to hold parts to be soldered, and most recently slicing off dozens of 1/32in thick hatch boards from a laminated stack. The saw also did a great job of cutting a tapered blank for the mast of a Longboat model. While many of these jobs could be performed by a milling machine, they’re expensive too, and setup is often more difficult. In addition to its rigidity that allows accurate square cuts, the saw’s versatility is due to two features; the ability to raise and lower the blade and the 1/2in arbor that permits metal slotting blades of various widths. I have never needed a tilting arbor ( which the saw doesn’t have), the extended fence, or the crosscut sled. I did make a sled from a piece of aluminum angle, with an adjustable stop that fastens to the saw’s Standard miter gage. It’s a shame that high shipping costs, customs duties, etc. limit access to this remarkable piece of equipment to those living outside of the USA. Roger
  18. Bob, As our resident paint chemist, what about Japan Colors? Roger
  19. How about a sight glass for checking boiler water level?
  20. And of course, you can make up your own custom color by mixing artist oils, the kind sold in tubes, with linseed oil.
  21. I’m Assuming that your Tar Colored Wash is what Americans would call an “oil based wood stain”. This is nothing more than artist oil colors mixed in linseed oil so diluting the stain with more linseed oil should work fine. I agree with Druxey that stains don’t cure rapidly as they are intended to be top coated with varnish. There is a product called “Japan Dryer” that when added to linseed oil based coatings speeds up curing. It should be available wherever you buy paints. Roger
  22. Although US Navy aircraft carriers are prominent features of WW II operational histories and battle accounts very little seems to have been written about the nuts and bolts of their construction. (I don’t have Norman Friedman’s book so maybe I’m overlooking something.). This build really highlights the complexity of these vessels. Well done! Roger
