king derelict
Everything posted by king derelict
  1. Thank you Mike I'm looking forward to the landscaping. The bag of blocks has become noticeable lighter. I'm hoping that I have enough. So far morale is holding up but I'm not looking forward to building the inner walls next. Alan
  2. Thank you very much Andrew. Its quite restful adding the blocks and seeing the walls grow but shaping the blocks does require a bit of determination to continue Alan
  3. Absolutely beautiful work. Its a stunning model. The crew makes it stand out but I think the wonderfully realistic sails make this a spectacular boat. Congratulations Alan
  4. I really like a lot of the subjects that Rosen produce and I have build some of their 1/72 kits. Some detail is excellent but in other areas flash is horrible and swamps the part Alan
  5. I'm not looking forward to those inside curves. I foresee a lot of custom filing in my future. I work for Rolls-Royce supporting the Lift System that bolts to the P+W engine. Liftfan, swivel duct and roll system. All the unconventional stuff. Alan
  6. Thank you OC. This build is going much better than the Rochelle Towers. All the feedback and help and likes keeps morale up and actually I think its easier to see progress on this one. I'm still keen to push ahead instead of sticking it out of sight for a while Alan
  7. Ive always loved the Seven and the early Lotus offerings, Elan and Europa Alan
  8. The details look really good. Its going to be a great and different model Alan
  9. Sorry for the dolorous progress. Real like has been intruding badly these last days. Partly its self inflicted. I was asked to come back and consult for a couple of engine tests and I (possibly foolishly) agreed. It will keep the wolf a few paces away from the door and doubtless improve sales at Sprue brothers et al. Its also good to hear the howl of an F135 at full throttle again Anyway, in quiet hours some progress has been made and the outer faces of the walls have been finished Now I have to turn it around and do it all over again on the inside. Some of the blockwork on the inside of the towers is going to be interesting.. I had planned to take a break at this point but I'm enjoying it too much and playing with engines will provide enough diversion so I'll try to keep going. Its going to be slow though so get comfy and lay in plenty of snacks and adult beverages Thanks for all the support, likes and comments Alan
  10. Thanks Ken The figures are very nice but a few mould lines need to be filed down. I'm very impressed with them. Alan
  11. Thanks EG Looks like there is other howitzer activity on the board too Alan
  12. Thank you OC. Thank you for the advice regarding the figures. I am amazed at the detail. You can see beards on faces and individual fingers on hands. Alan
  13. Gators Grip and the similar product from Mig Ammo have similar properties. They give you time to get a good placement of the PE. They also dry with some flexibility which means the part doesn't break off as easily as when glued with .CA which is brittle. I like the GG thin version best. Alan
  14. Really beautiful Mike. The panel lines are really nice and you did a masterful job of the folded wings. Alan
  15. Absolutely stunning Mike. You did a great job and the dio really sets it off very well. The mechanic really sets the scene. Looking forward to the next one Alan
  16. Absolutely stunning OC. The details on the uniforms is so precise Alan
  17. This should be fun. It looks more sci-fi than your space fighter Alan
  18. In my flow of build I end up painting the main deck before painting the superstructure so I tend to 1 assemble hull, deck and main structure elements 2 Prime 3 paint the main deck 4 Mask the main deck 5 paint hull and structures if they are the same colour 6 Mask hull and paint structures if they are different 7 Add details and touch up. I'm not claiming this is the most efficient way but it works for me Alan
  19. This is going to be spectacular Alan
  20. I still slowly grinding (literally) away at the outer walls. As usual nothing much got done at the weekend but I got some useful time in today. It still moves along fairly slowly because I think its worth letting a tier set before trying to sand back level and risking knocking off a couple of blocks and having to do it all over again. I turned the last corner and am on the last tower and section of wall This is where the hill will climb up the wall And the panorama showing the completed work so far. Our nice post lady brought a package from the UK this morning The 10mm Pendraken medieval figures. They are really beautiful and I think they will work well. Thank you @Old Collingwood for the suggestion. They have a medieval cannon set too so I am considering a couple. I'm still a bit concerned about @Egilmanhowitzer Painting them is going to be interesting I think we will be going for *overall effect* Does anyone know how to prime metal figures? I have the Mr Metal Primer for PE so I am planning on using that Some thought is going to have to be given to adding them to the model. They are too small to really remove from their bases so maybe I can thin the base down. Thanks for looking in, all the likes and comments. Alan .
  21. I never got on well with my Tamiya PE pliers. The jaws quickly went out of alignment. Possibly it was just a dud pair. The magnifiers with light are a big help to me. I tend to stick the hull to something that I can hold to minimise handling of the model. I use a piece of plastic packing material liberated from work and double sided tape. Others use paint bottle tops and blu tack. There is a big deep hole of tools that you can throw money into Alan
  22. I had the Airfix Defiant kit about Fifty five years ago. I painted it as a night fighter then. It looks like the kit has got more sophisticated since. It's a lovely model and a nice concept but it made an indifferent aircraft. Lots of weight that could have been used elsewhere Alan
  23. Sorry. Autocorrect insists that PE should be OR and I missed a couple in my reply. For me the key to PE is planning the sequence of bends so you can access the area to bend as needed Good luck Alan
