drobinson02199
Posts posted by drobinson02199
  1. Charles:
    The issue you raise is one I gave some thought to.  Thinking ahead, once those ribs are removed, you have some long stretches of planking with no rib support above the deck.  So it's important to glue the sides of the planks to each other across that whole length, at least, so they support each other and remain flush.
    I went ahead and glued the planks to the ribs, because you want the ribs to shape the run of the planking both horizontally and vertically and keep the planks flush, and I've never been a fan of pins as I find they don't hold.  Used CA medium glue.  Then, when you are ready to remove the ribs, take a pair of long nose pliers and fix them to a rib lengthwise from the top down to the deck, and wiggle gently side to side to detach the rib from the planks.  Then twist the pliers to remove the rib.  That will leave a stub at the deck which you can sand or grind down.  The sanding doesn't have to be too pretty because that whole area is covered over by a molding later on.
    Now that I have typed the above, I belatedly realize that I planked the deck AFTER removing the ribs, as stated in the manual, so that I could plank over the rib stumps and not mar the planking grinding them down flush with a Dremel drum.  But again, as long as you are careful to grind them down in parallel with the planks and not extend too far out toward the center of the ship, the molding will cover any marring of the deck.  What you can do is punch out that molding and see how far it extends from the planking toward the center, and that will tell you where to be careful and where you can grind away.
    Hope this helps.
    Regards,
    David
  2. Re my comments above about drilling holes under the channels for the deadeyes, I used the right size (short) drill on an angle and then angled in the bottom of the chain plate.  Worked OK, but some distortion of the rods that I couldn't fix.  I did that on the side that won't be visible.
    Then I just bit the bullet and used a 1/16 inch drill straight down, which gave a hole a bit too large, but since I was reinforcing these by bending the other wire under the channel, worked fine.  A picture of that below.
    Regards,
    David
  3. I've now pretty much finished all the deck structures and fittings.  Pictures here of all that.
    Some comments on sequence.  I'm not exactly sure why, but I chose to go ahead and do the stern deadeyes early, which was a relief when I installed the curved stern railing.  I'm not sure I'd have been able to avoid mangling it if I'd done them in the manual sequence, which is during the rigging stage.
    Speaking of those, the manual and drawings show a way to create the chain plate from wire, and then fix it to the deck below the deadeyes, which is conceptually fine for those in the middle of the hull if you have a 3 inch long .75mm drill bit -- mine are shorter, and I'm not sure they exist.  I may still do it by drilling on an angle.  It still looks like a flimsy fixing for the tension on the deadeyes, so I'm going to reinforce them to the bottom of the channel.
    But there's no clear way shown to attach the ones on the stern that you see here -- so I improvised by creating a sort of wire "plug" on the deadeye and gluing that into the hole.  I'll do the ones on either side of the hull next, as I won't want to try to maneuver those into place with masts and yards up (which is the way the manual would have you do it).
    The other improvisation is the small front railing between the ladders.  I lost one of the stanchions on the floor somewhere, and of course Mantua provides no spares.  So I had to fashion the two rear stanchions out of wire.
    Before I get to the rigging, I need to build the lifeboats and mount them, which is the next step.
    Regards,
    David
  4. I finished and mounted the rudder, and applied the bow and stern decorations.  Pictures below.
    The drawing shows the white rubbing strakes running straight to the figurehead at the bow, and the brass decorations on that same line without the bend you see here.  While the rubbing strakes would "frame" the top decoration, I'm not sure what the bottom of the lower one would look like.  In any event, as I mentioned above, I had missed that in the drawings and terminated the strakes at the end of the hull.  So I extended them and applied the decorations as you see here.
    Also as noted in my earlier post, the space between the strakes at the stern was not wide enough for the stern decorations, so I had to file them down to fit.  That seems to have worked out OK.
    Regards,
    David
  5. The white rubbing strakes are now on.  The manual wants pins to hold the curve, but I steamed the curve into the strips, then painted them, and then used CA glue.
    I think I may have ended the strakes too soon at the bow, and if so, I'll fix that later.  I KNOW I have an issue at the stern where the width between the strakes isn't quite large enough for the brass figures that go in there, but I ran out of stern to fix the lower strake to, so I'll fix that as well by cutting down the brass to fit.
    I need to touch all of this up now with black and white paint.
    Regards,
    David
  6. Back from vacation, and found the extra copper plates waiting for me.  Took me a while amidst post-vacation catch up tasks to finish off the coppering of the hull.
    That brought me to finishing off the keel, bow and stern.  I had planned to use copper tape for that, and as things turned out, it worked really well.  I've attached pictures showing pre-taping rough sections, and then the finished product.
    Found there was a learning curve in handling the tape to minimize crinkles, but they show up no matter what you do, so I'm glad I used the plates for most of the hull, and equally glad I used tape to finish off the edges.
    Now I can go back and pick up the sequence items I skipped waiting for the extra plates to arrive.
    Regards,
    David
  7. While I'm waiting for the rest of the copper plates to arrive from Ages of Sail, I'm doing what I can to move forward.  Here are the planked decks.
    I can do the next steps involving more deck finishing, but don't want to do the port covers or the white hull strips until I finish the coppering, because they will mar/bend when I lay the ship on its side.
    Regards,
    David
  8. [EDIT NOTE:  As sometimes happens on this site, the pictures came out in reverse order from what I intended]
    I'm stuck at the moment because there aren't enough copper plates in the kit to finish the job -- by about 400.  Ages of Sail is sending me more, but in the meantime I'm working around it to the extent I can, which is limited.
    I've mentioned above that I used a different approach to copper each side of the hull.  On the first side I started at the keel, then worked up a bit, then went to the waterline, worked down, and then fitted the two together.  You can see that in the picture below.
    On the second side (the one I plan to display), I started at the waterline and am working down (you can see where I ran out of plates).  As the picture shows, it's a much better looking pattern up close.
    From 3 feet or more away, the first side looks fine, but the display side looks much better.
    Regards,
    David
  9. I haven't posted in a while because I've been coppering, coppering, coppering . . .
    One side now done -- picture attached.  I started on the side I don't plan to display so I could learn from it.  Results are fine, but on the other side I think I'll start at the waterline and bring it down to the keel, where the final fitting of odd pieces and shapes will be easier.  On this side, I did it where the bottom and top layers met, and it was a LOT of cutting, filing, and fitting.
    I'm a bit concerned about my supply of copper plates, but we'll see how that goes.  May have to call Ages of Sail for a "make good".
    Regards,
    David
  10. HOF:
    Thanks -- the YouTube videos were really helpful.  He's using very thin plates -- mine are the thicker kit plates so I don't have the same flexibility he does.
    Two big things I took out of the videos:
    1. The idea of end-capping the cutwater, stern and keel.  It's given me a new thought on how to do that on my model.
    2. I'm reflecting on his approach of doing the waterline with a row of plates and then using cut plates in the middle to finish off.  I was going to trim plates to fit at the waterline.  On reflection, I think his way will work better and so that's what I'll do.
    I'm using medium glue all the way, and it's working pretty well.  I'll post a shot when I get a bit further along.
    Regards,
    David
  11. Here's why I abandoned the tape.  I made up a strip of the copper tape and put it above a row of the real plates that I have started at the keel.
    It's really hard to get good shots of this because of the way the tape and plates reflect light, but you can see it in these two pics.  The pounce wheel does a fair job of making rivet marks at top and bottom, but the divider rivets just don't look right -- AND, the tape is really shiny compared to the copper plates.
    Regards,
    David
