Everything posted by Remcohe
Thank you Karl. Thanks Mark, it's just a line for positioning. I have to make a special cleat and rope to attach the blocks to the tops. You'll see. Mark II, here's the how to. I used this link to understand how it works: http://www.animatedknots.com/spliceshort/index.php?Categ=splicing&LogoImage=LogoGrog.jpg&Website=www.animatedknots.com First the length I need is laid out and tied off at both ends. The tips of the ropes are dipped in CA to prevent from unraveling The ends are brought together and tied again Then the lines are spliced using a needle, it took some time to understand how this works as its quite confusing I opened the eye of the needle so I can insert the rope easily The finished splice The loop is glued to the block And then seized at both ends The result Remco
- 1,215 replies
- sloop
- kingfisher
Thanks all. So the metal work is blackened and installed and it's time to do some rope work. Believe it or not it took me one whole evening to understand the text in TFFM how the block should be stropped and how the rope needed to be spliced. But I got it and spliced the rope properly tying the individual ropes with small fly tying rope to prevent them to unravel. This worked better than a spot of glue as the glue wears of pretty quickly once you start splicing the rope. The blocks are BIG compared to the mast. Nothing refined about it just hardware made to do a job. Remco
- 1,215 replies
- sloop
- kingfisher
Thanks guys. Progress is a little slow, making the blocks hasn't got me over the block yet.. I'm not mass producing the blocks other than the method described in TFFM vol 4. I've seen how Chuck does it, clever but whenever possible I like to avoid powered tools. Cutting by hand is more satisfying and I'm not on any deadline to get things finished. And doing a repetitive task helps to clear my mind, that's what the hobby is for. That said I had to turn the shaves on my lathe I found making bigger blocks harder than the small ones, getting them the same shape and size was necessary as it really shows. Remco ps Pat, you can always come over and scavenge my scrapbox
- 1,215 replies
- sloop
- kingfisher
Are you looking for this type: Like Mark said it has a toothpick on the other side to hold it. Remco
Thanks guys for you tremendously kind words. So last week I had a bit of modelers block, don't know where it comes from but happens once in a while. Drove the admiral crazy..... Finally I got over it by cleaning up the shop, and got back to work. I'm in the progress of making the Jeer tye blocks, these are massive 20" blocks. For a split second I thought of carving the shaves just like the smaller blocks, but having seen Michael Mott's blocks I just couldn't leave it like that. Advise on the size of the axle for the shave is much appreciated Bigger isn't easier, getting the shapes uniform is a real headache.... Remco
- 1,215 replies
- sloop
- kingfisher
With a chisel or better a miniature plane with the stock held in a jig. Is the stock you use round or square? Remco
What a sweet little block, without the finger in the picture it looks full sized. Remco
- 2,215 replies
Hi Anja, It works fine on my Mac and iPad. But what might be confusing is if a picture doesn't fit on the page it's moved to the next page but the box around it is showed on the previous page, suggesting a blank picture. So the third big picture in part one is on page 7. Okay, here's three little mast, the foremast is complete, I just need to blacken the bolts. And for the mizzen mast there is a span to be fitted, but I'm struggling the get a 2" rope served properly, still need to work on my skills there... Remco
- 1,215 replies
- sloop
- kingfisher
Thanks guys. Mark, you are too kind So I have a bit of bad news. So Dave (Midnight) saved my log previous to MSW’s move from 1.0 to 2.0. He was ever so kind to share these files with me to rebuild my buildlog. Unfortunately I’m not able to convert the PDF’s back to text to get them back into my buidlog. So instead of typing the lot over again I decided to put the PDF’s on a public share where every body who’s interested can download them from. To make live a little easier I compiled a small index so you now what to expect in each PDF. All the PDF's can be found here. I know it's a bit of a disappointment not to be able to put the information back into this log but the good news is nothing is lost. Any comments of how its working are welcome. And now it's time to make some sawdust!! Remco
- 1,215 replies
- sloop
- kingfisher
Thanks Dave I got all the files in good order 58 Mb of pdf content to process.. Daniel, I use the Byrnes drawplate and use boxwood from Hobbymill cut to 0,8 x 0,8 mm strips. Its a matter of gently pulling the strips through the plate. Unfortunately I didn't take pictures of the process. If I remember right I flattened brass rod, cut and filed the pieces into shape and silver soldered them. By the looks there are 3 pieces, the bolts are simulated by drilling small holes. Remco
- 1,215 replies
- sloop
- kingfisher
Thanks for the kind words folks. Well the topmast is supposed to slide in from underneath, so if I make it the right size it will fit like its supposed to. The Swan's topmast is octagonal at the bottom and round from there on to the top Only time will tell Remco
- 1,215 replies
- sloop
- kingfisher
Thanks all for your kind words! It was fun for me too to go through all the pictures and make a summary of what has been going on over the past years. Brought back a lot of memories. There is more but I didn't want to make it too long. Dave (Midnight) has a backup of my log and Dave and Danny are sorting things out to get it in a format easier to repost. So hang on and at some point the text will be back too. Greg, if I'm going to add the items (I'm not sure yet) it will be when the fore platform is ready. I think the sequence will be finishing the main mast partner , switching to the fore platform. And then adding the ballast. I need to figure out a way get them secured permanently. There will be lots of handling of the hull for time to come and I don't want to have pieces flying around. I think it's wise not to use the gravel. So now I'll reconstruct my last post on the old log and than move forward. It was a little how to make copper bolts, I use them extensively First the end is rounded off with a cup burr The bolt is cut The cutting leaves a little burr on the edge that needs to be removed, other wise I'm having a hard time inserting the bolt in the hole (my drills are 0,5 mm and the rod something like 0,47 mm so the burr gets in the way). Rolling a steel ruler over it does the trick. Next up is making a thin burr half way down the bolt. This will keep it in place so I don't have t use glue to fix the bolt. The blade is rolled diagonally with light pressure over the bolt. Now the bolt is ready to be installed, I use a home made pushpin with a small hole in the tip so the dome of the bolt will protrude. Blackening is done with liver of sulphur once installed. I make them in small batches so it doesn't become to tedious. I don't dare to make an estimate of how many bolts will be used in this ship. And here's the current state of the foremast, holes can be drilled in the cheeks for the bolts.
- 1,215 replies
- sloop
- kingfisher
When reading all the executive summaries and management summaries it just dawned on my how fast time flies by. She really is impressive Grant. Remco
Michael, the deck planking and caulking turned out really beautiful. Remco
- 2,215 replies
To bad your log was lost, but this still will be a great model, that will never change. I can imagine she was fast, she's got a whole lot of sq ft sail Remco
Thanks Ryland, Håkan, Carl, Sherry. Danny I hope he does, I sure do..... Remco
- 1,215 replies
- sloop
- kingfisher
