historyguysteve
Posts posted by historyguysteve
Tom
Wow am I ever glad I peeked into this build! I have both the HMS Victory and the Soliel Royale. I had NO idea that supplemental instruction brochures were even produced! I JUST ordered them both directly from the publisher in France - the Vic is now down to one copy and the SR is ummmm sold out- I got the last one. Whew!
Tom; Great job on the ship thus far, keep up the great work. A piece of advice if I may. When it is time for masts and spars substitute actual wood for all of the plastic stuff. 1) by the time you clean up all of the mold lines and paint an prep the plastic stuff you could have constructed wood yards masts and spars. 2)the parts you replace with wood will automatically appear more authentic, very satisfying I assure you. 3) last and most important. The wood is MUCH more robust; stronger, more resilient to getting knocked around during construction. The plastic will break easily and deflect as you add rigging. Oak dowels are easily available at any home center and in a wide variety of diameters, no need for a lathe. If you can use a cheap set of calipers, read a ruler and use sandpaper you are in business.
I only tell you this because I just moved and now the t'gallant main on the completed Thermopylae is broken without hope. All of those stays, lifts and braces have to be re rigged. AARRRRGG! Save yourself the aggravation. I put wood spars on Sea Witch, USS United States (44), Young America and others and I urge you to consider the 'upgrade'.
Thanks Steve
WOW, I have NO idea what Trumpeter was thinking of with that bowsprit. NO WAY was the bowsprit angled so far from centerline. The Anderson book is pretty correct, follow those guidelines. It seems to me that you have choices, all requiring some scratch-building. Since Trumpeter saw fit to put an access hatch on the centerline, you may be required to place the stump end of the bowsprit slightly to port but still pointed directly forward. Alternatively you could position the extreme stump end of the bowsprit just in front of the hatch (which appears to be spurious under any circumstances) and angle the bowsprit up considerably. The idea is to make the bowsprit appear to pierce the forward bulkhead of the forecastle and terminate near the step of the lower foremast. That would solve a LOT of problems and be historically accurate and be fairly simple given that you must scratch-build under any circumstances.
How you will solve gammoning is a real puzzle. Gammoning is a rigging requirement. You MUST lash the stump of the bowsprit to the beakhead through the grating. It appears that you will have to remove some of the grating on this model to properly apply the gammoning. Also you must put an elongated slot into the beakhead; the gammoning will wrap around the bowsprit, go through the slot in the beakhead multiple times and be gathered in the center by more rope winding-check your resources.
Allow me to finish by saying what a great job you are doing here, I'm personally excited with this build. One of the real pleasures of this hobby is problem solving. Put yourself in the position of the sailors of the time (in this case the bosun and bosuns mates who were responsible for rigging) and consider what they are trying to accomplish with every stick and rope- sailors have a lot of common sense. You have nothing but friends and allies with VAST experience on this website. Have FUN!!!
Ah-HAAAHHH! This is the old 1/96 Sea Witch made by Lindbergh- I know because this exact model is on the shelf just about 3 feet away from me. I recognized her the minute I clapped eyes to her. She is well worth saving! You were not looking for advice , so..... I'll just give you some. The plastic upper masts and yards were EXTREMELY brittle when new. The model has been out of production for over 40 years. So, the masts and yard really cannot be salvaged- they will not respond properly to ANY glue; the plastic is chemically unstable and will not hold up. Use the yards/masts as templates for wooden ones. Appropriate doweling is easily available and really inexpensive. When you consider the amount of time and effort you will expend trying to retrieve the old sparring you could have easily replaced everything with a much more robust and interesting material - wood. You do not need a lathe- just some sanding paper, get some dowels at the local LOWES or Home depot or order the stuff on any number of sites found on this website. You will almost certainly have to replace the blocks and deadeyes as well - the Lindbergh ones were really well made and historically accurate but, as with the masts/yards, are so brittle and delicate they will not function. As for the rigging.... there is really no way around it - you will have to replace it as well. Of all the things that Model Shipways, Corel, Artesiana Latina or any of the modern makers - appropriate rigging material is the one thing most get right, order the stuff up and by the time the sparring is done the rigging material will have arrived.
