Jim Rogers
NRG Member-
Everything posted by Jim Rogers
I build the majority of my own cases as I like the look of the wood frame surrounding the model. I have also started adding water features and I am working my way through those trials and tribulations. On occasions when I want a quality Acrylic only case I go to www.casesforcollectibles.com. Here are a few photos of my cases upside down of course. The one with the Longboat is a Casesforcollectibles case. I used their MDF base and veneered it. The ‘well’ you see is how I get the ship down to the water line then it is through bolted through the well and the keel. Not going anywhere so it is a travel and display case. One went from WA to the whaling museum on Maui with zero damage.
Should the deck planking be completed before the cap rail installation?
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Where did they carry the wood for this stove? It must have been a large load.
- 1,784 replies
- winchelsea
The only deck beams glued in are above the bulkheads all the rest are temporarily inserted. Still having photo rotation issues with various photos trying to figure it out.
- 105 replies
- winchelsea
My Winnie will be a tiny little bit different then others. I just did not like the look of the Captains cabin walls so I built my own and painted them white. This made the cabin a tad bit narrower so without doing a lot of trimming on the doors it could not fit four doors. Went with three and a filler. Looks fine. Not historically or Chuck accurate but nobody will know except this little group. Also added a ship’s cat, the Admiral loves it.
- 105 replies
- winchelsea
Been busy busy working on a display for the whaling museum in Lahaina Maui . A buddy of mine built the Charles W Morgan and asked me to build the case. The trick with this case was it had to (1) be used for transport without damage to the model, (2) be the model display case with no modification after shipment and (3) have a water feature. It all worked…go figure. Anyway after this project I got back to work on my Winnie.
- 105 replies
- winchelsea
Chuck I’ll post some photos in the next couple of days. I usually download the plans from the Syren site. Never think about checking on MSW. Daaaa. On the gun port covers you did not have a line for opening but I was planning on adding it. Would a cleat be added above or on the side of the gun port to secure.
- 1,784 replies
- winchelsea
When will Chapter 7 written instructions be hitting the streets?
- 1,784 replies
- winchelsea
Gluing deck planking
Jim Rogers replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
Personally I put glue on every surface the plank touches. -
New Member from Western Washington State
Jim Rogers replied to Michael Jones's topic in New member Introductions
Welcome aboard from Bremerton, WA -
Micro Mark Bending Machine 81356
Jim Rogers replied to Railcardownunder's topic in Modeling tools and Workshop Equipment
Personally I see no use in these bending wood strips. Side bending, wet bending and steam bending would all be preferred by me. -
“Turns out I only needed to adjust and use one wider plank” You talked about having to add one or two wider planks on the ends I was wondering if it would also work top dead center.
- 1,784 replies
- winchelsea
Could the two wider planks go top center?
- 1,784 replies
- winchelsea
Your ship your call.
Where beams bolted into place and should we simulate bolts?
- 1,784 replies
- winchelsea
Apply a little heat with a heat gun and pull it out.
