Trussben
Everything posted by Trussben
  1. Here are the 6 lower frame locator parts glued to the former, 3 on each side. They are laser etched with the bulkhead locations at the top and the individual frame identifiers, very simple to figure out. I glued with a mixture of PVA and CY.
  2. Only a couple more jig pieces to be installed, these MDF parts sit on top of the previous jigs and give more support to the bulkhead extensions at the level of the upper gundeck, they get screwed into the lower jigs to keep them securely in place. These MDF sections as you can see also contain all of the gunport framing parts.
  3. More stern jig pieces installed, these two will hold the Counter Timbers in the correct places whilst framing is done. Care must be taken as they are quite thin and fragile pieces and a very tight fit.
  4. I started installing the aft jig, this one is much more complex than the other two as it is the one that will align all of the stern framing.
  5. All of the bulkheads and stiffners have been glued to the former and themselves, this thing is now rock solid and a very sturdy platform for everything thats to come. I have begun installing all of the jigs that will support the upper parts until the model has been planked on the outside, these jigs are NOT to be glued to the model as they will be removed later for all the internal work, here you can see the forward one.
  6. I sure whatever you decide will look great Dusan, I’m not going to be adding any to my model as I’m really gonna try to stay contemporary and close to the paintings.
  7. Last bulkhead to be installed is for just forward of #1, it is for the beakhead support, it also has two verticals for the bow and it locks bulkheads 1/2/3 together for more stiffening. There should be a 1/16-1/32” gap between it and bulkhead #1. With all these parts now installed, the entire structure is very very stiff with almost zero movement anywhere and is now ready to start having glue applied to it, kudos to JJ for his design and laser cutting to make this as solid as it is.
  8. So the foremost bulkhead #1 requires that these two upright bow supports be glued into place before it is installed, making sure to make them perpendicular. Also the stiffners between aft bulkheads 24 & 25 need to be installed to tighten that section up.
  9. All of the bulkheads were removed from their sheets and dropped into position on the former, no adjustments were needed to any of them to make them fit! No glue has been used so far and you can see the longitudinal stiffeners being installed - fore sections first and then the aft ones, after these clipped into place with a little persuasion the entire structure has really begun to get more solid. More bulkhead and stiffner work to come before glue goes anywhere near it.
  10. Hi Greg Yes, the knee parts are two sets of parts that get glued together to make a single thicker Knee, you have to deal with the char because of the kerf that the laser creates on the parts, so very careful sanding and fitting is needed to create tight joints on the outer surfaces.
  11. Final progress from this weekends work, the sanding of the Knee to its correct dimensions and then its installation onto the former along with the keel and false keel pieces. Now she is on the build board ready to start testing the fitment of the bulkheads.
  12. Hi yes, as usual on my models I use a 2B soft pencil on both edges, I don’t personally like it when it’s too stand out.
  13. I glued together the eight included bulkhead former uprights ready for the build board and then glued the “rabbit” strip to the former as well. Now to work on the Knee!
  14. A little more progress, the two pieces of Swiss pear to represent the fake “rising wood” being glued into position, the quality of this Pearwood is really really nice.
  15. Some spacers were needed to centralize the last piece of the bulkhead former in position and then it was glued up.
  16. The build has officially begun, the MDF former made of 3 pieces glued together on a nice flat surface and left overnight to dry fully.
