Posts posted by G.L.
- Captain Poison, tarbrush, mtbediz and 1 other
4
- tarbrush, mtaylor and Captain Poison
3
- mtbediz, tadheus, Captain Poison and 3 others
6
- mtaylor, tarbrush and Captain Poison
3
Part 13: Making the rudder.
13.1
The rudder is made of three oak planks, the main piece and two after pieces. Because the main piece is thicker than the after pieces. I lay a small sheet of brass of half the thickness difference below the after piece planks to glue them together. I lay also a similar brass sheet on top of the whole to put some pressure on it while the glue is drying.
- Mirabell61, mtaylor and tarbrush
3
- tarbrush, Captain Poison, mtaylor and 1 other
4
- John Allen, mtaylor and tarbrush
3
- Captain Poison, John Allen, mtaylor and 1 other
4
My frames are also a little too short. It is not really a problem for the most of them because their top ends will be hidden by the inner and outer planking, but the fourth futtock of frame sticks out of the sheer rail and must be lengthened at both sides. To have a larger glue surface, I saw them off under an angle of approximate 45° and glue a comfortable long piece on top of it. I do the same with the fourth futtock of frame C because this one remains also visible.
- mtaylor, Captain Poison and Canute
3
On 11-1-2018 at 11:28 AM, Mirabell61 said:
I like your companionway with doors and slide cover G.L.
What have you been using for the resembled dark caulking lines on deck, are those black card stipes ?
Nils
Yes Nils, I use strips of 220 grams black paper which I glue at the side of the planks with ordinary white wood glue before fixing them on the deck beams.
G.L.
- mtaylor and Mirabell61
2
Aviaamator,
Your tree nails with the dark edge look fantastic!
G.L.
- aviaamator and PeteB
2
On 11-1-2018 at 8:55 AM, vaddoc said:
I just came across your log G.L, very very nice. I think that your deck looks fantastic.
But just for your lofting using pencils and rulers without the help of computers, you have my respect!
What do you use for brass blackening?
Regards
Vaddoc
I use an oxidant which is called 'oxidant 1130', it is mainly used for brass but it works also with copper. I don't know the exact name or the composition of the product. I buy it in a shop for artist products in Ghent (Belgium): 'De gouden pluim' ( http://www.degoudenpluim.be/ ). They fill it in the wanted amount in plastic bottles.
Oostends schipje by G.L. - scale 1:20 - Ostend shrimper - first POF - Edition 2
Shaping the tiller arm with fret-saw and file.
