JeffT
Everything posted by JeffT
  1. You should be able to get the dremel collets from amazon. The small one that came with my dremel works well for small bits. I'm not sure about the size though, maybe a 1/32?
  2. The portholes on the MS version are pretty much the same. Its just a cast metal porthole inserted into an opening drilled in the hull.
  3. Thanks Rich. I just followed the the plans for the kit which shows the configuration I did. The kits plans are based on the way the ship looks now so I assume the actual ship will have the same configuration. Anatomy of a Ship shows 4 per side also but in a different configuration.
  4. I use a dremel 3000 variable speed and a flex shaft. No issues to report.
  5. Welcome to MSW. Your model looks very good. I had totally forgotten that Model Shipways manufactured Vanguard kits for a short time until I saw your post.
  6. Good luck with the build Martijn, I know you will enjoy it.
  7. I pulled the trigger on this setup, I decided to get the double action and learn to use it. http://www.tcpglobal.com/itemdetail.aspx?ItemNo=ABD+KIT-4247-IS925
  8. I have one. Works great.
  9. I have no doubt that take 2 will be a success.
  10. I too am thinking of buying an airbrush. One of the options I'm looking at is the Iwata eclipse.
  11. check out model expos confederacy. its impressive
  12. www.agesofsail.com is another option
  13. It happens to be where I keep my sharp stuff stored.
  14. I bought an 8 drawer wood chest from harbor freight that locks.
