Hubac's Historian
Everything posted by Hubac's Historian
  1. I managed to get the red sprayed before leaving for the Cape. We had a wonderful week in Hampton Bays with lot’s of family fun, good dinners, and plenty of medicinal scotch. I also managed to have a productive week laying down all of the primary colors: Unfortunately, in my haste, I forgot to mask off the monogramed escutcheons between the main deck guns. The centers, which will be painted ultra-marine really require a white undercoat for the color to come out right. This now necessitated hand-priming of these little ovals. I deliberated, from the start of this whole project, whether the red should extend up into the amortisement. Ultimately, I decided that it made more sense to follow a continuous, banded approach to each of the three primary colors, with the yellow ocher serving as a unifier. The impression of the amortisement is a bit skewed, at the moment, because I have yet to pick out the supporting dolphins in gold and silver. I took great care to hand-paint subtle edge borders, in yellow ocher, around the triangular panels of the upper section. From here, it is the long, steady march of careful cutting-in, followed by rounds of re-touching: Perhaps, above, it is more apparent how my idea to use ultra-marine along the lower band of fleurs, accentuates the scalloped design of the frieze. This is probably more ultra-marine than would have actually been applied, owing to the expense, nonetheless it is an artistic choice that highlights the effort of making the whole thing. Slowly and surely, we are getting there! As ever, thank you for looking in.
  2. The beauty of our hobby is that it rewards us for our resourcefulness - for simply finding a way that works for us, individually. The beauty of your ship is that it is remarkably beautiful, and a testament to your skill and craftsmanship. It can be difficult to filter out the “noise,” but try not to pay any mind to blowhards like that. Your presence, here, has been missed very much YankeeD. Welcome back!
  3. I can believe it, yes! I remember buying my first pair of titanium eyeglass frames, which were wonderful in every way, but EXPENSIVE for the times. At least I got about six years out of that pair. I would certainly agree that that experience has been beneficial for you. Disciplined best practices, taught from the outset, instill a rigorous approach. My woodworking apprenticeship was administered by a man who insisted I mill material to the nearest thousandth of an inch, as I did the final planing on a KUNDIG sanding machine. His point was not that those tolerances were critical to the work we were doing, but that paying attention to the process was. David was forever reminding me to think things through, in order to avoid “negative pre-determinants.”
  4. This is really a very impressive kit, and your finish work is impeccable.
  5. Wonderfully, practical approach, very well explained and a beautiful result!
  6. It is nice to see you again, Marc. Beautiful work on the port framing!
  7. Thank you for the birthday wishes, Bill, and thank you very much for reading through my log! Over the years, it has grown to an absurd length for the progress made, but the research, therein, is essentially the book I will eventually write, in its unedited long-form. To your question, I would probably display one side with a fully open broadside, and the other side fully closed - if I wanted to show the contrast in appearance. On my first SR, I closed some ports on the lower tier, because I was copying the box cover artwork. As time went by, I came to regard that as a sort of arbitrary display without much logical grounding in what would have really happened on the ship. One other possibility would be to close all of the ports on the lower deck, as would be done if weather conditions would not allow for those guns to be run out.
  8. There are quite a number of MSW builders named Mark, who are doing remarkable things, here: Mark Taylor, Mark (SJ Soane), Mark Tiedens, and I am also a Marc. The work you are doing here, Mark, is very inspiring. I personally have ambitions of eventually building a large and complex fully framed model, like this, someday. Presently, I haven’t yet done anything like that, but it is comforting to realize what can be achieved by jumping right in there. I really appreciate your willingness to share the learning process - both for its triumphs and frustrations. You are doing an incredible job!
  9. Part two of my vacation begins this Friday. I will try to airbrush the red base before I leave, so that maybe I can lay down the blues and get a start on the yellow. I really like how the whole thing - the stern extensions, the frieze and port enhancements - all homogenizes under a layer of white primer: Painting this piece will be a marathon, but perhaps I will at least have the complete port side ready for the show. All the best, and thank you for looking-in!
  10. Beautifully done, and well photographed. This log will be a gem!
  11. I’ve been enjoying a very restful and beachy vacation in Cape Cod. I brought one of the aft upper bulwark plates with me, and have been busily cleaning up the frieze, securing eyebolts for the gun tackles, filling some holes and drilling others. Not much to really show there. I did, however, happen upon this other build of the Heller kit, and it is wonderfully vivid in it’s use of color and shading: https://modellistinavali.forumattivo.com/t3669p75-soleil-royal-1-100-heller I thought it may interest some of you to take a look.
  12. Actually, looking at it a little closer, now, I do think that before you glue-in the hawser pieces, you will want to do a good dry-fit between the bottom of the hawse pieces and the head knee extensions that wrap around the bow, and below the hawsers; if the hawse-piece obstructs the knee extension, in any way, that will be much harder to trim after the hawse piece is glued in-place.
  13. Nicely done, Bill! One observation - you may want to glue and putty in your hawser entry holes pieces sooner than later, so that you can paint the continuation of the bee-lines in this area.
  14. Yes, three cheers for the big cats! 48, this summer. Summer of 69 for you, Bill?
  15. Very well done! I think you will continue to be pleased with your first effort, even as your skills continue to improve. There is very much to be proud of here; clean woodwork, and taught rigging are major accomplishments!
  16. Apart from everyone else’s excellent suggestions, I think it is always a good idea to sight the beelines with your eye close to the hull; look from bow to stern for a fair run, and then again from stern to bow. Because there is such a stark contrast between the black and yellow, you want to make sure there aren’t any unwanted flats or wobble in your lines. They should all be fair, smooth curves.
  17. You have made a wonderful model, B.E., and it has been a pleasure to watch your meticulous care and attention to all details, great and small. While Chuck makes an excellent kit, it still requires great talent and finesse to bring it to its fullest realization. Congratulations on a job well done!
  18. This looks really terrific, Tom. I look forward to seeing this in person, in New London!
