Everything posted by JeffT
Welcome to the forum
Hi Shane. Welcome to MSW
Welcome to MSW!
Hello Bob. Welcome to the forum!
Welcome to the forums
Bonjour Mic. Welcome to the forum.
Error code 200
JeffT replied to Blue Ensign's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
I had the same issue last night. -
I've got most of the stem, stern and keel done now. This was pretty challenging since there were a lot of parts involved. One thing I need to get better at is sanding the edges of the parts cleanly. I seem to end up with a crowned edge or an edge with more off one side than the other. I'm going to have to come up with a way to make sure I get a nice clean edge, especially on surfacers that are glued together. I ended up having to fill a few gaps. I'm sanding manually so that's part of the problem. The laser cut parts have quite a bit of laser burn which is also ridged so its tough. Anyway here are some pics of my current progress. This is the upper part of the stem not glued yet. Its hard to tell from the picture but these are all built up from 3 layers. This is to accommodate the option to split the hull. I'm not building that option so will have these seams visible. Some parts of the stem assembled And done. The part you see sitting there is positioned approximately where its to be glued but I'm not 100% sure exactly of the position, so its not glued yet. There are steps that go here also for the forward frames but again not sure of the exact position so I haven't glued them on. Something I'm going to have to figure out. Something tells me the position of these parts is critical. You can also see there is a lot of color variation in the parts. The parts of the stem after removal from the sheet. These are CNC cut (all but one part) and there's some cleanup to do. After cleanup The overall
Check out our sponsors on the main forum page.
New Member Rock Harris: An Introduction
JeffT replied to rock harris's topic in New member Introductions
Hi Rock. Welcome to the forum. -
Welcome to MSW 🙂
Welcome to MSW Dan.
HMS Granado 1742 Kit - CAF Model - 1:48 Scale
JeffT replied to cafmodel's topic in Wood ship model kits
Good to see its free of the cradle. Looks very nice! -
Very nice Tom. I hope mine will look that good. -
Hi Rico. Welcome to MSW
Looks easy to remove.
I probably would have had a lot of drinks after that
- 505 replies
- vanguard models
- Sphinx
Thats pretty cool. I guess you just use a hand drill to operate it?
Hi Greg. Welcome to MSW.
Thanks sticker and roger. I do appreciate your input.
Thanks Bob. I haven't seen that one before. That mill does look very interesting. I'll taker a closer look at that.
I do the same. The CA acts a clamp when used in conjunction with Titebond.
- 217 replies
- medway longboat
- Syren Ship Model Company