Consider any tall ship model to be three models: the hull/deck furniture, the masting/sparring, and the rigging. You have one down and two to go.
I hope this helps.
history guy steve
Hi So far great job on this kit- I have this in my stash so I'm really happy to see a build log on this.
A piece of advice; use the plastic masts/yards as templates for wooden ones. Just replace the plastic with wood. The reason why (ask me how I know) the plastic is already 20-30 years old and will get really brittle and positively will fail and at the WORST possible time. 🤦♂️🤦♂️🤔Also consider this; by the time you reinforce the masts/spars, sand them to get rid of the seams and paint them and place them you could have used a dowel, shaped it and have a MUCH better outcome long term. Wooden masting and sparring will absolutely look light years better and will be soooooo much more resilient. I tell you plainly- replacing the masts/spars with wood is a win win- you will save time, the ship will look better, and it will last muuuuch longer.
thanks- just friendly advice based on experience😃😃😃
historyguysteve
WOW... You really are cooking along with this model. It is really great to see someone do a scientific kit. They are reasonably accurate, fairly simple, yet result in a good representation of the ship at hand are of a great display size. I have this exact kit in my 'stash' and I really pleased that your building it. You will need to figure out some solution to belaying pins and pin rails, Scientific does have some shortfalls mostly due to scale and simplicity. A good reference for better rigging will also be beneficial as their rigging plan is way oversimplified.Great job!!
steve
Hi
Here is a little tip on weathering the deck. You've got to use pastels. They are pretty inexpensive, just get a small set that has the browns/greys that you might use. Get some cheap make up brushes or even the little nylon/plastic brushes you see and reject at the hobby store. Scrape off some of the pastel into a pile, chop it up really fine and apply with a brush. It is possible to airbrush clear flat as a fixative but be sparing or you may warp the wood deck,(Hint: that would be bad). Colored pencils might work as well but I find it difficult to get them chopped up fine enough and you definitely don't want streaks especially at this scale.
Awesome job on the PE- what a difference that stuff makes!😍
- popeye the sailor, lmagna, mtaylor and 2 others
- 5
I agree with Grampa Phil above. You have a large model so some creativity is involved but heat up the hull in really hot water for some considerable time not less than 5 minutes or so. Have a piece of really flat, strong material and lots and lots of clamps and rubber bands ready. If possible clamp the hull to the flat surface first, then immerse. Another tip for the small parts. Put a small amount of superglue into the hole or on an edge of a part that has been broken off, right away tip on some baking powder. The mix will set up rapidly and become really hard- harder than the surrounding resin. Then sand to finish. For a larger area or to raise a damaged edge just repeat the process adding layer upon layer. It technique works really well and is structurally sound.
Have fun!!! looking forward to seeing the completed ship!
You didn't ask for my advice , so... I'll just give it to you 😇 😇Strongly consider replacing the masts and spars with wood. The plastic stuff will get brittle and therefore delicate over time. The LAST thing you want is the be very nearly finished and bust a topgallant or the jib boom! (ask me how I know) Actual wood is readily available and when you consider the prep time necessary to make the plastic spars look good (filling ejector marks, removing mold lines) you could have wood masts and spars that look really good, are more robust by far and provide a strong sense of accomplishment. Also consider replacing the rope with better quality and blocks with wood- Model shipways is one company among several that can provide wood blocks and deadeyes. The deck can also be planked- use super thin wood and gel super glue. This step will solve the problem of hiding the seperation lines of the 3 part deck. I tell you plainly; these simple upgrades are all out of proportion to the impact and appearance of the completed model. Also 'Fright' above recommended some reference materiel. I wholeheartedly concur. You don't want to get into the model, get hung up on some technical problem and be delayed for lack of readily available(and affordable) reference material. As you may imagine the super people on this site are also eager to help.
