Mindi
Posts posted by Mindi
Thanks Mike...it's a welcome change from rigging challenges...lol
- Cabbie, Nunnehi (Don), Ryland Craze and 6 others
9
Some serious kit bashing last few days. I had no end of trouble getting the curved sofa to fit without being in front of the door to lower deck at one end, and/or pushing the small cabinet in front of the door at the helm station at the other end. I cut away the curved backboard to let the sofa in and under a bit, but that was not enough and in the end I had to take the saw to the whole sofa structure and remove about 6mm from the long end. Restuck the leather and the end panel OK.... I am sure that I must have done something incorrectly, probably around the curved back board..?? perhaps it should have been higher allowing the sofa to go under properly. Dont know....but all the parts have fitted so well that I am assuming I have introduced the error.Also found the top of the small cabinet next to the dinette was at the same height as the adjacent counter under the rear portside window. I took the top off the cabinet and ran a new piece of mahogany from the bottom of window through over the small cupboard. Looks better as one piece....well I think so anyway.Very close to finished the cabin interior. I think the lime floor planking was a good modification...that faux parquetry paper really wasnt for me.Actually the woodwork doesnt look this shiny, it is reflecting the flash in the photos, it is more semi gloss than they look.
- GrandpaPhil, Moab, schooner and 7 others
10
Experimenting with a new finish for the mahogany cabin furniture and walls ...I have always used Lifecolour LC77..Satin Clear. It is closer to Matt than Satin I think. I am using Tamiya Semi-Gloss on this furniture and interior. It is never quite right...I think this is definitely on the "gloss" side of semi gloss but it does give more life to the enclosed cabin so I am happy with it really. You can see in the next lot of photos that it is not matt.
- CRob, GrandpaPhil, yvesvidal and 3 others
6
There are actually a few errors in the instructions related to wrong part numbers or positioning. I think I will post them here as I go as an aid to someone following after me. Some are just unimportant spelling/translation errors which I will no longer bother with but just pics of corrected graphics.
- GrandpaPhil, JeffT, yvesvidal and 1 other
4
- Ryland Craze, JeffT, Moab and 2 others
5
Started to fill and spray undercoat the flybridge and cabin exteriors. This is where it comes in the process, and I have to topcoat them as well. Makes it better to brush the topcoats rather than spray and ongoing work will need touchups and hard if sprayed. Using Admiralty Matt White much better opacity than Tamiya and I like the colour. These shots show 1 coat of sprayed undercoat on the cabins and the final one of flybridge has 3 undercoats and 1 topcoat.
- Arjan, yvesvidal, GrandpaPhil and 1 other
4
- yvesvidal, Ryland Craze, GrandpaPhil and 1 other
4
Only day 2 and I have completed the frameup of the cabin....have to slow down. The Amati parts go together so accurately that assembly is just so easy. Some very minor notes for future builders, I used a 0.5mm thick deck plank under part 27 ..pointed to by knife....(rear cabin arch) to just raise it very slightly to fair it into the sides perfectly. It was OK but this was easy and did make a slightly better fit.
The limewood floor finished up OK. I could not work out exactly how to fit parts 21B and 22B...they are little supports for 21 and 22 the horizontals mid way up in the front corners. (see gb006) As far as I could see 21B and 22B were not really required and are not visible in the instructions. I kept them in case they turn out to be important.
- Moab, clearway, Ryland Craze and 2 others
5
This is the start of my build log.
The first thing was to compare the Amati kit with my previous build which was the Caldercraft Endeavour. I thiunk this is much better, with sharper CNC parts, and much better documentation. Having said that there is an annotation error on Page 1 as pictured below in GB004. The parts wont go in the places described for 6 and 7 but it is obvious where they should be...the other way around. The kit has a very awful paper print cabin floor covering which simulates the parquetry of the real boat. While I am sacrificing some authenticity I am planking the cabin floor with leftover Endeavour decking which I will possibly stain to look like teak, or may leave it matt and blond to show up better inside the cabin when largely built in.
Dave
Unless I am mistaken only one of the four boats had a white lead coating as an experiment against worm. It was the longboat (I think) and the others were assumed brown/tar as for the main ship's hull. The experiment was such a success it led directly to the expensive implementation of white lead on ship's hulls when Cook reported back to the Admiralty on the immunity the white lead had conferred on the longboat, it was untouched when examined at the end of trip
Compliments on the brilliant work.
Have been working on the front end..oops..bow..! Just about done bowsprit and supports. Finally managed to bump and snap a bumpkin...called that because if you bump it you kin start making another one. (sorry)
Serious bumpkin question...recognise that AOTS argues strongly for bumpkins and other authors & modellers reject them as over interpreting Banks' sketches and they did not exist on the ship...whatever..! Once you have them in place and the anchor lashed to the gunwhale, I cannot see how you can install bumpkin stays to the locations shown on AOTS and still lower the anchor past them. I would have thought the anchor in practice would have been lowered under control and in an emergency able to be cut free and freefall ...this would wipe out the bumpkin stays in one fell swoop. Anyone thought about this..?
- GrandpaPhil, BANYAN, cristikc and 7 others
10
- dashi, Piet, Captain Slog and 4 others
7
Hi Mindi,
glad to see you back on your Endeavour.
The photo-etch sheet is available from Cornwall Model Boats if you have no luck from Jotika.
http://www.cornwallmodelboats.co.uk/acatalog/caldercraft-brass-etch.html
Cheers
Slog
Slog
I just saw this from you...thank you very much. I have given up on getting a response from Jotika so you have got me out of jail. Cheers.
- Piet, dashi, Captain Slog and 1 other
4
Made the Pinnace first as it is white and better to practice on something which is painted. Have to do oars, but made up a simple gaff rig and mast step for one of it's sailing configurations just for the fun of it. Hate doing the boats..it was getting to this stage 5 years ago that made me stop although I am reasonably happy with this first one. I dont think this is a strong point of the kit to be honest.
- dashi, rowand, Captain Slog and 5 others
8
- Captain Slog, cristikc, dashi and 5 others
8
Gosh there are some Endeavours being built here which are a standard I cant approach. Better I dont look....! Some beautiful rigging work happening.
I was so unhappy with my cannon that i took them off, removed the capping rains for the gundeck, and started to bulid gun tackles albeit with only one block. Make them a little more detailed if it works out OK.
Grand Banks 46 by Mindi - FINISHED - Amati Models - 1:20
Notes on fitting inside cabin walls
These walls (127,128) need to finish flush with roof side frames (17). To achieve this you can either plane off about 3mm for the full length from either ther bottom or top, in my case it had to come off the top because I did not trial fit the flybridge roof until later and it was too late to take it off the bottom. The lower edge of these side walls sits on top of the boat floor not outside it. See next post but you can see here that I have removed the overhead instrument panel 169 to enable roof fit
