Remcohe
Everything posted by Remcohe
  1. Absolutely marvelous Greg! What did you use to 'fixate' the Fiebings dye, I noticed mine is water soluble even to the touch of a damp finger. Remco
  2. Go for it guy's make lots and lots of pins They are key to position parts temporarily, I don't exaggerate but I think any particular beam in this build is taken in and out at least 100 times to position parts, mark mortices etc etc. So today I did a little detailing of the gratings. I simulated the pins that were used by making small holes with a needle and then taking the same needle tip loaded with graphite to enhance the holes. This really takes your mind off-line after a busy day For comparison, the 'big' bolts on the corners are 0,4 mm Remco
  3. Thanks guys for your very kind compliments. Sure Maury, the pictures speak for them selfs. I use spring steel wire 0,5 mm cut to different lengths and the tip slightly grinded in to a point like a needle. After the copper wire is coiled it's silver soldered to the pin. I use a potato to act as a heat sink, you definitely don't want to anneal the steel, this happened to my first batch of pins and the steel becomes soft. Remco
  4. Thanks guys. Greg the pins are easy to make, I think they rank amongst the top 10 most used tools in my build. Ben, with my scroll saw they were relative easy to make and there were no remakes :-) I couldn't find an appropriated sized piece of brass for the iron knee so I made it from boxwood and tinted it black with Fiebing's leather paint I'm also doing lot's of mortice cutting for the remaining carlings and ledges. A little off topic, but it was time to make a better storage for my chisels. They used to wander over my bench with the tip protected by a little piece of isolation foam. This was a nice little project, keeps them safe and organized Remco
  5. TJ, great idea, I did the same. Remco
  6. Thanks Piet. Jan what can I say, the MSW Oracle didn't answer and I went forward taking a 50% bet I got it right Meanwhile, more knee's opposing knee's gratings and so on. Everything is loosely fitted before marking the mortices for the ledges. Doing tasks in batches certainly speeds things up. Remco
  7. Thanks Duffer. Your right Joe..... So I continued and didn't change the mortices. Getting the round up of the deck into this special beam took some patience... Remco
  8. Thanks Mark I have a question, without really thinking about it I cut the mortices for the tabs of the beam arm half blind, but when is was shaping the tabs of the beam arm I started thinking if this is correct. The tabs could also be the full with of the receiving beam. TFFM discribes the beam arm is bolted to the opposing beam so the half blind mortices would give extra strength but the whole fitting is different than the carling and ledges so maybe unnecessary complicated. Its just to know how it was on a real ship because once fitted the different is not noticeable unless one could crawl under the lower deck :-) I haven't cut the thickness of the tabs yet so I can go either way. Remco
  9. You make it look so simple, but this must be difficult parts to make and fit so neat to the beams Remco
  10. Sweet! So now you're planning on how you're going to make the locking mechanism for the loading door? Remco
  11. Good to see you back Mark, you haven't lost you touch, beautiful as ever. Remco
  12. Beautiful, it's almost a sin to lay planks over the finely detailled beam construction. Remco
  13. Martin, on the left is a workbench I only use for building full size parts like jigs and furniture. I had some alignment issues with the carlings so I decided to cut all the mortices for the remaining beams and marked them all using a batten. Important lesson to remember for the upper deck.... Pillars are installed temporarily and still need to be chamfered. Remco
  14. Nice close ups. All the details really come out well after the coat of primer, the metal sheets look is particularly realistic. Maybe here thanks for reminding Andy, don't we all hope to see some rivets Remco
  15. Piet all the work you put into the hull paid off. She look tremendous! Permission granted to be really proud of yourself ;-) Remco
  16. Ed no magical powers, I did use a building board to erect the frames and to make measurements inside the hull. But whenever possible I take the model from the board and work seated. Ok, maybe the space are I do most of my work is tidy the rest of my shop isn't. Especially for you Joe I immediately took a picture as the shop is right now. A bit distorted as I made a panorama picture to capture the whole shop. One might wonder why no storage on the walls, I had that in my previous shop and it takes away an enormous amount of light. One cannot have enough light :-) It looks small in the picture but the room is spacious enough measuring 4.40 x 2.70 m. Remco
  17. Thanks for the appreciation. Greg's right, starting with a cross section (and a cross section is already a big project!) is good advise. Today something different. For some time I've been using a small board as a movable workstation, so I can move is out of the way if I need to install something in the hull. As you can see I don't use a building board to hold the hull as I work mostly seated. The board is also used for my sanding block and today I added a small edge to is so it works as a shooting bord now. I had to adapt the sanding block so it will ride along the edge. A good sanding station helps to make perfect joints ( and sharp chisels....). Remco
  18. My two cents in the "should I buy the kit" discusion With the knowledge I have now of the 'kit' I would not buy it again. Apart from the hefty price tag it's more of a scratch build starter package than a kit. And although all the parts are precut, Mr Hunt had no good control of his CNC router leaving ugly dents in every part. Cleaning up is tedious and will harm the overall shape of the parts. I stopped using them a long time ago.... Building the kit is just as complex as making it from scratch, so if I could go back in time I would: Get the Swan plans from admiraltymodels.com Get the Swan framing package from hobbymillusa.com Get TFFM Vol I, II and III from seawatchbooks.com, well I got them as you need the books even if you have the 'kit' as the practicum won't take you all the way. (ps just a happy customer from the above company's nothing more) Buy yourself a good scroll saw and table saw, you can easily squeeze this into the budget of the kit price you've just saved from spending. And it's a good investment for future projects. Take a plunge into the wonderful world of scratch building, it's not as difficult as I had imagined especially with all the help and knowledge here on MSW you can tap in to. And one other thing, if you mess up a kit part like the hawse timbers ( it took me more than one attempt ) you're in trouble. But if you make your own parts you just cut a new set and try again..... Now lets get back on topic Thank you Martin for your kind words. Current state of the lower deck. Progress is slow bud steady. Remco
  19. Wonderful Karl. The pictures taken at deck level look like there taken on a on full scale model..... Remco
  20. John, I followed your build silently. She turned out beautifully, congratulations on finishing such a fine model Remco
  21. Piet, have you considered turning the torpedo tubes from a nice piece of hardwood? Remco
  22. Thanks. I temporary turned my attention to make the aft hatch and grating. Making gratings was one of the things I've been looking forward to making. I finally got around to set up my table saw to make the notched battens, it was actually less difficult than I had imagined. In the end I didn't use the special sled I had made, but just a regular cross sled with a small batten off set from the blade to make repeated cuts. I had to adapt the coamings to let the bitt pins pass. A big batch of notched battens were made so I only need to do this once and have good supply to make all the gratings. The nails are simulated with a graphite tipped needle, just like I did on the mast tops. Remco
  23. To bad you need to redo the hatches. I know the felling when you realize you had to think ahead even more steps ahead.. Maybe Evergreen plastic strips? Remco
  24. Thanks for the warm welcome back guys! Really appreciated. I made the carlings and ledges around the mast partner. As two of the carlings are half lapped under the beams and the mast partner itself is let down 1" on the beam this makes for some interesting cutting and fitting.... The mast wedges will be simulated by scoring the ring with a graphite dipped scalpel blade (actually it's already done but this other ring is fitted to the mast) Remco
