JeffT
Everything posted by JeffT
  1. Welcome to MSW
  2. Welcome to MSW
  3. Welcome to MSW
  4. Thanks Chuck. This is a fun project and I'm feeling good about being in the workshop again.
  5. Hi all. Just a quick update and a question. I've built all the frames and dry fit everything together. I put the packing tape on the frames for support also. You may notice that I haven't attached the transom yet. I'm going to glue it on while everything is dry fit together on the build board. I thought it would be easier to get it properly aligned and perpendicular to the hull. My question is on the small strip of wood at the top of the frames. Is this added to all frames?
  6. Hi Mike, Welcome to MSW
  7. Vallejo has one. You can get it from amazon.
  8. Welcome to MSW ☺️
  9. Alright, finally got the keel finished. I just pretty much followed along with the instructions. I installed the simulated bolts and sanded off the laser char. After that, I ended up gluing the two inner keel pieces together first and then glued them to the keel. I made sure I had a nice flat surface and aligned the bottom edges along a angle block. It worked out nice. No adjustments were needed for the inner keel pieces, everything fit perfectly, no wiggle room on either end. I used the little 1/32 jigs as seen in other build logs to make sure I had the 1/32 rabbet. I gave it a coat of wipe-on poly and on to the next step.
  10. Welcome to MSW
  11. I like the unpainted bulkhead too, gives it some nice contrast.
  12. The ship is coming to life! Pun intended. Its looking very good.
  13. Question on adding the the two notched inner stern keel pieces: Is it best to glue the two pieces together first before gluing them to the keel?
