JeffT
Everything posted by JeffT
  1. Looking good. How do you like the admiralty paint. It looks like it brushes very well.
  2. Welcome to MSW. I agree with Mark. Try cutting a new one.
  3. You might be able to get it from Ebay if you are having trouble finding one.
  4. Thanks Geoff. I ended up cutting one out as well. I finished one last night and will work the other tonight.
  5. Thanks Rusty. I'm going to try that first. If it all goes south, I'll try cutting it out by hand as Bob mentioned.
  6. I think that's what I'm leaning toward Lou. Thanks for the input.
  7. Its been a while since I've updated this log, a lot longer than I thought actually. I'm sorry to those that have been sitting on the edge of your seats waiting...lol. Anyway, I've been focusing most of my effort on the Constitution (which I will continue to do) trying to get all the hull details done so the longboat has been a little neglected. Thats one reason. The other reason is that I've completed 3 rows and realized as I started the 4th row that I need to cut a new plank, probably for both sides. Plank 7 to be specific. That makes me a bit nervous so I've been a little hesitant. After thinking for a while I think that I will trace the original plank and then correct the edge that makes contact with the previous row. I'll just need to work out how best to do that. Cutting it out is something else to think on. My first instinct is to try using the scroll saw but I'm concerned about the thin material. I may need to order some additional material just in case this takes more tries than I have excess material for, we'll see. Thanks for looking. Here's a couple pics of the progress so far. As previously mentioned, I'm tree nailing as I plank. I haven't done any sanding yet though so the high spots are visible.
  8. I completed the aft top gallant rails. After fabricating the transom piece it was pretty straight forward. I sealed everything with wipe-on ploy and painted black. I first attempted to brush paint tamiya flat black from the bottle but that looked terrible, so I had to sand it back down with some 0000 steel wool. I ended up using a rattle can of tamiya matte black. Floquil was so nice to brush. I think I need to find another paint for brushing. Next its on to the front rails. I'll need to do a little touch up at the joints. The front rails are a little tricker since there is a bit of a curve. I'm debating on whether I want to try and edge bend a plank or just cut one to shape. 🤔
  9. I went with the copper plates on my constitution. It looks much better in my opinion.
  10. Hello and welcome
  11. Welcome to MSW
  12. Welcome to MSW
  13. Thats pretty significant. Does it line up without the planking?
  14. So I've managed to complete the remaining two fife rails. I was able to make use of the kit supplied rails with no drama this time. I've now pressed on to the top gallant rail. Mid Aft. One note here: The plans failed to account for the 1/32 plank doubler at this location showing all the bitts at the same length. The two outside bitts need to be 1/32 longer. I ran into a problem with the kit supplied top gallant rail transom piece. The curve didn't match the curve of my transom. So, I had to make a new piece. I drew it out on a piece of 1/16 basswood sheet and cut it out on my scroll saw. I'm pretty happy with the result. I'm starting to gain some confidence with the scroll saw, which is good, because I'm going to need to use it to cut out some new planks for my Medway Longboat, but thats another story. My cuts weren't perfect but I tried to stay about 1/64" outside the line. I just sanded the edges to finish to the line. The piece on the left is my new rail and the one on the right is the kit supplied part. Its not too obvious in the picture but the curve of the kit part is a little more drastic and is a bit to narrow to fit my transom. Here is the piece on the transom. I reduced the width a bit after seeing this picture. I'll give it a coat of wipe-on poly and paint it black before gluing to the model.
  15. Hello and welcome to MSW
  16. Hello John. Welcome to MSW
  17. Welcome to MSW Juan
