Everything posted by Remcohe
To bad you need to redo the hatches. I know the felling when you realize you had to think ahead even more steps ahead.. Maybe Evergreen plastic strips? Remco
Thanks for the warm welcome back guys! Really appreciated. I made the carlings and ledges around the mast partner. As two of the carlings are half lapped under the beams and the mast partner itself is let down 1" on the beam this makes for some interesting cutting and fitting.... The mast wedges will be simulated by scoring the ring with a graphite dipped scalpel blade (actually it's already done but this other ring is fitted to the mast) Remco
- 1,215 replies
- sloop
- kingfisher
I really like how the hatches for the dingy compartment turned out. Nice touch to an already very nice build. Remco
I got fed up with the plastic kit and it served it's purpose, I back working on my KF. Shaping the parts at the bow is a little tricky but fun especially with the scarph joints and the mast partner that has it's carlings cut from the onder side of the beam. Partially fixed partially test fitted here's the progress to date. Having the fore mast finished already helps to align all parts. Nils, thank you. Indeed the frame work is close to the real thing but not completely. I did not make the chokes as separate parts but they are part of the frame timbers. Remco
- 1,215 replies
- sloop
- kingfisher
For those looking for an alternative. You can get rivets as decals. http://www.archertransfers.com/SurfaceDetailsMain.html I used to use this and there pretty cool. Saves a ton of work and the results are very realistic. Remco
What about Minwax Wipe-on poly, it's water thin, it will penetrate the paper and any surplus can be wiped off keeping the crisp lines of the butt joints in tact. Remco
I added some pics from my sculpting adventure. Pics of the plastic kit will come in due time Remco
- 1,215 replies
- sloop
- kingfisher
Take a guess Jan ;-) I'll try to sneak in some pics somehow withour breaking the forum rules..
- 1,215 replies
- sloop
- kingfisher
Thank you Karl, you're very kind. Jan, 2 modern desert vessels a buffalo mpcv and a m-atv mrap
- 1,215 replies
- sloop
- kingfisher
Thanks Nils, Greg. Oktay, I use Castello Boxwood, aka lemonwood for 95% of the build the rest is Swiss pear and Holy. Sam, I take that as a big compliment. Jan is right, I'm a perfectionist looking for the limits of what can be done with the materials I use. This sometimes results in redoing parts most of us would find just perfect (and they are right). For the moment no updates, life is getting in the way and the time I do get to spend in the workshop is devoted to a plastic kit I bought recently and some figure sculpting and painting. Sorry guys, Kingfisher will have to wait Remco
- 1,215 replies
- sloop
- kingfisher
That is some fine joinery you are showing us here Sir, remarkable how perfect those parts fit. Remco
Thanks guys. Urb, I've send you a pm. Here's the whole assembly with the crosspiece and I decided to make the short version of the cleat (this is the piece that supports the upped deck beam) Still need to add some ironwork, not sure if I'll add the hook on the inside or the outside. TFFM shows two options (V1 p 276 and p80 V2) Remco
- 1,215 replies
- sloop
- kingfisher
Thank you for the compliments and the importand tip. I'm going to plank the lowerdeck but just a few bands, I'll make sure the bitt pin stays clear. Allthough I build the complete assembly now, getting it installed at a much later point will keep it from harms way while doing the rest of the decks. I'll post some pictures of the complete riding bitt this weekend. Remco
- 1,215 replies
- sloop
- kingfisher
Ed, I had the same issue until now, you'll definitely like it. I use this one: http://www.gesswein.com/p-10767-busch-burs-twin-cut-cup-fig-411t.aspx Remco
- 1,215 replies
- sloop
- kingfisher
Thanks guys, but who said I only have 2? The 3rd section of the platform needed more detailing, now I can move on to adding detail to the riding bitt's. Remco
- 1,215 replies
- sloop
- kingfisher
Trying is the right word, and then comes hoping you've got it all in the right spot. Glad this was an easy fix, further down it would have been impossible... Ed I now use a cup burr that works even better Here the third platform is partially complete and the riding bitt's are test fitted, hard to see but they taper quite dramatically towards the bottom of the hull. This is one of those jobs where I would like to have 6 extra hands ;-) Remco
- 1,215 replies
- sloop
- kingfisher
Thanks Scott, John. I had to rebuild the forward small platform as the deck pillar didn't line up with the deckbeam above. More deck pillars and stancions added, a small portion of the bulkhead is made too. The upper breast hook was made using card templates and trimmed further until a snug fit was obtained. Remco
- 1,215 replies
- sloop
- kingfisher
Thanks so much guys. The second part of the fore platform is taking shape. The planking is treenailed, the scarph joint is simulated Remco ps Piet it's not on the drawing table yet....
- 1,215 replies
- sloop
- kingfisher
I finally found my way back to my workshop. Real life, other projects and a bit of modelers block got in the way. I finished beam 11 with the hanging knees and now I moved to the bow section to built the fore platform. The footwalling already has it's final finish so the bare wood looks light in contrast. Two more platforms coming up... Remco ps Ben, nope I'm not a brain surgeon, nor something alike ;-)
- 1,215 replies
- sloop
- kingfisher
Congratulations Karl on finishing part 2 she's awesome! I enjoyed watching you build her. Remco
- 662 replies
- bonhomme richard
- frigate
Oh my, you really have been a busy beaver. It's great to see the hull taking her shape. At first I didn't understand why the bow is so much higher, but when I checked the drawings I understood, the deck structure needs to be build up on top of the hull. Are you going to show some details below the deck too? Remco