I think it is important to decide early on just how far down the 'resto-mod' pathway you will go. I feel the best ship model is the completed one. Case in point- there are build logs of the Wanderer whaling ship that shows extensive modifications but the build is proceeding, DAFI is redoing the HMS Victory (Heller) and I've been following it with avid fascination for years now - progress is SLOOOOOWWWW. It is a matter of compromise as in all things.
Ultimately HAVE FUN!😆😆😆
I'm must confess, I learned a lot on this build log. But.... if I was a-fishing and caught a fish that looked like this vessel..... I would quietly throw it back into the drink. And I would never discuss it with anyone.
I find it very surprising that the maker of the kit chose this subject- gutsy or foolish I cannot tell but evidently a well designed effort!!!
Great job on the model.
Steve
These Scientific models are really underrated. With a little time and effort, and with even modest modelling skill these kits can be turned into real masterworks. I have this exact kit, so I'm looking forward to seeing the build. Have Fun is my motto- the best ship model is the completed one!
Hi
Sorry i did not respond sooner
As EJ_L suggested above, pin rails are shelf structures that hold belaying pins so that the rigging aloft can be secured at deck level. Channels are OUTBOARD of the hull and provide a place for the shroud/ratline s to be secured.On Sea Witch you have to construct pin rail INBOARD of the hull roughly in the same place as the channels. At this scale (roughly 1/287) you can use actual sewing pins as belaying pins. The first pin hole should be roughly even with the leading edge of the mast. Simply place a ruler across the hull lined up to the hole indicating mast location, Fore and Main only the mizzen is a special case, place a reference mark on the inside of the hull. The pin rail should have about 12 pins evenly spaced (the real pin rail had about 23 belaying pins) The pins should be long enough to protrude below the pin rail but not so long as to go into the deck. As for the actual construction of the rails itself .... use your common sense- thick enough to be strongly secured to the hull thin enough to be realistic.
A very good very inexpensive reference is Charles G Davis (a famous model ship builder who actually captained sailing ships) Ship Models and How to Build Them. Sea Witch is on the cover and many of the references are to a ship contemporary of that era.
I hope this helps
Allow me to give you a small piece of advice based on experience. Start planning on pin rails. Scientific usually does not provide references or material for in board pin rails, and as it turns out YOU WILL NEED THEM. The best time to figure out where they go, how to make reasonably accurate pins and get it all installed is right about now in the build. What you want to avoid is getting all of the deck furniture in, some of the lower masts and realize you have exactly no place to tie off rigging.
just trying to help
thanks
Steve
I concur-the BEST model is the COMPLETED model; and with grampa too!! It don't GET no better than that!!!
cheeeeerrrs! may the wind always be at your back!
- Canute, modelshipwright and mtaylor
- 3
Looking forward to following you on this journey. These Scientific kits are waaaaayyy underrated. They are inexpensive, reasonably accurate (with even a little research and basic modelling skills they can be made very accurate indeed), and they are a great display size. Looking forward to seeing a completed ship model, which, as it turns out, is the best ship model.
steve
Hi Geoff
I'm looking in on the build. Great job!!! You are discussing the scale ropes- a serious issue on sailing ships. Look at Cottage Industry Models. They specialize in Civil War Ironclads. I was able to get my hands on the revenue cutter Alexander Hamilton (Samuel B Morris class revenue cutters, USCG.) At any rate they include enough of their handmade rope/cable to complete the model. That stuff is awesome, inexpensive and readily available. You are making your own now and the ropewalk looks cool, but if you get in a bind try the Cottage Industry stuff.
thanks
Steve
Hi Greg
I'm pulling up a seat and watching the build!
May I offer a quick suggestion. Go to youtube and view two tutorials. Your patience will be rewarded, they are from two of the best modellers I've ever seen and the tutorials are very professionally done. They are all in Japanese with no subtitles but that really makes no difference.
'Custom SP-16' --> a really outstanding tutorial on the IJN battle cruiser KONGO- juuuuuust take a look.
'Bandai Space Cruiser Yamato' again JUUUUST take a look, your patience will be richly rewarded.
