Everything posted by Beckmann
Hmmmmmm.... I propably forced the stern frames too much back, when I glued the filler pieces between the last bulkhead and the stern frame. This can not be corrected any more. Maybe I must make new quarter gallery windows with a tiny little bit more distortion. Otherwise the forward ending of the quarter gallery will lift too much up. The angle must be parallel to the planking. Is that right?
Hi Rusty, I am not shure, but check your left and right stern frame. They seem to be too wide. I made that mistake and it was awful to correct it after having glued the transom in position. Matthias
- 642 replies
- winchelsea
- Syren Ship Model Company
I had a little battle with my Winnie and that is the result. First I removed the small planks behind the door to the Qgallery. Then I shortened the 3 planks above and cut them loose from the frame. After correcting the shape of the frame I added the Qgallery transom peace and glued everything together again. I think it is close to the position it should be now. And thank you Chuck and Mike for your help. Matthias
Brigantine Leon by Beckmann - 1/48
Beckmann replied to Beckmann's topic in - Build logs for subjects built 1851 - 1900
Hi Doug, I am fine thank you. It has been a while now, that I did some work on Leon. I was pulled away by Chuck‘s Winchelsea. But I will certainly keep working on Leon. Concerning the companionway, I am not shure. But there is so little space and the hatch is in the way. So I just did not add it yet. I will have to do some more research. Matthias -
Thanks Chuck for the advice. I will carefully try to correct the shape by removing the short planks behind the door to the Qgallery, maybe I manage to cut lose the 3 planks above and then correct the shape of the frame. Today the parts of chapter 3 arrived, so I have a good guide with thd laser cut part.
Yesterday I glued tue transom in position. All looked well. The ivory windows fit is not bad as well. but today I realised, that I produced a severe problem by not sanding down the outer frames enough. I don't know how to fix that yet. I have seen this problem in some other build logs as well, so check that guys, before you glue the transom in position. Matthias
HMS FLY by cafmodel - 1/48
Beckmann replied to cafmodel's topic in - Build logs for subjects built 1751 - 1800
Hi, what Kind of wood do you use? And in wich scale do you work? Matthias- 59 replies
Mike, that is an increadable example of patience an accuracy. Your Winni will be an extraordinary model, once completed! Matthias
- 607 replies
- winchelsea
Bravo, ein phantastisches Modell!!! Grüße, Matthias
- 122 replies
- caldercraft
- agamemnon
What an excellent and beautiful design!! We are lucky to participate in this, thanks Chuck! Will you leave this black hole for the rudder like it is, or open it later?
- 1,784 replies
- winchelsea
Thanks everybody for the comments and likes!! I learned two or three things while doing this: The bulkheads need to be in perfect shape. If not (and mine are not) it can happen, that you get a bump in the surface. And then, if you sand everything, you suddenly see the bulkhead. I had that at two points. I had to change those planks, wich is really not a nice thing to do. The other thing is, that the planks should not be too thin. Better more near to 2mm than 1,6 mm. That makes is all more safe and stable. And the better you bend the planks before glouing, the better they fit. Forcing it in position always makes problems. There is a saying about building houses in Germany: Make the first one for your enemy, the second one for your friend and the third one for yourself. That is probably, what I should do with this Winnie-project!😉 Matthias
