Posts posted by AntonyUK
Hi Jack.
Wow your boat is truly a master piece.
If weren't for the wood grain on your table I would agree with Yves above post. Real nice workmanship.
Such a nice looking boat. With lots of character and style.
Regards Antony.
- Seventynet and mtaylor
- 2
Hi ?
Nice start to your build. I like the idea of the blocks and they will make the model more robust as well as keeping everything straight answer square.
The jig for the tree nailing is a good idea.
Regards Antony.
Hi David.
Nice work.
Like, like, like. Cuz the likes is broken.
Regards Antony
- Chuck Seiler and mtaylor
- 2
Hi Techsan.
Your workmanship is looking good from this side of the pond.
I agree with Chris's Above. Just clean it up and put in the stub masts and it's a nice little model.
Someone that is not ship literate would like it😀
Regards Antony.
- Techsan and CaptainSteve
- 2
Hi.
A nice build.
Shame on Constructo for supplying such rubbish components for a basic model.
Looks like you made a good job on the cannons.
Regards Antony.
Hi don.
A very impressive build.
Regards Antony.
Hi Mike.
Not easy to answer.
I think you are right about"My understanding is the opening should be framed twice. Once with with a 0,5 thick plank. Then a 1,5 thick plank. "on Zoran Web site there are colour photos of the build.http://www.marisstella.hr/gotovi_modeli_galery.php?id=126&tip=2
Some close up of the hatch entrance .
The 3 boards could be showing the side and the face of one board.
Why the 0.5 strip stops ...no idea might be a drafting error.
In the circle you have drawn... the 4mm is the width of the bulkhead. The 6mm is also looks like a board width.. 6mm X 0.5.. Again a drafting error (should show width of the 6mm X 0.5mm board.)
Not sure on the 0.5mm.
Don't know the kit so only guessing.
Regards Antony.
Hi Jeff.
Nice progress. Nice to see that you test fit everything that can be test fitted then removed for placement later on.
No advice from me..You are making a First class build 😀
Regards Antony.
Hi.
Look on eBay
BTW It would be a good idea to remove your email.
List of items in part Issue #84
1 x 300 x 4 x 2mm Ayous wood strip
1 x 300 x 6mm diameter Ayous wood rod
1 x 300 x 5mm diameter Ayous wood rod
1 x 300 x 8mm diameter Ayous wood rod
1 x Fairlead saddle, foremast top, bibs and trestle-trees (14 pieces)
1 x Printed plan for the foremastAll the best Antony.
Hi Martyn.
Hey Got my seat booked frount row.
I looked at this kit a short while ago. But I need to finish what I have in the queue first.
All the best with your build.
Regards Antony.
- BLACK VIKING and EJ_L
- 2
Hi Jeff.
Nice work on the on the removal of the bulkhead. ( The lesson here is to dry fit everything before applying any glue).
You could always cut machine cut some small blocks to fit between each bulkhead that clamps to the keel.(the blocks would need to be cut dead Square or it will make the keel curve even more).
Or cuting a grouve for the keel in plank of spare timber that is flat. You would also need to cut oversize grooves for each bulkheads.
Regards Antony.
Hi Andre.
That's a nice looking ship you have there.
Is that diagonal planking I see there ?.
Will follow along with this one.
Regards Antony.
- complexpack and EJ_L
- 2
H Jeff.
5 hours ago, Zarkon said:Every model is a challenge (especially when you "accidentally" make it more challenging for yourself) but i will persist and not let my bad first step get me down. I will fix it and move on!
It's the best way to learn by making errors and finding the fix.
Antony.
Hi Jeff.
Good advice from Dan above.
If the is not in the correct position then remove it and sand the slots until late you get a easy fit.
Removing the ash from the joints helps with the bonding.
Regards Antony.
HMS Victory by Zarkon - Constructo - Scale 1:94
Hi Jeff.
Looking good.
Taking your time and thinking things through is a really nice thing to do.
And thanks to Dan for recommending them pens. Got some myself and they work a treat with no bleeding.
Regards Antony.
