Everything posted by michael mott
Pandora by marsalv - FINISHED - 1:52
michael mott replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Congratulations Marsalv, a beautiful model and a well deserved medal. Michael -
Bob Thank you for your explanation of the AYC it clarified a question that has been on my mind for some time. The model of Skipjack that I am building which was one of the launches built for Andrew Mellon in 1909 was planked in "Yellow Cyprus" now that mystery is solved. I shall have to check for some local AYC suppliers. Michael
Toolmaking can be very addictive Mike! be careful or you will find yourself getting sucked right down the rabbit hole. Beautiful clamps by the way. Michael
- 969 replies
- hahn
- oliver cromwell
Hello Mark, The cabin cruiser on the lower level is this one I was warned about not starting another project until I had finished some that are still being worked on. But you know how that works 😀 Michael
- 2,215 replies
Thank you all for the wonderful support. Today I finished the pivoting cradle supports for the bow, it seemed like a lot of time to just make a few studs, bolts, and the pads. I used a thinner foam pad for the bow pads I just need to add a couple of chocks each side of the keel now to lock it in place from moving side to side. Michael PS it is snowing again!!!
- 2,215 replies
Well now I have a bit more room Kingfisher is back to center stage at last. Today I will finish off the bolts in the proper cradle, I had to lower the topmast because the long table that Albertic was occupying is about 5 inches higher, but that is OK for the moment. And I fixed my chiming mantle clock, I had missed it's sweet sound. Michael
- 2,215 replies
The journey for me is now over on this project, here is my last few pictures. In the crate now and cleated down ready for the final close. All ready to be picked up by the client. The shop seemed a bit lost for a few hours. The end Michael
- 749 replies
- albertic
- ocean liner
Thanks for putting the penny into the last set of pictures Ed, it is so easy to forget how small all this yard work is especially given all the very fine details that you show. Michael
- 3,618 replies
- young america
- clipper
A small update, I have started to reinforce the opening in the deck for the new removable companionway and skylight section. and while waiting for the glue to dry I made a few more studs for the cradle structure these are 2x56 threads and steel nuts with brass studs. Michael
- 2,215 replies
I will be following along as well Dan. Michael
- 238 replies
- leviathan
- troop ship
Thanks to all who have helped me with questions that I had during this restoration, and for the support and encouragement along the way. Denis I have built the crate and am waiting for the movers. Michael
- 749 replies
- albertic
- ocean liner
Today the clients made their inspection, the Appraiser who came along with them informed them that they got a steal so the next task is to move the model to the crate, after the company that is temporarily housing the clients artifacts sees the model before they take it to their storage facility awaiting its final display. I am really looking forward to gaining the space in the model shop. so that Kingfisher the pilot cutter can take centre stage again. I have been busy preparing the garage ready to house Maria while that rebuild happens. Michael
- 749 replies
- albertic
- ocean liner
Congratulation Dan, I concur that the dark colour of the base works better than the light colour. A superb model and display case all round. Michael
- 287 replies
- michelangelo
- ocean liner
Oh Brian you have outed me, I have known this all along and the personal name for this cutter in all my files is Kingfisher The Model Maker plans also call this boat Kingfisher There are a few other pictures of CK482 which I have in my files but I am unable to share them because I do not have the source. There is another model on this forum with this name so I did not want to put up this name, also I only used the basic bulkhead lines from the MM plans and then developed my own, and drew upon the general fleet for other details. I have copies of the Stone plans that are available for download on the "smackdock" here is another one that would make a great model it is called "pioneer" and another one from the register "Maria" I really like these boats. I am glad that there is a resurgence in restoring and preserving these vessels. Michael
- 2,215 replies
Back to the build. Thanks for all the fine comments. I have done a little more work on the companionway adding the slide track and rough fitted the solid roof section. Once the companionway is basically assembled, only three more dorade vents to form. The next step will be to cut the openings in the removable deck section then it will be ready for the structure and decking. Michael
- 2,215 replies
GL This looks like a very interesting project, I shall be sitting alongside all the way. Michael
- 219 replies
- smack
- cross-section
Thank you all for your support and counsel while I undertook this restoration. Your collective encouragement and valuable comments helped immeasurably. I am now looking forward to the final inspection by the client and then it can leave the modelshop freeing up valuable space for the next occupant of the workbench. I am going to enjoy having the extra room to work on the cutter over the next little while. Michael
- 749 replies
- albertic
- ocean liner
