JeffT
Everything posted by JeffT
  1. Welcome to MSW
  2. Hello everyone. I finally got over my fear of causing major damage and got the keel assembled. I used a caliper to measure the thickness of the keel and divided by two to hit the halfway mark. After much practicing on scrap pieces I used the byrnes saw to reduce the thickness to slightly above the halfway measurement. You have to go very slow using the saw or it will cause splintering of the wood. I wasn't able to remove all the material with the byrnes saw since we're not dealing with perfect 90 degree angles so I had to remove some material by hand. I got as close as I could to the edges and then used a number 10 curved exacto blade for chiseling away material. I'm not comfortable using the number 11 blades because I can't seem to control them as well. I did the final sanding with emery boards. I also assembled the other keel option just for the fun of it. Both keels are exactly the same length when assembled so I must have done something right. I'll go ahead and pat myself on the back and move on to removing some char and add the bolts. I also test fitted the inner parts and they fit nearly perfectly. Here is the result:
  3. Welcome to MSW Steve
  4. Try making a wood filler with the the extra cedar. Just sand the cedar until you have a nice pile of sanding dust and add white glue, just enough to hold it together. Use it to fill the gaps. make sure you are on a clean surface and use clean sandpaper or a clean file to prevent discoloring the filler. Or what Chuck said
  5. Welcome to MSW
  6. I don't know how I missed this post but I'm happy I found it. Its very interesting to see that Chuck is using very basic tools for the planking. All this time I've been trying to understand what the secret to a perfect planking job is and there isn't one. I've really been overthinking this big time. Basic tools and pre-planning is all that's needed. I dislike soaking planks so I can stop doing that too. I'll have to get my own hair dryer though, my wife won't appreciate me using hers. And now I know what Chuck looks like I think I was expecting him to be in a 3-piece suit though.
  7. Hi Tom. Welcome to MSW
  8. Thanks for all the suggestions and supporting comments, I do appreciate it. They are all good methods. I checked out the current build logs and saw some great ideas there like the digital caliper measurement. I did purchase a sherline mill but have no clue how to use it yet. I am considering that as an option. I also have the byrnes saw so I need to take a look at the huzzywuchet. I think the key to using the mill and the saw (and any other method) would be patience and practice before attacking the actual piece.
  9. So on with the build. This is Plan A and Plan B. Plan A is to use the lap joint parts. Unfortunately, this is the one thing I struggle with the most; final shaping or removing material from parts without causing serious problems like rounded edges, rounded surfaces, changing the shape, etc... Its the one reason I haven't been able to do a scratch build. So I need to figure out what method to use and take my sweet time doing it. If all else fails, Plan B is the other parts provided. On another note, I like that the tabs holding the parts on are nice and small. Its very easy to remove the parts and clean up the tab remnants. Seems like most kits have a giant chunk of wood in multiple places holding the parts on.
  10. Hi Bill, welcome to MSW
  11. Hello and welcome to MSW
  12. I received my kit yesterday and allowed the wood to acclimate to my extra dry environment. Here are some pictures of the kit contents. There is a lot more wood than I expected. I do like the look of the Alaskan yellow cedar. It has a nice grain to it.
  13. Hi Adrie. Welcome to MSW.
  14. Welcome to MSW Pete