These guys are super ninjas when it comes to detailing and solving problems that occur with the model kit and detract from important details. Even if you do not personally pick up any new tips the results these guys achieve is phenominal and inspirational.
thanks
Steve
- RGL, Elijah, Captain Slog and 4 others
- 7
hi Steve, Steve here
I'm impressed with the bowsprit and jib boom- excellent work scale in dimension and looks realistic. I knew you would appreciate the ease in replacing key mast, boom and spars with wood it is just so much better. By the way, to finish the wood you will want to use a bit of sanding sealer, otherwise the wood will simply soak up the paint and that may cause the wood grain to emerge.
great job, keep up the great work.
steve
WOW that clear deck is both gutsy and innovative- truly one-of-a-kind!! I say develop this idea until you are comfortable with it and go for it. Kudos for thinking out of the box. You will certainly be able to show off all of the work done on the gun deck.
thanks
steve
Welcome to the MSW Site- the single most awesome website for reference and support for what we do-. Keep up the great work- I am right in the middle of connies sister ship--- United States- same molds with a few changes.
Understanding the cost restraints allow me to make a suggestion that is inexpensive, solves A LOT of problems and looks great too.
Go to your favorite hobby shop- they are out there, in the US, Michaels or Hobby Lobby. Look for 1/32 or 1/64 sheet of plywood, either birch or sometimes walnut. The come in large enough sheets so that one sheet will be as long as the deck.
Glue up the decks but be prepared to do some surgery. Use the deck as a template to cut out a copy of the deck from the thin plywood. Cut out the major deck fitting, hatches and so forth out of the plywood. Keep adjusting and test fitting until the wood deck will fit over the plastic one- excersize you patience you will be rewarded. Once its all set use superglue to attach the wood deck to the plastic one--> USE THE THICK GEL TYPE SUPERGLUE!! The thin stuff will simply wick up into the wood and spoil everything. Clamp the crap out of and let it cure.
MANY problems will be solved- no need to paint (you can draw lines onto it using a sharp pencil or appropriate pen to represent planks)
No need to deal with the inevitable seams on the plastic deck, and it looks like wood because it is wood- you will be amazed.
Use a variation of the technique on the masts and spars- the old plastic is brittle and will deform and break at the WORST possible moment when you go to rig the girl, wood is MUCH stronger and will hold up to rigging.
I hope this helps
steve
Peter is correct, the plans are indicating 'gammoning' Also they are not chain, they should be tarred (black or very dark brown) rope.
Also another side note, you probably already know this, The Cutty Sark was composite build - some structural elements were wood others iron. I am almost certain that the bowsprit stump was iron, use the strongest stuff you can employ for the bowsprit and jib boom, you don't want a breakage at the last moment when all of the rigging is done and you're just about to put her on the display shelf, ask me how I know. :)
Great job - these scientific models are inexpensive, a great display size and fairly accurate, I'm surprised they are not more popular on MSW.
steve
Hi Steve, Stephen here great to see you back on the build
As it happens I am only about 5 feet away from my model, allow me to grab the calipers and we'll set to- if anyone wants to chime in with better dimensions do not hesitate.
From The HULL outwards to the jib boom cap(the tip of the boom)- the over all length is 8 1/4 inches( understanding that the jib boom foot is angled to match the knight head.)
At the hull end the boom is o.147 in. SQUARE- the square cross section moves forward 0.313 inches, goes through the aft chock (a figure 8 piece of iron that connects the aft part of the boom to the bowsprit stump. Then the cross section becomes ROUND for the rest of the length of the boom.
From there it is 2.290 inches further toward the cap end of the boom to the martingale ring. At the martingale the boom is .020 inches in diameter(just use the inside diameter of the martingale ring as a template).
Proceeding further to the boom cap-away from the hull, from the martingale ring 2.059 inches forward is the first sheave(a hole from above to below,through the boom that contains a pulley), this is for the inner topmast jib stay.
Next stop outward from the 1st sheave, 0.328 inches is a brace ring. There is an iron ring with eyebolts on either side(port and starboard) and below (NOT ABOVE ) for the guys and stays to attach; at this point the diameter of the jib boom is 0.175 inches.
Next farther outboard 0.801 inches is the second sheave for the outer topmast jib stay. (we're nearly there)
Next 1.621 inches farther toward the cap is a 3rd sheave for the inner t'gallant jib stay.
0.466 inches farther outboard is one last sheave for the outer t'gallant jib stay.
Now dont get lost - split the distance between the last two sheaves and there is an iron ring for the outer martingale stay(an iron ring with eyebolts like the the first one -on either side and below but not above the jib boom).
Whew, last measurement. The jib boom cap is outboard of the last sheave 0.195 inches and the boom has steadily tapered to 0.085 inches in diameter at the cap.
To construct it out of wood(highly recommended for this structure). Start with a dowel slightly larger in diameter than we need about 0.20 inches to account for the diagonal measurement of the square foot. Lay out all of the critical measurements for sheaves, rings etc. Drill the sheaves . Then slowly reduce the diameter from the foot to the martingale ring(roughly parallel, there is very little taper between the foot and the martingale ring). Taper to the cap. Construct the two eyebolt rings, splice the mainbrace (navy speak for drink your favorite cold beverage)
I urge anyone to top that.
hope this helps
steve
Holy Mackerel!! I just tuned in to your 'restoration"--> WOW!!!
On Antiques Roadshow they call all of that stuff 'patina'. I'm sorry to tell you shipmate- you just devalued the models by at least half.
GOOD LUCK WITH IT ALL
Under any circumstances you should enjoy a genuine sense of accomplishment when you're done!!!Steve
Hi
Just saw your post and checked it out. I agree with everyone else: build for your own pleasure. I completed this very model a few years ago and it impresses all of my family and everyone else who sees it. I improved the accuracy everywhere I could and honed my modelling skills. I learned a lot and solved problems to my own satisfaction. So.... enjoy.
thanks for the post!
Arrrrgggg
you beat me to the punch! I'm gathering research for the Western Shore, I have a connection with the ship as some of my family live in Coos Bay. I'm waiting for the Priske book- I e-mailed him just a few weeks ago and he indicated it would be in publishing soon. Can't wait to see your build.
thanks
Steve
USS Constitution by Michael G - Revell - Scale 1:96 - PLASTIC - Newbie Build!
Welcome on board with the Revell Constitution!!! I see you are having trouble with the deck, hmmmmm , I wonder where I've heard that before??? So, some common solutions; REMEMBER to look several steps ahead and make immediate decisions with future steps in mind. Specifically, the deck may be warped and you may be able to fix it, however there is no real satisfactory way to solve the obvious join line going across the deck. That line has driven MANY a modeler nuts in the past. Solution, there are several producers who make aftermarket wood veneer deck applications specific to the Connie. Some are a little mmmmmm pricey. Alternatively go to the local hobby shop or internet around and get a sheet of 1/32 plywood. Carefully map out all of the features on the deck, transfer them to the sheet, use a SHARP pencil to draw on planks, CAREFULLY cut the deck out of the sheet, apply it to the plastic deck (use super glue gel not the thin stuff or 2 part epoxy spread really really thin) and you have a deck that looks GREAT and looks like wood ummm because it IS wood. This in turn solves a LOT of problems - the warp, the seam and any mold faults. A simple upgrade that I think will encourage you to proceed!
Consider continuing this upgrade to the masts and spars. Wood dowels can be sanded down the the contours you need for any specific mast or spar, just use the plastic part for a template. The advantage is great appearance and resilience- the plastic is very prone to breaking at the WORST possible moment. Consider that by the time you clean up mold lines and construct the part, you could have done it in wood. The bowsprit is an excellent candidate for this simple, inexpensive upgrade.
Finally, get a few books on the subject, there are MANY out there. The challenge (FUN) is figuring out how to miniaturize the way the sailors did a task and applying that to the model. The Revell Constitution is an excellent representation of the actual ship and deserves/rewards the builder. HAVE FUN That is the purpose of this hobby!
Thanks (veteran of several Connie/United States builds)
Steve (History guy Steve)
